Old 09-14-2011, 12:07 PM   #46
DrKayak
Retro Rider
Oddometer: 778
Originally Posted by geometrician View Post
slick. I like that.
where you source the Velcro dots you trust so much?
The Velcor dots just keep it from moving around off road. The RAM ball mount is what holds it in place. No issue with it coming loose in 2 years...
WalMart or the like has the self stick velcro.
DrKayak is offline   Reply With Quote
Old 09-14-2011, 12:32 PM   #47
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Originally Posted by scottrnelson View Post
That is part of the TouraTech kit.
What I like about the TouraTech mount for the big KTM is that I can lock my Zumo 550 in place and don't need to worry about taking it with me when I park the bike or about someone stealing it
thanks! give me ideas, the KTM front light bracket & dash mount has so many holes & welded nuts it's a riggers paradise in there
FWIW there have been a few posts over the years RE: people breaking the TT lockable & locked GPS holders off bikes, one in a National Park parking lot with lots of people around. Just saying don't trust it too long or far away from you, I guess. damn thieves anyway
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 11-09-2011, 05:41 AM   #48
Masa
Masa's Avatar
Oddometer: 300
Thanks for the ideas! Here's how I did it.
Got a RAM ball that mounts with a M8 bolt, #RAM-B-367U.
Wanted to use 3mm thick L-shaped aluminum, I knew I had some, but couldn't find it. Took a piece of 80mm x 40mm and cut it to L-shape.
Made a slight bend to match the lines of top console.
Test fitting, marking four holes and drilling. Used couple of bolts with three nuts as spacers between brackets to secure it in place. Drilled small guiding hole through plastic and aluminum bracket. Then 8mm hole to bracket and 11,5mm to plastic. Trimmed bracket to its final size, some filing and sanding to round corners. Put some self vulcanizing tape around the base of RAM ball to hide clear aluminum and give it a snug fit through plastic cover. Also found the piece of L-shaped aluminum I was looking for earlier..
And there it is.
I'll do the wiring later. GPS's battery is good enough for short trips.
Edit:
Got the wiring done. Just soldered the leads together with the heated grips plugins connected to ACC2. Enlarged the hole for RAM mount to get the power plugin through and put a rubber grommet to give it a snug fit.
Masa screwed with this post 01-28-2012 at 05:08 AM Reason: Wiring done
Masa is offline   Reply With Quote
Old 11-10-2011, 01:10 PM   #49
lakecntyrider
lakecntyrider's Avatar
Oddometer: 108
Originally Posted by Masa View Post
Now that's reinforcement -- I just used a piece of flatbar underneath.
Ride Reports:
09 RR: Oregon
10 RR: Glacier National Park
11 RR: Alaska
14 RR: Rockies
lakecntyrider is offline   Reply With Quote
Old 11-10-2011, 02:47 PM   #50
bigkuri
bigkuri's Avatar
Oddometer: 741
Yee gods, that is one meaty bracket!!! I used 2mm aluminium, and thought that was overkill!...
PS - great job, but your nylock nuts are not locked - too short bolts.
Current Bikes: 2006 Honda XR650R & 2007 KTM 950 SMR
bigkuri is offline   Reply With Quote
Old 11-10-2011, 03:52 PM   #51
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,615
Just buy a Yoke Mount - $10
Add some braces under the bracket and voila!
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift!
Member of the Maryland OHV Alliance
2014 Yamaha FZ-09 Adventure
Kyler is offline   Reply With Quote
Old 11-10-2011, 07:13 PM   #52
godzuki
Oddometer: 316
i have the ball mount to the top of the dash, it came that way when i bought the bike.
godzuki is offline   Reply With Quote
Old 11-10-2011, 08:29 PM   #53
GSMark
Just Love Bikes
GSMark's Avatar
Oddometer: 875
KTM 990 Adventure Home made Garmin GPS Mount
http://www.advrider.com/forums/showthread.php?t=682941
AMA Earned Life Member Iron Butt Association Member
suttoncycleworks.com
Honda XR650L XR600 NX650 Oil Cooler Kit
KTM 990 Adventure Honda CRF450 Supermoto H-D Sportster Streettracker Honda XR650L
GSMark is offline   Reply With Quote
Old 11-10-2011, 09:31 PM   #54
MrLebowski
MrLebowski's Avatar
Oddometer: 158
The Cheap Option
Here is my gps mount. Cost, $10 for the ram-mount cradle, piece of scrap aluminum and a couple bolts.
MrLebowski is offline   Reply With Quote
Old 11-10-2011, 09:36 PM   #55
Yascher
Yascher's Avatar
Oddometer: 388
Originally Posted by GSMark View Post
no no no, this one is only attached to a plastic and way too far out, giving a lot of leverage to have this heavy GPS bounce around....even touratech one is secured to the subframe of instr cluster and it doesn't position GPS way out soo much....and even then I had to seriously modify it to make it stable from bouncing with steady readings
Yascher screwed with this post 11-10-2011 at 09:41 PM
Yascher is offline   Reply With Quote
Old 11-10-2011, 09:40 PM   #56
MrLebowski
MrLebowski's Avatar
Oddometer: 158
And how it looks on the bike... like most of the other ones I suppose. I have to admit the whole thing adds up to just enough vibration that when on a dirt road I have to put my hand on it to steady it so I can see my tracks. Of coarse seeing the tracks isn't easy with this model gps anyway.
Old 11-11-2011, 12:56 AM   #57
Masa
Masa's Avatar
Oddometer: 300
Originally Posted by bigkuri View Post
..but your nylock nuts are not locked - too short bolts.
I know. Already picked those and it would have been too long journey (about 8 meters) back to the nut box to pick regulars or longer bolts, so didn't bother.. Don't think it's going anywhere.
Wow! That's a beautiful mount you got there GSMark. Hope I had the patience - and skills..
Old 11-11-2011, 08:20 PM   #58
GSMark
Just Love Bikes
GSMark's Avatar
Oddometer: 875
Geee!
All that hard work and it doesn't work.
All of these miles and I thought it was working just fine. I am so stupit...
Thanks for telling me.
Old 11-12-2011, 05:01 AM   #59
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,615
Old 11-12-2011, 05:15 AM   #60
KaytM
Just a fella.
KaytM's Avatar
Oddometer: 202
Touratech damped lockable mount!
A great bit of kit.
2006.5 990 ADVENTURE.
KaytM is offline   Reply With Quote
Times are GMT -7.   It's 11:30 PM.
