Old 10-04-2011, 07:22 AM   #61
TheCowboy
back in the saddle again
TheCowboy's Avatar
Oddometer: 606
thanks JR, I have the stator out and headed to the electrical repair shop. I appreciate all the help... I could be stuck in worst places than Durango CO....
TheCowboy
TheCowboy is offline   Reply With Quote
Old 10-04-2011, 08:55 AM   #62
3Rrr
Read Ride Reflect recycle
3Rrr's Avatar
Oddometer: 170
Originally Posted by YetiGS View Post
I'm kind of surprised how many stators people seem to need to be replacing.
I believe that at the RawHyde Moab event two weeks ago there were two failed Stators. I know one was at 50,000 miles, not sure on the other.
Something to be mindful of and have checked before warranty expires.
3Rrr is online now   Reply With Quote
Old 10-04-2011, 05:42 PM   #63
JRWooden
Oddometer: 4,257
TheCowboy
Yeah... it could be LOTS worse
Old 10-05-2011, 07:26 PM   #64
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
johngil is offline   Reply With Quote
Old 10-05-2011, 07:55 PM   #65
cbOwl
just ridin somewhere
Oddometer: 84
That "other" one was mine - failed at 21,800 miles. I took it to Grand Junction BMW and they tested it and told me it was fine. It wasn't and it quite several times on me in Moab. Took it to BMW of Denver, they tested it and had it repaired within a couple of days.
cbOwl is offline   Reply With Quote
Old 11-22-2011, 12:42 AM   #66
chadams
Oddometer: 209
fired stator...
Add me to the list.... Mine died without warning. I was lucky though as I rode home yesterday and it must of gone on the way home as the battery was dead flat this morning. I jump started the bike using a car battery, I then checked and my battery voltage was not changing with rpm, or when the bike turned off... it sat flat around 12v DC. Then checked the stator wires and the best I could get out of two pairs was 13v AC.
So I removed the stator and reg/rec then posted them to a local specialist. I should have them back in a week. What I was surprised about was the difference colour / condition of the rods on the stator. The ones closest to the front of the motor / exhaust were in very bad condition, the insulation looked burnt and melted. The rods away from the exhaust looked like new.
To reduce the issue initially I'll wrap my headers in heat tape, but long term will pick up an after market set with no cat converter on have them ceramic coated.
This is my first and last BMW for me, I'll never buy one again. Given I've got over 80,000km my re-sale value is shot so I'll keep it and just replace parts with none BMW parts as they break and fail.....
Current ride:- 2002 KLX400R
Previous rides:-09 f800gs, 05 z750, 81 z1000j, 84 gpz1100, 98 dr250, 99 dr250, 96 dr350, 93 rf900, 93 nx650, 98 xtz660, 97 dt200r
chadams is offline   Reply With Quote
Old 11-22-2011, 05:55 AM   #67
JRWooden
Oddometer: 4,257
You don't by chance have a picture of that stator do you?
That's very odd... the several other failed stators I've seen here were all pretty uniformly (dark) colored all around....
If the guy at the shop has any feedback on the failure mechanism please post the results!
All: A am still looking for a failed stator on which to do some forensics engineering
If someone has a dead one kicking around that they don't need I'd happly pay USA postage and a six of your favorite beverage for it!
Old 03-26-2012, 11:43 AM   #68
supertorro
Oddometer: 23
so in simple terms
So in simple terms, troubleshooting a charging problem consists of:
1. Check the stator
Bike not running
1.a Check the three Stator wires in all combinations for resistance. (Currently getting 0.6)
1.b Check the three stator wires for a short by connecting to the stator wire and the engine? (all good here)
Bike started @ idling/3k rpm.
1.c Check the ACV being produced. Anything over 18+ is good (I measure 9.6, 9.6 and 10.6)
2. Check the R/R
Bike not running
2.a Measure battery voltage ....should be around 12.7v (12.4 battery fresh off the charger)
2.b Measure battery voltage ...anything between 13.2 and 14.5 is good. (12.6 - 12.9 @ 4k rpm)
- Lower points to stator problem ?
- Higher points to R/R ?
