Go Back   ADVrider > Riding > Regional forums > Canada
Old 09-27-2011, 06:33 PM   #2056
Fab418
Pig ridin'
Oddometer: 176
The miserable ride...
It started like it would be a great escape from regular life and a trip I've been tinling about for a long time: to ride all the way to a town named Natashquan where the road ends on the lower north coast of the St-Lawrence river. I would be driving through the TCAT/TNE for a while and when at Relais Gabriel (a little higher than Manic 5), I would dive toward the coast and ride up till there is no more road.
I started the bike at around 11am and got to the gas station to fill it up plus a 10 litres can I would be carrying aboard for the 380km stretch without fuel that Deadly and Shipwreck skipped when they came by.
As i got moving, I noticed that my lighter socket was not getting current and that my GPS was running on it's own batteries which would not be good enough. 20km from home. First stop. It was only a blown fuse that must have shorted out when I plugged back the battery two days before after changing the gearbox seal for the second time in two weeks since the clerk at the seal shop gave me the wrong one by 1mm the first time. Speaking of which, after two days riding the bike with no sign of dripping oil, the f**ker decided it should start pissing now that I was on the road.
Hmmm. I was getting seriously pissed off about me (for not testing it long enough) and the bike (for letting me down). I said screw it little f**ker, I'm going to ride the hell out of you until you spit enough oil to ruin the brand new clutch I've put in two weeks earlier (yes the marks on the clutch are 120deg apart for you oil-head aficionados-must be the gear box bearing). Note to self: buy an oil resistant friction disc next time around idiot.
And rolling I was again. I was going to ride from my place (Chicoutimi) to Labrieville, like Ted and Shaun did last time and then up north trying to get to Baie-Comeau before darkness. 710km of pure gravel travel. 7 hours to go before dusk. Place your bets.
Along the way the newly named Fab's hill (thanks guys). Pick your line:
Then I got pass L'auberge du 31 where there is fuel and lodging available. A nice river along the way:
I was in Labrieville at 2:45 nearly 4 hours after leaving the gas station. Only 380km to go and 4:15hours till the day is over. Let's go.
From Labrieville (for reference, Labrieville is located at about km 79 on this particular logging road), the road is REALLY wide and well maintained mainly because there is logging activity going on. You should always keep your right to avoid the big 14 feet wide (yes, wide) trucks that are using the center of the road as it would not support their weight if they'd go to far to the side of it.
Nice view out of Labrieville:
Nothing to declare until about km 174 or so where the road turns into something less wide but still decent with more crests and turns which make for an entertaining ride:
At this point, you are really in a remote place. If you think the TLHW is remote, think again; I did not see a living soul between 3:00pm and 6:15pm. No car, no truck, no cabin, nothing for 3+ hours straight. It never happened to me before and that was a bit freaky to be honest. The view:
After that point the km markers started going downward from about 180 so it meant that I would have to ride another 180 klics to get to the nearest town. No problem I thought. Bu this road was not the same animal as the one going up. Wide, but hardened and not maintained ie: full of 6-8 inches deep potholes.
At one point, the bike developed a strange noise when hitting potholes, like the rear wheel rubbing the fender kinda noise. I inspected the shock mounts and the rear of the bike but found nothing. The noise did not stop tho.
Later on the rear got all wobbly. I stopped to find the rear tire had a new hole in it. Easy. Take out the tool kit and plug it. 15 minutes later (I did not pack that well ) and I'm back on the road.
15km later, flat. Again. Plug's gone.
Re-plug.
Re-pack.
Find what was causing the funny noise; the aluminum luggage rack broke in 2.
Re-pack.
By that time, it's getting darker and time is running out and I still have 80 klics to go to reach Baie-Comeau. Here's the next 2 hours in rapid RR mode:
Get running, loose a pannier. Luckily, I see it fly in the rear view mirror. Stop, turn around and replace said pannier. Re-pack 3 removed the dry-bag's weight from the top of the pannier so it now has a tendency to fly off the bike. Back on the road for about 40 km until I realize that the pannier is gone again. Turn around. Ride 20 km in opposite direction on high beems (it's dark now). No pannier. Turn back. Screw that pannier, that shirt, those shoes, that food, that etc..Roll 40km and another plug's gone. Flat. Change the plug in total darkness with strange noises in the wood behind me. Probably a beaver taping the water to scare me.. Back on the road for a while. Only 10km to Baie-Comeau. Notice something loose when I push my butt against the luggage. Dry-bag's gone with tent mattress, sleeping bag and daughter's Strawberry shortcake's pillow. Turn around. Find bag 5km up. Re-pack. Enough. First trail to the side and I pitch my newly found tent without having lunch and I go instantly to sleep.
6:00, feeling a bit cold, I get dress to find it's been freezing:
I get to Baie-Comeau shortly after to get fuel for me and the bike and decide that I'm going back home as the clutch started to slip and my bike is definitively not in shape for the ride I anticipated. Maintenance is required. 300km of slab and 4 plugs and I get home thanks to a 94 GS that will not leave me stranded.
I'm not sure whether it's my personal experience but I'm not 100% positive that every folk doing the TCAT would be advised to ride that particular 380km section. Shorting it to Labrieville is only about 150km vs the 380 and the road is spectacular too. It's definitely a challenging stretch tho. Your choice. I did it. Will I do it again? Maybe....
