Old 12-03-2011, 10:18 PM   #61
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,178
Originally Posted by Matticus91 View Post
Has anyone had any electrical problems? I heard a few people say they had an issue with the starter cable melting to the exhaust and also leaking fork seals. Yikes!
Thanks for asking.
My bike died today on a trail. I had taken the horn off and the horn connector got loose and shorted on the frame, blowing the main fuse. Fortunately there was a spare mounted next to it. Interestingly, with the fuse blown the bike would run and could be bump started; but I couldn't kick start it (or e-start it, obviously). The idle speed seemed a little low and irregular, though.
Apparently the positive cable for the battery can chafe through where it's held by the frame bracket. I re-routed mine around the bracket. As a bonus, now the battery is even easier to remove. I'll check the e-start cable routing, thanks for the tip.
Also, new sprockets are on order. 12/57. Yeeeeaaaaahhhh.
Luke is offline   Reply With Quote
Old 12-04-2011, 07:43 AM   #62
Matticus91
Matticus91's Avatar
Oddometer: 272
Thanks for sharing man I'll have to check mine out as well. Enjoy the new mods!
"Husky" 2011 Husqvarna TE250
2012 Kawasaki Ninja 650R
Matticus91 is offline   Reply With Quote
Old 12-04-2011, 07:02 PM   #63
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,803
where did you order your sprockets from ?
im running a 13 / 52T and its still not low enough for me.
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 12-05-2011, 12:40 AM   #64
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,178
http://pbisprockets.com/
They've got everything from 38 to 61 teeth rear on the on-line store, and they may be able to make bigger ones.
Old 12-05-2011, 10:13 AM   #65
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 2,552
Wow. That combo will be beastly in tight trails, but will probably give you a top speed of about 35mph
Sort of O/T, but I've heard of more than one TE dying a premature death from a combination of highway speeds and not keeping the oil fresh. With only a quart in there, the oil shears out of viscosity rather quickly. Better keep that oil clean if you have to connect trails or spend any time at cruising speeds.
TaterHarry is offline   Reply With Quote
Old 12-05-2011, 06:49 PM   #66
swamp
swamp's Avatar
Oddometer: 1,803
i just ordered a 12T front from supersprox
its worth mentioning that the 2012s come with supersprox sprockets from the factory .. which is pretty cool.
also, ive been running cycra probend bark busters on my other bikes. but for this new husqy my old mounts wouldnt fit the stock bars.
the mounts that need to be ordered from cycra is called the "magura" (or something like that) mount.
hope this saves someone a return trip to the parts store
Enduro Earth
YOUTUBE
Old 12-07-2011, 01:08 PM   #67
dmaxmike
former quadtard.
dmaxmike's Avatar
Oddometer: 803
i was on the KTM site trying to decide which new bike i can't afford and can't touch on and for some reason i decided to go to the husky site and all my dreams came true! $7,500 and i can touch!
swamp please give us a ride report of the 2012 i must know how it rides and runs ect ect!!
I don't know how to ride a bike...yet
CRF250X
dmaxmike is offline   Reply With Quote
Old 12-07-2011, 01:37 PM   #68
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,783
Hey Monte, I thought the TE250 shared the bottom end with the bigger TEs, mine holds the spec below, which is actually a spec I found for a 2009 TE250:
Oil Capacity Transmission: 1.8 qt. (1.7 l)
http://www.ccbmw.com/new_vehicle_detail.asp?veh=128276
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 12-07-2011, 01:43 PM   #69
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 2,552
Earlier models, you are correct, but 2010 and newer models with the X-Lite engine have a 0.9L (0.95 Quart) capacity.
Old 12-07-2011, 02:22 PM   #70
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,783
..... but 2010 and newer models with the X-Lite engine have a 0.9L (0.95 Quart) capacity.
Dang, that skinny Italian mistress is skinnier than I thought....
Old 12-07-2011, 04:44 PM   #71
Milosh
Milosh's Avatar
Oddometer: 116
Any way to make this bike a bit more streetable or am I looking at a WR250R?
Milosh is offline   Reply With Quote
Old 12-07-2011, 05:20 PM   #72
Matticus91
Matticus91's Avatar
Oddometer: 272
How streetable?
Old 12-07-2011, 06:37 PM   #73
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 2,552
Not really.. if you plan on any extended slab, you should go the WR250R route, I almost did myself. You can make the gearing taller, say 14/48, so it's not totally wrung out at 55MPH, but you'll lose a lot of low end grunt. It's not a dual sport in any sense except for the license plate.
I read rumors on Cafe Husky of a taller 6th gear coming out in the hard parts catalog if it comes true, and I already have a reason to split the cases (which I hope doesn't happen for a long time), I'll probably go that route.
Old 12-08-2011, 03:02 PM   #74
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,178
New sprockets came in. Who wants to climb some hills?
Unfortunately the front sprocket doesn't fit. It's for the pre- xlite motors. The rear sprocket fit (after cutting a bit off the chain guard and adding a few links to the chain) and it looks mean.
Hmmmm. Maybe I should do something about the chain guide.
Old 12-08-2011, 03:07 PM   #75
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 2,552
It looks like you could just fab up a small piece of aluminum or steel to lower the rear mount a bit, and just pivot it down at the front.
Times are GMT -7.   It's 04:47 AM.
