Old 01-23-2012, 04:28 AM   #12301
robmoto
robmoto's Avatar
Oddometer: 3,267
Originally Posted by Bambi View Post
Hello Rob and Simon,
this is the direct link to see yourself (Simon himself, Rob as the photographer) in the German forum:
http://www.dr-big.de/forum/viewtopic.php?f=14&t=78348
Thanks for that nice connection and kind regards to you, Bambi
Thanks Bambi, does Stefen think Simon is his nephew or as you say it neveau .
robmoto is offline   Reply With Quote
Old 01-23-2012, 12:19 PM   #12302
kyle
kyle's Avatar
Oddometer: 82
hey Robmoto!!!!
i see you run without the rear carrier just handles..was wondering how you strengthened the subframe..on mine the carrier is used to tighten the whole up..i wouldnt think the rear fender would last too long with the weight of the subframe hanging off it..i like the look of just the handles
just trolled through you build pics...so that answers that question......no subframe
kyle screwed with this post 01-23-2012 at 12:28 PM Reason: answer my own question
kyle is offline   Reply With Quote
Old 01-23-2012, 01:54 PM   #12303
Bambi
Bambi's Avatar
Oddometer: 487
Hi Rob,
no, that has nothing to do with relationship ... Stefan is compairing the number of habitants in a square-km in German regions and in Australia. Although I think, if you take a look at Sidney or Canberra it might be similiar to towns like Berlin or Frankfurt in Germany. But if you go out to the country-side, I think Germany is still crowded in it's loneliest regions compaired to the little number of people living in the Australian outback.
Hope, I explained it in an understandable way ...
Kind regards, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 01-23-2012, 04:56 PM   #12304
Simon M
Simon M's Avatar
Oddometer: 87
Hey, welcome back everyone. It's been a bit quiet here for a while and I was starting to get withdrawal symptoms. Good to see everyone out and about again, and safe after the silly season.
I’m a bit envious of you guys out riding. The weather here isn’t conducive to going bush at the moment. This week’s forecast is, 38, 39, 40, 40, 42, 40, 37 degrees C , so I’m staying inside apart from the odd splash in the pool.
Off to but an air conditioner now.
PS. I’m another tank patter.
Simon M
82 Husky AE420 85 Suzuki Katana 1100 88 Suzuki DR750
07 Triumph Speed Triple 08 Yamaha WR250F
Simon M is offline   Reply With Quote
Old 01-23-2012, 09:27 PM   #12305
Simosez
Simosez's Avatar
Oddometer: 255
i'm a tank slapper
fear causes hesitation and hesitation will cause all your worst fears to come true.
DR750 BIG
KTM 450 EXC
Simosez is offline   Reply With Quote
Old 01-23-2012, 10:31 PM   #12306
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,269
Mixture and Economy
Can you guys give me an idea of the fuel consumption of a well tuned SR41 (750) DR?
I put the carbs from the SR42 on my bike (the ones with the removable pilot jets). The bike runs great after replacing all the O-rings and slide guides but is using more fuel. I used to go 400 to 420 k before using "reserve"....Now it's down to 370 k.
Milage is 38 miles/gallon .... or .... about 16 kilometers per liter.
With the old standard SR41 carbs I was averaging 42 to 45 miles per gallon ... or ... 18 to 19 k/l.
In comparing the carb specs in the service manual, I noted the SR42 carbs have a richer needle jet (O-5 rather than O-4) but use the same needles.
To compensate I moved the needle clip up one notch (to lower the needle) today. Only rode around the neighborhood since I was running out of time. The bike ran fine without any hint of lean conditions. I'll give it a better ride tomorrow. Unmodded airbox, clean standard filter, standard exhaust.
I'd just like to know what figures are "normal" or common for the Big
Ladder106 screwed with this post 01-23-2012 at 10:41 PM
Ladder106 is online now   Reply With Quote
Old 01-23-2012, 11:30 PM   #12307
Resi
Resi's Avatar
Oddometer: 194
Send a message via Skype™ to Resi
Ray,
my smurfie takes between 6.5l/100km up to 10l/km, acc. 15.4 km/l respectively 10 km/l.
