Old 10-14-2011, 05:05 AM   #121
Dieselboy OP
Journey not Destination
Dieselboy's Avatar
Oddometer: 1,122
Originally Posted by JRWooden View Post
I found what I was looking for ... Joel's comment on the noise:
http://www.advrider.com/forums/showp...8&postcount=19
Again, good post. So initial rattle no major issue (as I always believed prior to this thread.) But now mine does not rattle at all-- even better.
For the record my left cover was tightened per the book (both sequence and torque) and that is what I show in the pics.
Dieselboy
The Adventure Continues
Dieselboy screwed with this post 10-14-2011 at 06:56 AM
Dieselboy is offline   Reply With Quote
Old 10-14-2011, 06:04 AM   #122
JRWooden
Oddometer: 4,231
I'm not sure when mine started ... it did NOT do it when it was brand new, but only started sometime later....
It does only do it on a cold start for 1-3 seconds.....
DB: Did you replace your tensioner assembly during this rodeo?
Old 10-14-2011, 06:49 AM   #123
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,122
Tensioner was replaced two weeks prior to this surgery. And it will get replaced in 25000 miles regardless.
Dieselboy
Dieselboy screwed with this post 10-14-2011 at 06:57 AM
Old 10-14-2011, 09:18 AM   #124
JRWooden
Oddometer: 4,231
Seems like cheap insurance ... esp. after seeing the "photo shoot"
Old 10-14-2011, 10:04 AM   #125
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,393
You should do a photo DIY for replacing the tensioner.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 10-14-2011, 10:35 AM   #126
Dansrc51
I need a cape....
Dansrc51's Avatar
Oddometer: 1,511
+1
Dansrc51 is offline   Reply With Quote
Old 10-17-2011, 05:58 PM   #127
zaner32
In over my head
zaner32's Avatar
Oddometer: 648
Great job. I'll have to print it and keep for reference.
The dealer changed the tensioner as the bike was rattling considerably until it warmed up. At startup it would rattle a bit, and get quiet. After that, it would cycle every second or so rattling, quiet, rattling, quiet. and so on until warmed up. They said the tensioner was 'bleeding' too much oil? I haven't had a chance to ride it too much since I got it back. Having fun with the DR350 on the greasy trails
97 DR350SE
09 F800GS
"When nothing goes right, go left!
zaner32 is online now   Reply With Quote
Old 10-19-2011, 07:02 PM   #128
Rafiki
Some Dude
Rafiki's Avatar
Oddometer: 1,846
First off,Excellent job !!
Second,on the coolant bleeding issue;if you have an old radiator cap,you could drill a hole in the top of it,attatch and seal a "nipple"(something to attatch a vacuum hose to) then attatch a hose and vacuum pump to it.
once you fill it,put it under vacuum-this should draw all the ait bubbles to the radiator cap.
Rinse/repeat till it stays full after vacuum.
'94 XR650L ΜΟΛΩΝ ΛΑΒΕ
"Monkey killing Monkey over pieces of ground.
Silly monkeys give them thumbs.
They make a club, And beat their brother down."
Rafiki is offline   Reply With Quote
Old 10-19-2011, 09:23 PM   #129
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,122
Originally Posted by Indy Unlimited View Post
Great Job DieselBoy !!!
Did you determine how much the stock chain stretched over the new chain?
No measurement made. I didn't think I could get an accurate measurement without investing more time than I was willing to invest.
Dieselboy
Old 10-21-2011, 04:32 PM   #130
rritterson
Oddometer: 207
Fantastic write up!
Side question: for rivet-type master links, can't one simply grind the rivet heads off, install the chain, then reuse the existing plates from the disassembled link and just replace the pins?
rritterson is offline   Reply With Quote
Old 01-29-2012, 04:33 AM   #131
chadams
Oddometer: 209
Originally Posted by rritterson View Post
Fantastic write up!
replacing on a hy vo chain ....
http://home.earthlink.net/~wrenchtwister/camtool.pdf
some chain specs
http://www.reginachain.it/eng/produc...da_morse.shtml
Current ride:- 2002 KLX400R
Previous rides:-09 f800gs, 05 z750, 81 z1000j, 84 gpz1100, 98 dr250, 99 dr250, 96 dr350, 93 rf900, 93 nx650, 98 xtz660, 97 dt200r
chadams screwed with this post 01-29-2012 at 05:36 AM
chadams is offline   Reply With Quote
Old 02-08-2012, 10:48 PM   #132
mischief
misadventurer
mischief's Avatar
Oddometer: 515
Why do we need master links?
Is there any reason to replace more than one pin? Pushing one pin out will break the chain, attach it to the old one and pull it around then replace the pin. I wouldn't think it would be that hard even if someone had to custom machine new pins
Originally Posted by Bayner View Post
Dieselboy, I'm looking through specs but I need to also know the width of the chain -the measurement of the thickness of the stack of side plates the pins are holding together. And just to confirm those pins are round, rather than an oblong or noticeably triangular shape, right?
Or if you're bored, you can snoop through here:
http://www.tayloredge.com/reference/...ilentChain.pdf
http://chain-guide.com/toc.html
"I have this moment and no idea when it will end" - Andrea Gibson
"The adventure begins when the plan turns to shit." I don't know who said that first but I like it 'cause my plan turned to shit a long time ago
mischief is offline   Reply With Quote
Old 02-09-2012, 09:38 PM   #133
chadams
Oddometer: 209
How many links are there in the f800gs timing chain? Thanks
Old 02-10-2012, 03:48 AM   #134
chadams
Oddometer: 209
f800gs part number.... finally found one 98XRH2015
Now where to but one with a master link
http://www.orakorbike.sk/!img/upload...rse_retaze.pdf
PS: Why I have so much interest in cam chains at the moment. My f800gs has just under 90,000km, with a very loud cam chain and a broken chain jump guard above the exhaust cam sprocket. I don't wan't to split the case, but I'm yet to find a master link for this chain.
Old 02-10-2012, 04:30 AM   #135
LukasM
Oddometer: 5,384
http://www.orakorbike.sk/!img/upload/file/morse_retaze.pdf
Mate that is an amazing find!!! Morse is a part of the Borg Warner group so this makes perfect sense!!
I did some more searching and found which other bikes use that same chain:
I haven't been able to find a split link for it yet, most OEMs seem to use/sell that chain in an endless configuration.
But it's a big step in the right direction so let's all keep digging!
Times are GMT -7.   It's 07:01 PM.
