Old 10-24-2011, 04:51 AM   #61
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,218
Originally Posted by ride4321 View Post
Now, after the bike cools down over night I can check the valves easily. I used anti seize on the new fitting BTW. It had better work!
And a teachable moment here.
Do I take correctly from your comment that you removed the cover before the bike cooled down?
If so, let it cool completely down next time and it will help ease the removal of the cap.
'08 DR650SE; '91 GL1500SE; USMC 1972-76; NRA Life Member
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 10-24-2011, 10:51 PM   #62
goggo2460
Oddometer: 31
I did the first valve adjustment and the inspection bolt was almost loose. I let the bike cool overnight.
was a little fidgety getting it right though still easy.
Very satisfying doing it yourself.
goggo2460 is offline   Reply With Quote
Old 10-25-2011, 06:00 AM   #63
rivercreep
rivercreep's Avatar
Oddometer: 3,155
Send a message via ICQ to rivercreep
Originally Posted by XDragRacer View Post
Minor point, rivercreep, but I believe the TDC mark passes the window at the end of the compression stroke and at the end of the EXHAUST (not the intake) stroke.
The TDC piston position occurs twice on each cycle of a 4-stroke engine, regardless of the number of cylinders, AFAIK.
I stand corrected = posted before coffee.
That's why I never adjust my valves or do any servicing until AFTER I've had the mornings coffee.
Thank you for the correction.
rivercreep is offline   Reply With Quote
Old 12-19-2011, 11:39 AM   #64
discoganya
discoganya's Avatar
Oddometer: 133
Can anyone recommend a different thread with pics of the oil change & valve adjustment? The pics on this thread do not load and are probably lost...
discoganya is online now   Reply With Quote
Old 12-19-2011, 04:56 PM   #65
shu
Oddometer: 757
For the Valve adjustment there's a PDF with instructions and pics that you can download here:
http://drriders.com/topic251.html
................shu
shu is offline   Reply With Quote
Old 12-20-2011, 12:31 PM   #66
discoganya
discoganya's Avatar
Oddometer: 133
Thanks, any links for an oil change?
Old 06-24-2012, 04:15 PM   #67
Ed~
What, Me Worry?
Ed~'s Avatar
Oddometer: 333
Originally Posted by sonic reducer View Post
valvetrain wear
there is a phrase though: slappy valves are happy valves
Valvetrain wear as in the more clearance, the more inertia on the hit from the rocker arms before the valve springs take up the energy...
Minor wear along with possibly measurable but likely negligible performance difference from slightly more closed valves I guess.
Here's another saying from the Airhead guys:
"I'd rather hear my valves than smell them..."
As in "tic-tic-tic" as opposed to the smell of burning valve seats from not closing fully during cylinder ignition. It's almost always the exhaust valves/seats that lose gap over time. G... I wonder Y...
Just finished my valve check on a new-to-me '00 DR650 with 8K miles and no record of valve-check since 600mi service:
.005" Intake .008 Exhaust. -just buttoned her back up and
Thanks for all the info guys! We are awesome aren't we?
"It is better to be violent, if there is violence in our hearts, than to put on the cloak of non-violence to cover impotence. There is hope for a violent man to become non-violent. There is no such hope for the impotent." -Gandhi
Ed~ is offline   Reply With Quote
Old 11-22-2012, 03:46 PM   #68
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 143
The only issue I was was for the oil change do not got get to get a crush washer when getting to change oil.l have sweapped to a honda crush washe . and rather then collapsing into the threads its a heat treated aluminum washer and you should get 2-3 oil changes out of one washer vice the 1 then change Suzi one. with outh the hassle of having to dig it out of the threads of the drainplug.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Times are GMT -7.   It's 07:19 AM.
