Old 01-16-2012, 01:32 PM   #76
Baja Designs
Baja Designs
Baja Designs's Avatar
Oddometer: 617
Originally Posted by Yellow Pig View Post
How does the Squadron compare to Rigid Dually D2?
Hey Yellow Pig the Rigid Dually D2 is a great light, but as far as a comparison to our Squadron, it doesn't really make much sense. I say that because The Squadron is a much brighter light. Rigid advertises the Dually at 1300 Lumens and our Squadron is almost 3x that. The D2 would have comparison to our Double Stryk; again the Rigid lights are great lights, but it would not be fair comparison between our Squadron and their D2 Dually. If you have anymore questions feel free to ask.
Baja Designs is offline   Reply With Quote
Old 01-16-2012, 03:13 PM   #77
Baja Designs
Baja Designs
Oddometer: 617
Hey MJS I took all your information to Alan, owner and head engineer here at Baja designs; to give you the best possible answer and information on our products.
Dear MJS, we think what you are doing with the turntable test is cool and would give a good approximation of the lighting power contained in the main beam of the headlamp. Baja Designs also agrees wholeheartedly that all of us LED light manufacturers should move away from pure marketing hype and move toward more technical measurements. We are completely confident that as consumers are educated on LED technology, Baja Designs lights will come out at the top of the pile. Consumers should be aware of way more factors of LED lights than just lumen output but if we put it all here in one thread, your head will spin. So look for more topics from us in the future.
Your original test was designed to measure the performance of a stage style spot lamp, not a LED based driving lamp; therefore, your test will not accurately reflect the light power contained in the “spill” beam of the headlamp. One of the benefits of LEDs is their inherent “spill” light. “Spill” light would be undesirable and wasted in a stage environment but for an off-road motorcycle light we actually factor this into our optic design and it contributes greatly to the effectiveness of an LED light source. In technical terrain, this spill beam greatly reduces the “tunnel vision” effect you get with many high powered driving lamps. We utilize the spill beam to make the transition between the main beam and peripheral light smooth. It also greatly improves a driver’s ability to recognize terrain and obstacles that would normally be outside the main beam. This is very important especially as you move through your suspension travel during braking, acceleration, cornering, or in rough terrain. The most important benefit of quality optics, which includes this “spill” light, is the considerable reduction in eye fatigue for the rider/driver. Baja Designs is the only off-road light manufacturer that has in-house engineers that designs the optics of our lights. These engineers also happen to be professional level off-road riders and drivers with multiple Baja 1000 class wins to back up the claim. The design goal with the Squadron, Stealth and other Baja Designs LED’s lights is to provide a high intensity center beam for good distance vision along with an appropriate amount of peripheral light. The Squadron driving uses two each of two different reflector styles. There are two “spot” reflectors with a round pattern and two reflectors that add a horizontal component to the main beam.
With the current state of LED technology, comparing them to an HID is not exactly an apples to apples comparison. An HID light is still better for high speed and/or flatter terrain but an LED shines in technical terrain and where you have space and/or weight constraints.
The 3600 Lumens that we claim for the Squadron is based on the total lumens that the LED’s can produce at the drive current that we run them at. It is based on Cree’s numbers for the particular R6 bin that all of our XML LED’s come from. It does not represent the total “out the front” lumens of the lamp (we do this since no other competitor publishes “out the front” lumen numbers for their products). Based on our design work on these reflectors, the Squadron reflectors are approximately 88% efficient. Typical loss for a hard coated polycarbonate front lens is 8-10%. Therefore, calculated through the front lumens should be approximately 2851 lumens.
These numbers do not reflect the output of the LED’s when they get too hot (luminous intensity decreases as the LED’s junction temperature climbs). For this reason, Baja Designs pays great attention not only to the optics, but to the thermal performance of the LED’s and their interface to the heat sink. We are the only consumer LED lighting manufacturer to use solid copper core MCPCB’s to effectively dissipate the heat from the LED into the heat sink. We use active thermal management to reduce LED current when there is not enough air flow to keep the LED’s at the proper operating temperature.
Is your head spinning yet?
Following are candela plots of the spot and wide reflectors that are used in the Squadron. They are normalized to a LED output of 100 lumens. At this time the Squadron lamp is still at an independent testing facility and we don’t have iso plots of its “out the front” performance. We will publish them as soon as we receive the reports.
