Closed Thread
Old 11-29-2011, 02:12 PM   #1891
frogy
frogy's Avatar
Oddometer: 869
Faaget the cool,it sounds like I might get the "Air" before winter sets in
frogy is offline
Old 11-29-2011, 02:50 PM   #1892
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,752
ghost. I regret to inform you that the cool will not be available in your Texas county due to import restrictions. Some sort of Homeland Security issue. In other news, it will be rolled out by counties, beginning with those counties starting with "Mc" first in honor of Scrooge McDuck and Ewan McGregor.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline
Old 11-29-2011, 03:41 PM   #1893
Plane Dr
Plane Dr's Avatar
Oddometer: 888
I thought it was starting at the OK border and working south......
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline
Old 11-29-2011, 06:30 PM   #1894
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Thanks for your orders everyone!
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 11-29-2011, 07:19 PM   #1895
KSBEERHUNTER
Oddometer: 354
IICE air and IICE ice
Howdy,
I have a 01 1150gs and was interested in your IICE AIR but then I see you are
getting ready to produce a product called IICE COOL. What is the difference?
Does the IICE COOL product require the IICE AIR, or first product to work? Or
are they two different products? I assume that they are both products to
enrichen the fuel mixture? I was thinking that your second product may be an
improved version of the first product. Please explain what the intended usages
are please. I don't want to miss out on the IICE AIR product if I need it but
don't want to purchase it if your second IICE COOL product is a new and improved
model..
KSBEERHUNTER is offline
Old 11-29-2011, 07:26 PM   #1896
Plane Dr
Plane Dr's Avatar
Oddometer: 888
Originally Posted by KSBEERHUNTER View Post
Howdy,
model..
To keep poolside working.... Air is based off the intake air temp and adjust mixture when the throttle transitions. Cool is going to use the oil temp to adjust the mixture in other throttle and engine transitions (it's late) so they basically need to work together. If I recall neither should effect steady state running when the O2 sensor kicks in.
Head to the first post. lots of reading.....
86 RG500WW (gone)
Plane Dr is offline
Old 11-29-2011, 07:37 PM   #1897
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,142
Howdy,
model..
What he said…↑
The IICE Air and IICE Cool are 2 separate products that work together to help the engine respond with more authority when you twist the throttle.
The IICE Cool requires the IICE Air to function properly.
The IICE Air FINAL SALE is still active so you can order one now. Once the FINAL SALE concludes then IICE Air's will no longer be available to order as the production shifts to making IICE Cools.
The 1st post of this thread has a link to the IICE Air vendors thread where you can order an IICE Air.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen screwed with this post 11-30-2011 at 11:39 AM
johnjen is offline
Old 11-29-2011, 08:28 PM   #1898
Ridestrong
Oddometer: 157
Business or project?
So, as I am anxiously anticipating the arrival of the IICE Air I ordered a few days ago I started to read through the thread and, it appears that the Air and, after that, the Cool are going to be limited production runs for which there will be no more made at a later time. Is this just a "project" run or do you intend to make a "small" business out of this? It looks as if the product has garnered a lot of attention and accolades already and you could probably do well with continued production of these and any future products you might engineer and design.
Ridestrong is offline
Old 11-29-2011, 10:28 PM   #1899
hilld
riding isn't an addiction
hilld's Avatar
Oddometer: 268
Maybe I missed it, but did the last order ever ship as I still haven't received anything. The list was posted about 10 days or so ago and my initials were on it.
Just wondering.
D.
Every day is a new day
hilld is offline
Old 11-29-2011, 11:28 PM   #1900
gratefulJED
long strange tripper
gratefulJED's Avatar
Oddometer: 1,894
I know of LIFO & FIFO, but FILO?
I ain't jellin'
in fact I thought of sellin'
when JJ started yellin'
but now that PS calmed by tellin'
me my name came up I'm mellin'
or something
"The liberties of a people never were, nor ever will be, secure when the transactions of their rulers may be concealed from them." - Patrick Henry
gratefulJED is offline
Old 11-30-2011, 05:15 AM   #1901
frogy
frogy's Avatar
Oddometer: 869
frogy is offline
Old 11-30-2011, 07:41 AM   #1902
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,954
You've met Engineering, you've heard from Marketing...
Sounds like a question for Management.
Splitting lanes, and splitting hairs.
Andrew is offline
Old 11-30-2011, 07:51 AM   #1903
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Ahhh... Well...  I think we're operating without any adult supervision.
Poolside is offline
Old 11-30-2011, 10:58 AM   #1904
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Howdy,
I have a 01 1150gs and was interested in your IICE AIR but then I see you are getting ready to produce a product called IICE COOL. What is the difference?
Does the IICE COOL product require the IICE AIR, or first product to work? Or are they two different products? I assume that they are both products to enrichen the fuel mixture? I was thinking that your second product may be an improved version of the first product.
Please explain what the intended usages are please. I don't want to miss out on the IICE AIR product if I need it but don't want to purchase it if your second IICE COOL product is a new and improved model..
Others have answered this above, thanks guys. Yes, the IICE Air and IICE Cool are two different things. And they work together.
If you are interested, here's a little more technical detail about what's going on inside the ECU. And what parts are affected by the IICE Air and IICE Cool
When you crack the throttle (aka: throttle tip-in) and accelerate at a constant rate, two unrelated things happen. Not at the same time, but one after the other. The IICE Cool modifies the ECU control of throttle tip-in, and the IICE Air modifies constant rate acceleration.
Fueling for motor acceleration is a one-two sequence. First, the rider advances the throttle, then second, the motor accelerates. They are two separate events, and the ECU controls them separately. An ECU controls the two events separately because the fueling requirements for 1. throttle tip-in, and 2. acceleration, are unrelated. The control algorithms to manage those events are also unrelated.
Throttle tip-in is a destabilizing event in the intake port, and requires a very complex control routine. Throttle tip-in and its opposite, throttle tip-out, upset the equilibrium of injected fuel vs. vaporizing fuel. In this case equilibrium means that the rate of injected fuel is equal to the fuel vaporization rate. A state of equilibrium is present in the intake port during steady speed and during constant acceleration. But when the throttle is moved, it upsets that equilibrium.
If you would like to read more about it, here is a relatively simple paper on the topic, Transient Fuel Control. If you take a look at figure 11, it sort of summarizes the operation. Any type of Transient Fuel control algorithm is designed to maintain a relatively constant fuel mixture during throttle transitions of tip-in and tip-out. Maintaining a constant fuel mixture during throttle transitions is a complex process based on the fuel vaporization rate, which is based on a host of dynamic variables such as Manifold Absolute Pressure and Intake Port Velocity, which are outlined in the paper.
Ok, so that was Transient Fueling in a nutshell. The control of fueling during Constant Acceleration is an altogether different thing. The control algorithm for that is simple by comparison. It's a simple air mass calculation based on air temperature and local barometric pressure. That's it. See, I told you it was simple.
The IICE Air has a simple job in modifying the ECU control of constant acceleration. The IICE Cool has a dynamic and variable task and requires a microcontroller.
Poolside screwed with this post 08-17-2012 at 12:43 PM
Poolside is offline
Old 11-30-2011, 11:43 AM   #1905
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
The batch is going out in just a little while.
Poolside is offline
Closed Thread
Times are GMT -7.   It's 05:49 AM.