And then from there you guys kind of lost me. I swear I heard the whistle as it went over my head. Joel mentioned something about testing the insulation resistance with a megger?? Can someone explain what a megger is?
any help appreciated. My scoot died whilst trying to dial in the suspension....Luckily it wasn't raining
So if I consider my diagnosis results, I'm looking at a toasted stator?
supertorro screwed with this post 03-27-2012 at 01:09 PM
supertorro is offline   Reply With Quote
Old 09-11-2012, 06:22 AM   #69
JRWooden
Oddometer: 4,257
Just found these handy charging system guides on the Electro-Sport site, so thought I would post them:
http://www.electrosport.com/media/pd...ng-diagram.pdf
http://www.electrosport.com/technica...g-system-works
http://www.electrosport.com/technica...ting-guide.pdf
Old 09-26-2012, 07:01 AM   #70
ebrabaek
Oddometer: 4,745
Originally Posted by =o&o> View Post
Met a friend last Saturday to ride and take pictures of the fall colors... but her 2009 F658GS wouldn't start. Jump started it, got it to my house, checked the stator output and got 7.2 to 7.6 volts on all three legs.
Then, just to compare, I checked my 2009 F800GS, and got 13.4 on one leg and 9.6 volts on the other two . My stator was replaced under warranty exactly ONE year (and 8K miles) ago
So now I have two new stators coming from Rick's Motorsport Electrics.
You might want to consider an aftermarket R/R. There are two out there that have been running with good results.
Erling
Old 09-26-2012, 02:47 PM   #71
JRWooden
Oddometer: 4,257
My understanding is that any BMW part has a two year warranty on it from time of installation,
that being the case you might want to re-assemble with the bad factory stator and have BMW give you the new upgraded kit with ventilated flywheel at no charge....
Old 09-26-2012, 06:29 PM   #72
kelsow
kelsow's Avatar
Oddometer: 1,118
Question.
So I was in the middle of nowhere on Sunday when I went to start the bike and it turned over s l o w l y but started.
I headed home to my garage, stopped the bike and it would not restart.
Did a bit of research and decided it was prolly the battery.
Replaced it with a Deka, started right up.
Started doing a bit more research and poked around with a volt meter.
I'm not well versed but followed the instructions from here, http://www.advrider.com/forums/showp...77&postcount=5
Anywho, here is what I found,
Fully charged battery was 13.0 dropping to a steady 12.78 with key off.
At idle it's 12.72
3000rpm 13.3
4000rpm 13.6
5000rpm 13.6
14.3v would be good, right?
I also checked the resistance at the 3 pronged connection.
I got 0Ω across all connections, 1-2-3 Is this bad or good?
For AC volts (with 3 prong connected)
At idle I got:
1-2 10v (after cleaning and dielectric grease)11.3
2-3 9v (after cleaning and dielectric grease)10.3
1-3 12v (after cleaning and dielectric grease)12.6
At 3000rpm I got:
1-2 10v (after cleaning and dielectric grease)10.9
2-3 11v (after cleaning and dielectric grease)11.5
1-3 14v (after cleaning and dielectric grease)14.6
I'm not sure if this is operator error or the tester I'm using.
Thoughts?
"Kelsow's helmet is so tight, it cuts off the circulation to his personality."
Ride: 2010 BMW F800GS
Site: dualsport.ca and rideatlantic.ca
kelsow is offline   Reply With Quote
Old 09-26-2012, 07:41 PM   #73
ebrabaek
Oddometer: 4,745
Originally Posted by kelsow View Post
Question.
At idle it's 12.72
3000rpm 13.3
4000rpm 13.6
5000rpm 13.6
At idle I got:
At 3000rpm I got:
Thoughts?
You should see 50-70 vac ...... If you intact only have 10-14 vac..... Then your stator is toast.
One more test... One at a time take each of the ac phases ohm it to ground..... All three wires should be open....ie no continuity. Any other ...... You have a short.
Sounds like a bad stator.
Erling
Old 09-26-2012, 08:31 PM   #74
=o&o>
I like to ==o&o>
Oddometer: 120
Originally Posted by ebrabaek View Post
You should see 50-70 vac ...... If you intact only have 10-14 vac..... Then your stator is toast....
Just to clarify: Is it correct that the 50-70 volts AC would only be if the stator is unplugged from the Rectifier/Regulator, but the readings should be around 13vac if still plugged into the R/R?
=o&o> is offline   Reply With Quote
Old 09-27-2012, 08:14 AM   #75
baloneyskin daddy
bikaholic
Oddometer: 2,141
Theres no way you have 13.6 dc at the battery with the ac results at the stator that you report. You have the tester at the wrong setting or something else.
baloneyskin daddy is offline   Reply With Quote
Times are GMT -7.   It's 01:32 AM.
