Old 01-11-2012, 09:08 PM   #31
Qwik
Two Wheeled Addict
Oddometer: 5,247
the material of the bracket right in front of where the blue meets the red. It needs to be removed so that the fitting can be threaded in. I will be doing mine soon and doing a write up on it when I do.
Speed bumps never seem to make me go any faster
Qwik is offline   Reply With Quote
Old 01-13-2012, 10:57 AM   #32
BaronVonDarrin
Oddometer: 384
oooooh ok. i was hoping it was a bracket or a fitting and not like, me tapping the oil cover or whatever. ha
BaronVonDarrin is offline   Reply With Quote
Old 01-13-2012, 11:30 AM   #33
Qwik
Two Wheeled Addict
Oddometer: 5,247
Its really quite easy. I just used my dremel to cut away some material and then cleaned up the cut area. Takes me about 20 minutes start to finish on the trim of the plate.
Old 01-13-2012, 11:48 AM   #34
dirtdiver
Oddometer: 1,861
What about sucking the oil out of the fill hole? I guess you would drain the sump from the bottom but could you suck the oil out of the other tank?
DD
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
dirtdiver is offline   Reply With Quote
Old 01-13-2012, 07:12 PM   #35
Qwik
Two Wheeled Addict
Oddometer: 5,247
Tried that. Didnt get very much of it that way. This is simple and easy and you dont have to carry a suction pump.
Old 01-14-2012, 05:59 PM   #36
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,866
Great job guys. I've seen this on Chris's bike and finally got one installed on my 950.
I've given the QuikValve a try in the past, and it took forever to drain in my opinion. I removed it. This is much faster.
I've made up a few of these for me and my buddy's bikes. I have assembled drain extensions ready to go. No work needed and ready to install at your next oil change. Anyone interested?
You'd need to modify your own Alum bracket. I can send a template.
Or would anyone be interested in a core swap product?
I can have the brackets modified here in my shop. I send out a bracket and Drain Hose. You send back your bracket for a core refund.
Drain Hose Kit: $55 plus shipping -includes new oil tank gasket. (slight price increase of $5 due to supply costs going up on all parts last order) This is the ADVRIDER member price for the Blue tank and plug fittings. Black Hose Fittings.
+$10 if you want All black fitting or Custom KTM Orange Fittings.
Drain Hose Kit and bracket exchange: $100 plus $75 Refundable Core charge, plus shipping. Send your bracket in for modification and no core charge.
Just a thought for those that don't want the hassle of cutting braided line, bleeding and putting this all together.
This version is also Clear poly wrapped to protect anything from rubbing on the braided hose and I found some fittings that have a little larger ID for faster oil flow when it comes to drain time.
Please send me an email via Advrider if interested. This way I have your sign in name. I have more kits in stock ready to ship.
If you want a new bracket so that you can save your OEM one, I can do that too. Price would be $55 for the hose kit plus $139 for the modified bracket, plus shipping.
Safe and Easier travels,
cj
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products.
www.outriderjournal.com FREE STUFF!!
cjracer screwed with this post 02-11-2012 at 06:53 AM
cjracer is offline   Reply With Quote
Old 01-15-2012, 05:06 AM   #37
Douf
Limey Bitch
Douf's Avatar
Oddometer: 653
Originally Posted by cjracer View Post
I've made up a few of these for me and my buddy's bikes. I have enough parts to make 3 extra assembled drain extensions ready to go. No work needed and ready to install at your next oil change. Anyone interested?
CJ,
I just bought the parts, but haven't installed them yet. However, the template would slightly simplify the installation if you're interested in sharing that. I've got access to Pro Engineer and a manual Bridgeport so, assuming you have the information electronically, any common file format would suffice.
Cheers,
Douf
Douf is offline   Reply With Quote
Old 01-15-2012, 06:51 PM   #38
gpthis
Oddometer: 171
Thumbs down Oily mess
Cj,
Am interested in one of those!!
Lemeno,
Peter
gpthis is offline   Reply With Quote
Old 01-15-2012, 06:56 PM   #39
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,866
Originally Posted by gpthis View Post
Cj,
Lemeno,
Peter
Hi Peter,
I have one left. Shoot me an email w/ shipping details.
I've got enough interest in this. I'm going to make another batch.
Old 01-15-2012, 09:50 PM   #40
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 1,723
Hi Peter,
whoohoo sweet!
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 01-16-2012, 07:11 AM   #41
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,866
Originally Posted by Douf View Post
CJ,
Cheers,
Douf
Hi Douf,
I was going to mod them manually. Send me an email.
later,
cj
Old 01-16-2012, 07:15 AM   #42
slowinfastout
6 x 275cc
slowinfastout's Avatar
Oddometer: 1,410
I'm in for one. Craig does excellent work on his mods.....definitely recommended.
"Only a biker knows why a dog sticks his head out of a car window."
* 2012 BMW K1600GTL
* 2004 Ducati Multistrada 1000ds
slowinfastout is offline   Reply With Quote
Old 01-16-2012, 09:07 AM   #43
BaronVonDarrin
Oddometer: 384
I just got all the parts (I opted for all black bits aside from the hose) from Summit today at work. If my Dremel is here and not at my folks place, I will probably do this modification this week or weekend at some point. I may make a small video if I feel so inclined. I would be interested in a bracket already done up, Craig!
"I have no idea what I am doing... yet" - me
Husqvarna 2011 te630
BaronVonDarrin screwed with this post 01-16-2012 at 09:21 AM
Old 01-16-2012, 01:10 PM   #44
Qwik
Two Wheeled Addict
Oddometer: 5,247
Baron, I used a cutting wheel and did the basic cut and then used a stone to shape and clean the cut afterwards
Old 01-16-2012, 03:30 PM   #45
Peanuts
Peanuts's Avatar
Oddometer: 1,032
Looks like an ideal job for one of my favourite tools :)
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 09:23 AM.
