10-28-2011, 09:51 AM
#61 | |
Oddometer: 298
Sorry, the springs are not marked, that's the (main) reason that I haven't ordered softer srings. |
10-28-2011, 10:27 AM
#62 | |
airhead or nothing
Oddometer: 7,933
Just read about another ADVR getting custom wound 0.65 springs from this place:
http://www.sonicsprings.com/catalog/
"punkrocks what it's all about" - J. Strummer Quote:
10-28-2011, 10:43 AM
#63 | |
More tacos than you
Oddometer: 5,097
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
10-30-2011, 09:03 PM
#64 | |
More tacos than you
Oddometer: 5,097
65mm upper clamp area 175mm gap 92mm lower clamp area I used a crappy tape measure and judging by anton's avatar, his numbers for the clamping area lengths are probably better than mine, but the gap between the two is obviously MUCH bigger on the 990 I measured - not sure what year - so much so that they probably wouldn't work on an airhead.
10-31-2011, 07:50 AM
#65 |
More tacos than you
Oddometer: 5,097
Does anyone have a KTM dirtbike to pull some measurements off of? Could you measure the center to center of the diameter of the hexagonal brake rotor bolt pattern? I'd like to compare them to the pattern from a 990 adventure which uses dual 300mm floating rotors as stock. The 990 rotors use no lateral offset, so if the rotor bolt pattern is the same, I might be able to use a 990 rotor with dirt model forks.
10-31-2011, 08:26 AM
#66 | |
Oddometer: 298
Straight accross (center to center) 125mm One hole to the next (center to center): 65mm |
10-31-2011, 08:30 AM
#67 | |
More tacos than you
Oddometer: 5,097
EDIT: OK, after a bit more checking it looks like the 950/990 adventure, the 950 super enduro, and the 690 enduro all use the larger 143mm rotor bolt pattern. While the 950/990 adventure use the larger 30mm, the super enduro and 690 enduro use the same 26mm axle as the RFS model. I might have to start with a 690 enduro or 950 superenduro front hub. I'll also need a different caliper holder if not an entirely different caliper. Measurements ripped off of metalgear's website: Measurements (mm) Outside Diameter: 300 Inside Diameter: 124 Bolt Hole CTC Diameter: 143 Bolt Hole Qty: 6 Bolt Hole Size: 6.5 Thickness: 5.0 Minimum Thickness: 4.5 Offset: 0.0 Metalgear makes some nice rotors at pretty reasonable prices too: ![]() $189AU
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. Airhead Wrangler screwed with this post 10-31-2011 at 10:21 AM |
11-02-2011, 06:08 AM
#68 |
Oddometer: 255
KTM 950 SM Conversion
I just finished my bike, rode it yesterday. (88GS} Short story, new cnc offset trees using stock SM forks and radial mount brakes. Shortened KTM stem turned down to fit BMW stock bearings. I used both KTM calipers and the stock KTM brake lines. The brakes are great, not too much as on the SM. I used a 16 mm BMW master cylinder and all my stock switchgear and throttle work fine on the KTM fatbars that are mounted in the stock rubber isolators. The stock springs in the 06 USD seem to be about right for me at 190 pounds.
I'm not too good a posting pictures. I will share if one of you send me an email address. I was inspired by all of these unholy reunion threads and had to take action. Thanks ! |
11-02-2011, 08:28 AM
#69 |
More tacos than you
Oddometer: 5,097
Check your PMs.
11-02-2011, 01:05 PM
#70 |
Oddometer: 1,082
11-03-2011, 09:02 AM
#71 | |
More tacos than you
Oddometer: 5,097
11-03-2011, 10:19 AM
#72 |
Oddometer: 255
Thick Clamps
That is quite the offset. I left the clamps pretty thick, they are strong enough to set a house on. I have done some real hard braking while testing the rig, no issue yet on tire to fender clearance. I made sure the axle location is real close to stock, the geometry seems to be spot on.
11-03-2011, 10:41 AM
#73 |
More tacos than you
Oddometer: 5,097
I bet. Those brakes look like they'd stop you like a brick wall.
11-03-2011, 06:46 PM
#74 |
More tacos than you
Oddometer: 5,097
Are you sure about this measurement? I had a manufacturer of aftermarket KTM hubs tell me that the front rotor bolt diameter on ALL KTMs 125+ is 143mm. He said that 125mm is the diameter of the rear rotor bolt pattern on a lot of the dirt models.
11-04-2011, 12:32 AM
#75 | |
Oddometer: 298
Aaarggh, you are right, it is 143 mm. I have a lot of trashed parts and picked a rear one. Sorry. |