Another neglected feature of LED and HID lighting performance is the color temperature of the light source being used. In order to save money, many manufacturers use high color temperature LED’s or HID’s (6500 Kelvin and above). The high color temperature LED’s have a greater manufacturing yield so they are cheaper to buy. However, thousands of hours of off-road testing has shown that color temperatures in the 5000K range are better for terrain recognition and depth perception. All Baja Designs lights are built with 5000K light sources whether HID or LED. That blueish hue that Traveltoad picked up in his photography of our competitors lights was due to a high color temperature light source that we feel is a significant detriment to off-road performance.
Old 01-16-2012, 04:07 PM   #78
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,744
I'll bet you get all the chicks with that kind of talk.
Seriously, though...
The TT light seemed more blue as it warmed up, but once going it did not seem that blue. At least not as blue as my photos would indicate. Does the eye not pick up all of the subtle color differences?
traveltoad is offline   Reply With Quote
Old 01-16-2012, 04:17 PM   #79
Baja Designs
Baja Designs
Oddometer: 617
The eye can play tricks in how they perceive certain lights, but a big factor could just be how the camera filtered the color. Often a camera can change certain aspects of the picture and over exaggerate colors, but it definitely did pick up on the blue.
Old 01-16-2012, 06:08 PM   #80
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,555
Damn!
That's fantastic because I find the Rigid D2 Dually to ge a great light.
Now I gotta check out one of these squadrons.
Thanks for the info.
Yellow Pig is online now   Reply With Quote
Old 01-16-2012, 06:12 PM   #81
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,555
PS just looked up the two lights:
The D2 Dually claims 2600 lumens
The regular D2 claims 1600 lumens
Baja Designa claims 3600 lumens for the squadron.
You must have looked up th regular D2.
Do you have a comparison shot of the Spot vs the Driving Squadron light beam?
Old 01-17-2012, 04:49 AM   #82
MOTARDJUNKIE
MOTARDJUNKIE's Avatar
Oddometer: 163
Any idea when this will be available in a ktm mask?
Originally Posted by Oscar
Adventure begins when your plan goes to shit.
MOTARDJUNKIE is offline   Reply With Quote
Old 01-17-2012, 07:51 AM   #83
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,555
What are the mounting points for the Double Striker?
Old 01-17-2012, 08:52 AM   #84
Baja Designs
Baja Designs
Oddometer: 617
Sorry about that and thanks for the heads up you are right, I looked up the regular Dually not the D2. They advertise 2600 of raw lumen output for the D2 Dually. Unfortunately I do not have any comparison shots, maybe someone on here has some? Also keep your eyes peeled for some articles I will be posting about lumen output, optics, and much more.
Old 01-17-2012, 08:55 AM   #85
Baja Designs
Baja Designs
Oddometer: 617
Hey PM me all the info on your bike and I can give you a better idea of when it will be available.
Thanks,
BD
Old 01-17-2012, 08:58 AM   #86
Baja Designs
Baja Designs
Oddometer: 617
Hey yellow pig, unfortunately we do not have a dirt bike mount for the Double Stryk yet, but we are working on it. I will try and keep you posted on the details, what kind of bike are you running?
Old 01-17-2012, 09:16 AM   #87
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 1,188
That would be a total winner, I'd take one too!
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Old 01-17-2012, 10:15 AM   #88
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,555
2010 KTM 530 XC-W
I'd be interested in a KTM orange one too. Shouldn't be a problem, it's just a Polisport MMX headlight mask:
Old 01-17-2012, 10:18 AM   #89
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,555
Not interested in a moto specific mount, I can make that.
Just wondering how anything attaches to the light. Is there a threaded receiver on the bottom or on the side or what.
What would be very helpful is if you guys would post pictures of the item from all sides on the BD web site. you have a bad habit of only showing one picture and not providing any dimensions.
of anything you sell.
Old 01-17-2012, 10:36 AM   #90
Baja Designs
Baja Designs
Oddometer: 617
Yea I agree and we apologize for that, our website is still new and constantly being updated, it will take some time to get it running the way we all want it. What I'll do is go take some specific pictures for you and post them as soon as I am done.
Thanks,
Gordon BD
Times are GMT -7.   It's 08:04 PM.
