Closed Thread
Old 10-06-2011, 02:08 PM   #91
tofire409
Geared up and ready.
tofire409's Avatar
Oddometer: 654
Hi HighTechCoonass,
Does the booster plug alter the temperature reading on the dash (computer)?
Damn I wish all roads were dirt.
2011 White F800GS, 30,000 km's
Toronto to Maine and back, Toronto to Boston -The Long way, To the Dragon, 2days TCAT
tofire409 is offline
Old 10-07-2011, 06:32 AM   #92
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,476
No sir.... The dash temperature is controlled by the sensor under the headlight.
Originally Posted by tofire409 View Post
Hi HighTechCoonass,
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is online now
Old 10-10-2011, 07:52 AM   #93
seaswood
seaswood
seaswood's Avatar
Oddometer: 170
Power
Have run mine around different roads yet to try sand, appears to work as bike should except when I am expecting bike to stumble, it does not. Did die once but not as was before whenever lowering throttle there was an issue. Assuming this should be removed for dealer service. And the cable with switch had to loop around it was quite long, maybe give an option of long to pre drill somewhere, shorter to keep under cover.
1200GSA /7/5
seaswood is offline
Old 10-10-2011, 10:31 PM   #94
eddyturn
Wannabe
Oddometer: 1,903
Me finally install. Me likey. Thanks HTCA! Mine did not come with some motherboard but just figured it was now in the big radar looking clump.
All things being equal... fat people use more soap
eddyturn is offline
Old 10-15-2011, 09:21 AM   #95
HighTechCoonass OP
Oddometer: 2,476
Laugh Power Controller - F800gs / F650gs Snatchy Throttle Fix
The way to calm the beast within is to lower the air box temperature readings to the ECM (engine Control Module)
Results: Smoother Throttle response on the UP and Down Throttle! a 5 minute fix...
If you have any questions post here.... The last thread turn into sales and got moved to vendors.....
There are about 30 bikes out there now running the units.... If you have any question post here.... Glad to be of service...
The term for this is "Resistor Tuning" if you would like to read up on it. There is also the Booster Plug and the Accellerator.... lots of good info......
These work on almost all of the BMW FI bikes... but since the R1200 for example doesent rev up as fast it is not a big of an issue...
Thanks for the support!
HighTechCoonass screwed with this post 10-26-2011 at 02:57 PM
Old 10-15-2011, 01:37 PM   #96
HighTechCoonass OP
Oddometer: 2,476
Laugh
the new units have a longer switch whip.... so you can mount it on the frame or the bars if you like- more options.... i mounted mine on the frame next to the clutch cable mount.... i will post pics....
10 units built today! in stock ready for shippment...
Old 10-15-2011, 07:51 PM   #97
eddyturn
Wannabe
Oddometer: 1,903
I like mine!
eddyturn is offline
Old 10-16-2011, 08:21 AM   #98
GB
Mod Squad
GB's Avatar
Oddometer: 55,995
If I understand correctly, this gadget gives the ECU an ambient temp that's colder than it actually is to enrich fuel to air mixture, correct me if I'm mistaken. How does this gizmo affect fuel consumption (mpg)? And the switch is to turn it on and off?
GB is offline
Old 10-16-2011, 08:35 AM   #99
HighTechCoonass OP
Oddometer: 2,476
Laugh How it works...
How it works....
The ECU uses the air box temperature on a moving throttle state...
steady state throttle the EC uses the O2 sensor to adjust fuel....
the 2 switch position
Blue setting - Shift the air box readings by -38 deg F ( when air temp is below 85)
Red setting - Shift the air box readings by -16 deg F (when air temp is above 85)
Why doesn't BMW do this.... emisions.... the bike run VERY lean to pass emissions testing.
This give the bike a little more flue for UP and DOWN power.... It makes a huge difference.
This will stop the Bucking horse syndrome.....
Old 10-16-2011, 08:37 AM   #100
rockinrog
rockinrog's Avatar
Oddometer: 2,872
I am curious how/if it affects MPG also.
rockinrog is online now
Old 10-16-2011, 12:42 PM   #101
doublegobble
gnat dodger
doublegobble's Avatar
Oddometer: 17
smoooooother....
HTC....
thanks for the mod....well thought out and easy to install. Noticeable improvement and well worth the USD.
-dg
doublegobble is offline
Old 10-17-2011, 05:25 PM   #102
HighTechCoonass OP
Oddometer: 2,476
Laugh
Un-noticiale... Myself and a friend rode Colorado....Me (f800gs 2009) with my Power Commander and a friend (F800GS 2011)without... everytime we filled up and compared - not difference to say one way or the other...
GangPlank plans on doing a dyno test for us soon!!!! Stay tuned!!!
Also thanks again to the 30 customers who purchased thus far!
HighTechCoonass screwed with this post 10-17-2011 at 05:31 PM
Old 10-18-2011, 07:42 AM   #103
Grafspee
one bike is never enough
Oddometer: 207
A happy customer!
Just got back from a long weekend ride in Missouri, and I so much happier with my bike. Your controller makes a huge difference in the rideability of my bike!!! Thanks again for a great product.
Grafspee is offline
Old 10-18-2011, 09:13 AM   #104
toro618
toro618's Avatar
Oddometer: 966
I bought and use the first batch you made...works great. Other than the longer lead, is there any difference between the first batch and the latest? I did read somewhere you waterproffed the oem plugs...any reason?
toro618 is offline
Old 10-18-2011, 03:20 PM   #105
soyanarchisto
soyanarchisto's Avatar
Oddometer: 3,483
How is this product different from what is being offered here:
http://advrider.com/forums/showthread.php?t=667661
soyanarchisto is offline
Closed Thread
Times are GMT -7.   It's 07:20 PM.
