Old 04-06-2011, 03:47 PM   #16
Damifino
Damn if I know
Damifino's Avatar
Oddometer: 680
So how is the Ohlins? I have a new to me 86 R80RT, the rear shock is as squishy as Kirstie Alley's backside.
I can get a Progressive shock for $367 or an Ohlins for $845, is the Ohlins worth that much more?
Let me hear it!
07 KTM 950 SE
99 KDX200
79 Yamaha RD400 76 BMW R76/6
06 Vespa Granturismo 200L
Green Marble Enduro Riders http://gmer.us
Damifino is offline   Reply With Quote
Old 04-06-2011, 03:54 PM   #17
jdiaz OP
Oddometer: 32,326
Check the Dan Kyle ohlins group buy in Vendors.
jdiaz is online now   Reply With Quote
Old 04-07-2011, 02:32 PM   #18
Damifino
Damn if I know
Damifino's Avatar
Oddometer: 680
Ok, can get it cheaper through him, but again, is the Ohlins that much better than the Progressive?
Thanks for the group buy tip!
07 KTM 950 SE
99 KDX200
Old 04-07-2011, 02:38 PM   #19
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,112
The Ohlins is really that much better than the Progressive. Progressive's are (IMHO) cheao junk that owners love when replacing clapped-out stockers.. but cheap junk in the end (sorry Prog. owners).
I've had stock, Works and then finally Ohlins on my last two bikes... the Ohlins are really that good.
Now if you are someone who doesn't like to mess around with stock settings (bgoodsoil for example ) you can easily tune the shock to have a horrible ride.. that said you can tune it right back to great ride as well.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 04-07-2011, 06:38 PM   #20
2xdisco
Oddometer: 277
what solo said,
the ohlins is very good. adjustment is key to a fantastic precision delivery. there are other good one's hagon, wilber, WP, works. IMHO progressive is ok. Ohlins is best.
BMW R80 G/S P
09 ktm 530exc r. 06 drz400s(hers)
2xdisco is offline   Reply With Quote
Old 04-07-2011, 10:15 PM   #21
supershaft
because I can
Oddometer: 9,116
Does anybody run Penske's? I guess they make shocks for our bikes. I doubt if they make one for Mono's? I have checked them out on a couple of friends race bikes and I thought they separated the adjustments like no other shock I had ever messed with. It's been a while and I have only been close up messing with one once but . . . . I see them on a lot of race bikes.
Old 04-08-2011, 04:25 AM   #22
jdiaz OP
Oddometer: 32,326
I had Penske make a custom set for an R1100RT back in 1996. These were still the days when you called the Pennsylvania office and actually spoke to the guy who was building your stuff. They gave up on BMW applicatons for awhile after working with me.
Old 04-09-2011, 09:16 AM   #23
Damifino
Damn if I know
Damifino's Avatar
Oddometer: 680
Ok, I have my choice of two different Ohlins models, the cheaper one has a only rebound adjust, the more expensive has both rebound and compression and a remote reservoir, there is about a $200 difference on price. Anyone have the cheaper one? Any buyers remorse in not buying the expensive one?
07 KTM 950 SE
99 KDX200
Old 04-09-2011, 09:41 AM   #24
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,112
The remote preload is really nice when going from solo to solo=bags, or two-up.
R65LazaruS
Old 04-09-2011, 01:43 PM   #25
supershaft
because I can
Oddometer: 9,116
I would have to mess with an Ohlins a bit on a friends bike. It all depends if the compression damper adjustment does anything at all or if it simply does just about what the rebound adjuster does per one person's post here. If I found that to be the case by testing one, why pay two hundred dollars for another mislabeled clicker that does the same thing that the other clicker does? I have seen worse, I have seen shocks that have a compression damper adjustment that does nothing as have many others that I talk to! I don't even have to ride the bike. Just bounce it and you can tell. When your done, click it back to where you found it.
I would also ask someone that understands how they work if the compression adjuster will adjust only more compression damping than the one without the adjuster or more AND less. This is an important question for me because I personally like less compression damping than a lot of people run. IMO, cranking in more on a dirt bike can be a big setup aid but I don't see much use for much of it on the street or road course. To some small degree, of course, but too much is too much. On other words, if the clicker only adjusts more damping in, I very well might want less to start with so why pay for the clicker IF it even works in a direction that I don't want to go.
I want to clarify why I don't see much use for much compression damping on our boxers. IF (and that is a BIG if!) I didn't have to deal with very limited cornering clearance, I might run a softer spring with more sag and rely on both high and low speed compression damping adjustments to take over what might otherwise be the springs job so I could take advantage of that softer spring while leaned way over and while dealing with very subtle bumps. . . . But that isn't the case! I need very little sag to keep the cylinders off the tarmac! With that little sag, I don't need much compression damping! Between the lack of cornering clearance and the drive shaft effect, our bikes work best with an odd setup.
supershaft screwed with this post 04-09-2011 at 02:16 PM
Old 04-10-2011, 06:51 AM   #26
Damifino
Damn if I know
Damifino's Avatar
Oddometer: 680
I don't think it has remote preload, just a remote reservoir.
07 KTM 950 SE
99 KDX200
Old 04-10-2011, 08:36 AM   #27
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,112
OK, never mind . I would say that I can tell the difference when I change the comp and rebound damping by two or three clicks on the Ohlins on my G/S... both are accessible while riding and I have changed them "on the fly"..
R65LazaruS
Old 12-10-2011, 11:12 PM   #28
Les_Garten
Les_Garten's Avatar
Oddometer: 732
Going to put a little bump on this thread.
I am looking at the Ohlins for my Monoshock. How do you guys like them? I'm looking at these or the Wilbers.
Les_Garten is offline   Reply With Quote
Old 07-12-2014, 05:06 PM   #29
sigpe57
Oddometer: 348
I bought a new Ohlins BM053 from an authorized U.S. Ohlins dealer for my '95 R100RT Classic. I had to loose the right subframe mount to put in the shock. However, after the shock is installed, it seems like the top of the shock is rubbing the right subframe. Is this a problem for anyone who has Ohlins installed on their Mono-shock RT? Could it be the '95 R100RT has different subframe than the eariler RT?
Thank you for the reply,
sigpe57 is offline   Reply With Quote
Old 07-12-2014, 06:32 PM   #30
photomd
photomd's Avatar
Oddometer: 744
I used washers as shims to move the subframe off the shock.
1979 V-1000SP
1988 R100RS
1996 R1100RSL
1998 CR250
photomd is offline   Reply With Quote
Times are GMT -7.   It's 03:51 AM.
