Old 05-09-2011, 12:10 PM   #1
GTC OP
GTC's Avatar
Oddometer: 281
R100GS rear spring rate
I have looked all over and have not been able to find a shock spring rate calculator for an R100GS. I really like the ride of the stock shock and want to get close to the same spring rate on the next one I get. I am looking at a YSS shock that is set up for 165 pounds but have not been able to compare the spring rates because I can't seem to find the information. Please Help!
Thanks George
1998 KLR650 (Road Warrior)
1997 XR 400 Sadly For Sale
2002 WR 426
GTC is offline   Reply With Quote
Old 11-17-2011, 11:22 AM   #2
etj
etj's Avatar
Oddometer: 28
Bruno of Bruno's Machine & Repair in Canada (who rebuilds R100GS shocks) tells me the stock rate is 7.5kg per mm which is around 420 lbs/in. Using published formulas and running the numbers, I calculate right about that too.
I recently replaced my stock spring with a 600lb spring.
etj is offline   Reply With Quote
Old 11-17-2011, 09:38 PM   #3
R100RT Mark
Oddometer: 303
Interested to know why you went with a 600lb spring and how the performance differs from stock? Thanks. Mark
R100RT Mark is offline   Reply With Quote
Old 11-17-2011, 09:46 PM   #4
etj
etj's Avatar
Oddometer: 28
I'm over 200lbs these days, and I have my 135lb wife on the back 75% of the time, and the stock spring was light to begin with. She and I together would bottom out a lot. Bruno suggested the 600lb and said he'd ridden that setup a lot himself. I bought the spring from him. He also provided a short spacer since the new spring is about 1/4 shorter than the one it replaces.
I've only got a few miles on the new setup, all in the rain, so I've not done extensive testing yet. So far I like it. I need to get out for a few hundred miles and really thrash on it.
Old 11-18-2011, 07:26 PM   #5
R100RT Mark
Oddometer: 303
Thanks for the added info. I'm 155 lbs and run solo, so we are coming at the spring rate from different angles. Mark
Times are GMT -7.   It's 09:11 PM.