Fabrice
TCAT traveler: If ever in need near Saguenay, Quebec; have tools, will help. PM me.
http://www.fabricetremblay.ca
My HPF: 21 inch-mx forks R11GS conversion
Fab418 screwed with this post 09-27-2011 at 06:41 PM
Fab418 is online now   Reply With Quote
Old 09-27-2011, 07:18 PM   #2057
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,603
[QUOTE=hardwaregrrl] So, Ted had asked if I was afraid of heights as we may be passing over some of the old rail bridges. This is what came to mind...
Photo & Video Sharing by SmugMug
[QUOTE]
That was the scariest ride over a bridge that I've ever read about
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is online now   Reply With Quote
Old 09-27-2011, 07:26 PM   #2058
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
This is the one that gives me nightmares...
Old 09-27-2011, 07:27 PM   #2059
Dan Alexander
Oddometer: 7,603
Fab, sounds like you found the 'adventure' in your part of the Trans Canada Adventure Trail
Beautiful pics, reminds me of the Trans Taiga Hwy.
Old 09-27-2011, 07:28 PM   #2060
Dan Alexander
Oddometer: 7,603
Yikes .. do trains come along occasionally?
Have you read Colebatch's ride report on crossing that Siberian bridge and what happened ... a must read
Old 09-27-2011, 07:34 PM   #2061
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
No, that bridge is no longer in use, except for the occasional ghost train...
Must read the Siberian bridge story. The tall one can't really be ridden. The ties are too far apart, and there's no railing. Just the stuff of nightmares, in my book.
Old 09-27-2011, 07:56 PM   #2062
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,540
Yeah, read colebatch's account, then watch this.
Big, huge, balls on this guy!
Old 09-27-2011, 09:49 PM   #2063
olebiker
Old buzzard bait
olebiker's Avatar
Oddometer: 3,693
Yep I don't think I could bring myself to ride that one. Looks like a long ways down too.
Originally Posted by ShadyRascal
Then all the Jo Momma shit started.
olebiker is offline   Reply With Quote
Old 09-28-2011, 04:32 AM   #2064
Dan Alexander
Oddometer: 7,603
http://www.advrider.com/forums/showp...&postcount=552
http://www.advrider.com/forums/showp...&postcount=587
Dan Alexander screwed with this post 09-28-2011 at 04:39 AM
Old 09-28-2011, 04:41 AM   #2065
Fab418
Pig ridin'
Oddometer: 176
Thanks. And yes, I did find the ADV out there! but lost some shoes too. Shopping time before it gets too cold to wear sandals
Fabrice
Old 09-28-2011, 05:20 AM   #2066
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,092
Should there be a cautious note to that section " beware this trail takes your shoes"
shipwrek12001 is offline   Reply With Quote
Old 09-28-2011, 05:21 AM   #2067
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
Why not go back and look for them?
Old 09-28-2011, 05:24 AM   #2068
Fab418
Pig ridin'
Oddometer: 176
2 pairs so far.
Fabrice
Old 09-28-2011, 05:25 AM   #2069
Fab418
Pig ridin'
Oddometer: 176
I did. Couldn't find the pannier in the dark. That trail eats shoes, you've been warned.
Fabrice
Old 09-28-2011, 05:56 AM   #2070
Deadly99 OP
Fast and Far
Deadly99's Avatar
Oddometer: 10,038
As things are kind of bouncing around and some great reports coming in from folks involved in the project I figured a map would help folks visualize where we are talking about.
This is a pretty rough outline of the Eastern TCAT
The green line on the right side is Newfoundland. Skibum69 is making this section...not complete but I believe it will involve some slab up the vgiking highway, part of an old rail line and maybe some gravel roads. (approx 2-4 days)
The black line is the Trans Labrador Highway. Over 2000 kilometeres, about a 65-35 mix of gravel and pavement. Nice big easy to navigate roads. (Approx 2-4 days)
The yellow line is Fab's section of the route. It could be broken into three parts. Baie Comeau to Labrieville is the first section (heading west to east) and is a mix of logging roads, 380 km between gas. This is the section Fab is referring to in his previous posts. The second part if from Labrieville to Chicoutimi and is about 250 km's of logging roads. Keep in mind that Labrieville is a very small general store and gas stop. Very remote section of the TCAT (the 380 + 250) and from fabs words and from my experience.....way the feck out there and a consistant source of people loosing their shoes, lol. The third part of Fab's section goes from Chcoutimmi to Chibougamua, again logging roads make up the most of this section. (approx 3-6 days)
The red section is Juames and myself section. The first half (from Chibougamau to Ottawa) consists of logging roads, the second half consists of gravel roads and a handful of trails. (Approx 6-12 days)
The grey section was built upon sugesstions from Finnidian (Gord). A mix of gravel roads, logging roads and some trails. There are previous posts by SDWebb, myself and Gord on this area. (Approx 2-4 days)
The pink section was created by myself and parts have yet to be tested, but looks good on paper Next summer this is on the plate for me. (Approx 1-2 days)
The blue section is the one that Hardwaregrrl is reporting on and has been kind enough to "test ride" for us (Approx 3-6 days)
As you can see it is all coming together nicley. The bulk of this half of the route is complete or very close to being complete. Based on some rough educated guesses I would say this half of the TCAT will take folks between 19 to 38 days to complete.
The western half has also had a lot of work on it by those involved and looks to be good on paper. The bulk of it has been ridden and from the pics and reports looks to be outstanding. If all goes to plan I am taking the bulk of next summer off (August-Sept) and will be riding the entire western half in one go. I think I am in for something special
Sorry about the interruption, keep the reports coming
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is online now   Reply With Quote
Times are GMT -7.   It's 04:49 PM.
