Old 11-29-2011, 06:41 PM   #91
BMW_BIKER_KEITH
BMW_BIKER_KEITH's Avatar
Oddometer: 395
There was no real definitive anwser other than the Stator wiring is suspect. The author noted that a call to BMW for parts yielded a cost of over $900 large as it was a complete charging system... but all that is needed is a Stator.
The good news is that he found a Stator only at Ricks Motorsports Electrics for $165 !!!
http://www.ricksmotorsportelectrics.com/
Hope this helps!
2010 Lava F800GS...AKA "Dirty Harry"
1998 R1200C Classic Black...AKA "Dick The Cruiser"
BMW_BIKER_KEITH screwed with this post 11-29-2011 at 06:47 PM
BMW_BIKER_KEITH is offline   Reply With Quote
Old 11-29-2011, 08:02 PM   #92
motoman59
motoman59's Avatar
Oddometer: 40
That part from Ricks is available from Parts Unlimited too. Same price. Read the article and agree, nothing not discussed here.
Not sure where the $900 comes from. There may be some parts you need besides the two mentioned. Both the gasket for the cover and the generator comes to just under $800. The warranty from BMW is 2 years. Not sure about the Ricks warranty. Probably at least 1 year. I would bet that the stator will be available soon from BMW as a single part.
Part NumberDescriptionlbQtyEachTotal
11147670688GASKET RIGHT0.01
12317690427GENERATOR10.24
Total Weight:lbsub Total:
Total $793.66
motoman59 is offline   Reply With Quote
Old 11-30-2011, 03:31 PM   #93
JRWooden
Oddometer: 4,259
Originally Posted by motoman59 View Post
... Not sure where the $900 comes from.
I'm pretty sure that included in the $900 price you get a new flywheel that you don't need
Somewhere recently it was rumored that BMW would start selling the stator separately in the near future....
Old 12-01-2011, 10:44 AM   #94
LukasM
Oddometer: 5,425
Yeah in post #67 of this thread...
Old 12-01-2011, 03:56 PM   #95
TheCowboy
back in the saddle again
TheCowboy's Avatar
Oddometer: 606
I am not an engineer, just a dumb shade tree mechanic who looks at stuff without counting the binary numbers. When I pulled my dead stator at 50,000 miles all the windings were black and it smelled like fried electrics. I had it re-wound... and that didn't work (bad winding job or somthing). Bought Ricks stator and am using it now. Look at the placement of the exhaust tubes.... too damn close to the alternator for my taste. You know that exhaust tube gets MIGHTY damn hot.... tell me it does not effect the alternator. I suggested heat wrap on the exhaust around the alternator area - but have been too busy to try it.... it might be a simple fix.
TheCowboy
TheCowboy is offline   Reply With Quote
Old 12-01-2011, 06:02 PM   #96
BMW_BIKER_KEITH
Oddometer: 395
Damn good idea Cowboy... damn good observation.
Old 12-01-2011, 07:33 PM   #97
JRWooden
Oddometer: 4,259
It sure as hell can't hurt ....
I was in O'Reilly auto parts the other day and they had the stuff hanging on the shelf ...
I think I'll go back and get some...
It looks like it will require removing the headers to do the wrapping....
We'll need a pair of new gaskets P/N: 18217672804 to go between the pipes and the cylinder head?
Old 12-01-2011, 09:21 PM   #98
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
If I was going to go that far I'd get mine jet-hot coated.
http://www.jet-hot.com/coatings/
Reduces heat, looks good & comes in various colors. Looks better than a wrapping.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 12-01-2011, 09:48 PM   #99
flying.moto
Earthbound Misfit, I
flying.moto's Avatar
Oddometer: 221
Jet hot sounds like a good idea. I had been wrapping my header pipe on the dirtbike and it's been great! No burned leg/pants when i get pinned to it. BUT it clogs up with mud too easy and the mud soaks right through, not to mention moisture/water. Some said it will breed corrosion. At the end of it all i took it off and learned to ride better. It may be a solution for those who don't venture in a lot of mud/water... But then, caked on mud... Bad idea or just bad looks+weight?
flying.moto is offline   Reply With Quote
Old 12-04-2011, 07:55 PM   #100
motoman59
motoman59's Avatar
Oddometer: 40
What about a simple exhaust pipe heat shield of SS on the upper (closer) pipe to deflect the heat away from the cover. Won't absorb water like the wraps. Besides, there is not enough room to wrap only the upper pipe. You would have to wrap both. The distance between the pipes is not large enough to get the wrap between.
A Ti cover would look good but CF would disipate heat better.
Old 12-04-2011, 08:26 PM   #101
ebrabaek
Oddometer: 4,758
Carbon fiber would be a great isolator..... But we would need some input from the know how's...... That this would in fact work..... Before making a shield.......
Erling
Old 12-07-2011, 07:37 PM   #102
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
Originally Posted by Gangplank View Post
If I was going to go that far I'd get mine jet-hot coated. Reduces heat...
But how can a thin coating reduce heat radiance? I'm no engineer.
Fred
FredRydr is offline   Reply With Quote
Old 12-12-2011, 03:55 PM   #103
JRWooden
Oddometer: 4,259
I wonder if a layer or two of this stuck to the bottom part of the stator side cover would be worthwhile:
http://www.thermotec.com/products/14...mo-shield.html
Note that this particular product is NOT meant for wrapping exhaust pipes!
But this company does sell that stuff as well....
Old 12-12-2011, 04:25 PM   #104
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Fred
Here ya go - article about plasma sprayed ceramic coatings: http://www.gizmag.com/spray-on-ceram...eratures/6642/
"One motorcycle racing team that employed the system used a laser-guided thermometer and found that while the exhaust can have an internal temperature of around 150 degrees Centigrade, the outside temperate can be low enough for the exhaust pipe to be removed WITHOUT using gloves."
"Lower temperatures also increase the durability and effectiveness of engine and transmission oils, improve engine cooling and help to protect ancillaries such as starters, regulators, wiring and modern alarm and ignition systems from the degrading affects of excessive heat."
Starting to think about doing this.
Old 12-12-2011, 06:52 PM   #105
Hucker
Lost
Oddometer: 690
Me too...
Hucker is offline   Reply With Quote
Times are GMT -7.   It's 06:24 AM.
