Old 01-22-2012, 11:35 PM   #1
brianwheelies OP
Iron toocus
brianwheelies's Avatar
Oddometer: 935
Multicylinder 2 stroke into one expansion chamber?
Has this ever been done? Every performance exhaust for 2 stroke multi's has an expansion chamber for each cylinder.
Just curious.
2009 Aprilia SR50 R Factory
2012 Bont Vaypor Custom 2pt
My drivel
http://chillislives.blogspot.com/
brianwheelies is offline   Reply With Quote
Old 01-23-2012, 12:00 AM   #2
Tosh Togo
Oddometer: 1,594
Just curious.
Some early TZ700/750s used a pair of 2-into-1 chambers, but they were more an answer to the flat-sided OEM pipes than an actual tuning aid. They were ugly, but worked.
Two cylinders into a common pipe should work, as long as they're both in synch as the TZs were.
Tosh Togo is offline   Reply With Quote
Old 01-23-2012, 12:37 AM   #3
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 296
Snowmobiles do it all the time.
Piston
PistonPants is offline   Reply With Quote
Old 01-23-2012, 03:33 AM   #4
JonnyCash
turd polisher
Oddometer: 774
I've seen 3 into 1 pipes offered for GT750's. What I understand is that they run great, but give a strong midrange, not a top end hit.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is online now   Reply With Quote
Old 01-23-2012, 07:02 AM   #5
trophymoto
MACDADDY!
trophymoto's Avatar
Oddometer: 396
like this
http://omarsdtr.com/Ex550suz.html
trophymoto is offline   Reply With Quote
Old 01-23-2012, 07:48 AM   #6
anotherguy
anotherguy's Avatar
Oddometer: 4,314
An associate will build these for RZ350 Yamahas.
When injustice becomes law,resistance becomes duty.
Thomas Jefferson
Old 01-23-2012, 07:58 AM   #7
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 6,317
Piston
Yep, my old Yamaha Phazer does.
That pipe above is quite a piece of work!
"Tough times don't last, but tough people do." Robert A. Schuler
D.T. is offline   Reply With Quote
Old 01-23-2012, 09:24 AM   #8
brianwheelies OP
Iron toocus
Oddometer: 935
I didn't think to look at the snowmobile market.
That pipe above looks great!
My drivel
Old 01-23-2012, 02:10 PM   #9
Shocktower
Shocktower's Avatar
Oddometer: 8,234
Rediculous how on earth will your GF burn both calfs with out twin pipes
BTW that 2-1 is sexy looking
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 01-23-2012, 03:12 PM   #10
anotherguy
anotherguy's Avatar
Oddometer: 4,314
If anyone is interested I've asked Glyn (the guy who built the 2:1 pipe) for permission to put some contact information up here. Here's a set of pipes he makes for +4MM stroked RZ350's-$550 CAD. He does all sorts of engine work for road going 2 strokes.
Thomas Jefferson
Old 01-23-2012, 03:53 PM   #11
tkent02
Oddometer: 820
I rode one, 25 or so years go. Good mid range, good top end, much faster than a stock GT 750. Probably not as good on top as three separate pipes would have been, but I never rode one like that, so I don't really know..
tkent02 is online now   Reply With Quote
Old 01-23-2012, 08:40 PM   #12
scrambler73
Oddometer: 105
2 strokes will always make the most horsepower with ONE individual expansion chamber per cylinder.
As soon as you add 1 or 2 more cylinders to the mix, the soundwaves (for lack of a better explaination) begin to collide in a way that disrupts the whole purpose of an expansion chamber.... Cramming unburnt mixture back into the cylinder before the port closes.
There is a guy working on a 3 into 1 for a Kawasaki Triple that will have interchangeable "chambers".. all made to work at different RPM's. It will be pretty cool to see how it all turns out.
Ive had a few different old-school brands of 3 into 1's on H1's and H2's and they all work the same... Good low end and midrange grunt......but at 6 grand or so, absolutely shut off like you are hitting the kill switch. 6 grand on a triple is where the fun is supposed to start, not stop.
Ive also ridden a buffalo with one of Omar's 3 into 1's and it ran well. Buffalo's were never high revving, so you didn't really miss that last 1000 revs.
Electric start?
scrambler73 is offline   Reply With Quote
Old 01-24-2012, 09:51 AM   #13
gplracing
Oddometer: 29
Hi guy's I'm Glyn the guy that built the 2-1.
This is still in the very early stages of development, but has shown some goos results.
With the post quoted your are right to a point about the pulses getting confused. But the way the crank is phased plays a huge role in the end result.
As this is going onto a parallel twin that is phased at 180* this is in my favour. The first one was dyno'd last week in Germany, a different design to the one shown here but the same principle.
It did quite well for it's first run only 4hp down on the 2-2 set up he was running and it peaked at 9400k against his 9700k with the 2-2.
I will agree that a 3-1 is asking for trouble and will never be able to give you any top end power to speak of, but the 2-1 with a 180* can be made to work really quite well.
How fare I'll take this I don't know as I am time limited at the mo, but I know that it will be as good as any after market off the shelf pipe currently out there.
Glyn
gplracing is offline   Reply With Quote
Old 01-24-2012, 11:36 AM   #14
anotherguy
anotherguy's Avatar
Oddometer: 4,314
Welcome to the Jungle Glyn.
Thomas Jefferson
Old 01-24-2012, 06:12 PM   #15
scrambler73
Oddometer: 105
Cool Glyn...and I do agree that with 180 phasing, if the 2 into 1 is designed well enough (and it sounds like you are definately on the right track!), you will not have nearly the "problems" with soundwave turbulence that one would have with a 3 cylinder.
How was low end grunt compared to the 2 into 2? Thats actually quite impressive that it was only 4hp and 300 revs down on peak.
Glyn
Electric start?
Times are GMT -7.   It's 04:00 PM.