Final ratio 15/50, actually Metzeler Unicross tires, nearly offroad use only.
Oranje one is at approx. 8 l/100km (12.5km/l).
Final ratio 14/48, onroad use only.
Green SR43 is at 6.5l/100km, onroad cruisin' ;)
You have to break an egg to make an omelette.
Cheers,
LarS
Resi is offline   Reply With Quote
Old 01-24-2012, 12:04 AM   #12308
ztaj
not quite so broken
ztaj's Avatar
Oddometer: 686
Hi Rob,
Australia....land of nothing
Hello all
Ladder I was getting about 17 k/l when the Big (sr41) was running, a little less when "pressing on" The best I ever did was 512k's from a tank, Mrs Z had to ride home and get some fuel in a container for me though
ztaj is offline   Reply With Quote
Old 01-24-2012, 12:09 AM   #12309
Megamoto
Yes, I do look like this.
Megamoto's Avatar
Oddometer: 1,738
Daisy gets 50 Mpg. SR43A, K&N, stock carbs, Laser Produro. (If that helps................)
Guerrilla Moto diplomacy.
Higher level simians as ambassadors of vroom to skewer ignorance and amalgamate ideas globally.
I'm so happy I could whistle through my willie. (Dan Walsh)
Per Ardua ad Astra
Megamoto is offline   Reply With Quote
Old 01-24-2012, 12:23 AM   #12310
MCmad OP
Oddometer: 7,842
Originally Posted by Resi View Post
Ray,
Cheers,
LarS
For those of us less educated this makes all those numbers easier http://www.convert-me.com/en/convert/fuel
Seems most reasonable sized road/adv bikes get between 18- 19km per litre (in my experience on the road somewhere near the speed limit) sometimes I dip into the 17s and occasionally see 20, whether that be a 750/800single or KTM, Aprilia or Harley twins, Thats about 50- 55mpg if your of British descendants
Back in the 800 days
MCmad screwed with this post 01-24-2012 at 12:48 AM
MCmad is offline   Reply With Quote
Old 01-24-2012, 01:25 AM   #12311
bluesman
Oddometer: 2,998
Mine is 5.5 liter per 100 cruising at 120 kmph, 6 liter in any kind of mixed riding. 5 liter per 100 cruising non-stop of 90 kmph limit. My wife, luggage and german motorway at 130 kmph = 6 liters per 100
bluesman is offline   Reply With Quote
Old 01-24-2012, 02:36 AM   #12312
robmoto
robmoto's Avatar
Oddometer: 3,267
Originally Posted by kyle View Post
hey Robmoto!!!!
Kyle, since those pic,s I have added braceing from both sides of the rear frame the back handle bolts to a centre point at the back centre of the guard, using one of the bolts that mount the small rear tailight.
It is now very solid and don,t vibrate at low revs.
it is now very good.
robmoto screwed with this post 01-24-2012 at 03:08 AM
Old 01-24-2012, 03:01 AM   #12313
robmoto
robmoto's Avatar
Oddometer: 3,267
800 motard with pumpers and 2 150mm long foam filters cruising at 100kph is spot on at 20klm,s per litre'
Orange 750 with pumpers the side cut out of the standard air cleaner and small foam cleaner added to the top of the air box fully loaded with all the camping gear etc on hwy sitting at 4500rpm with no headwind only once was 22.1klm,s per litre.
Blue 750 with standard air box and using the air filter cage with no paper but foam filter insert 16.6klm,s per litre and making the motor work.
Yellow 750 with no air box and foam twin air , air filter with 14/50 teeth gearing flogging the guts out of it on off full throttle stuff in the scrub and some road work sitting on 5000 rpm at a guess 12 to 14 I think. but don,t know exactly who cares when your having fun .
Old 01-24-2012, 03:47 AM   #12314
bluesman
Oddometer: 2,998
Damn. So you made me think about TM pumpers again. Damn.
Old 01-24-2012, 03:49 AM   #12315
robmoto
robmoto's Avatar
Oddometer: 3,267
Hope Doc don,t mind, here is his SR/43 bought from Brendan J.
scroll down a bit to see.
http://www.advrider.com/forums/showt...9#post17819629
Times are GMT -7.   It's 05:21 PM.
