Old 01-22-2012, 11:35 PM   #1
Chillis OP
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,158
Multicylinder 2 stroke into one expansion chamber?
Has this ever been done? Every performance exhaust for 2 stroke multi's has an expansion chamber for each cylinder.
Just curious.
Chillis is offline   Reply With Quote
Old 01-23-2012, 12:00 AM   #2
Tosh Togo
Oddometer: 1,594
Just curious.
Some early TZ700/750s used a pair of 2-into-1 chambers, but they were more an answer to the flat-sided OEM pipes than an actual tuning aid. They were ugly, but worked.
Two cylinders into a common pipe should work, as long as they're both in synch as the TZs were.
Tosh Togo is offline   Reply With Quote
Old 01-23-2012, 12:37 AM   #3
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 457
Snowmobiles do it all the time.
Piston
PistonPants is offline   Reply With Quote
Old 01-23-2012, 03:33 AM   #4
JonnyCash
turd polisher
Oddometer: 1,648
I've seen 3 into 1 pipes offered for GT750's. What I understand is that they run great, but give a strong midrange, not a top end hit.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is online now   Reply With Quote
Old 01-23-2012, 07:02 AM   #5
trophymoto
MACDADDY!
trophymoto's Avatar
Oddometer: 450
like this
http://omarsdtr.com/Ex550suz.html
trophymoto is offline   Reply With Quote
Old 01-23-2012, 07:48 AM   #6
anotherguy
anotherguy's Avatar
Oddometer: 6,631
An associate will build these for RZ350 Yamahas.
you don't see luggage racks on a hearse..........act accordingly
Old 01-23-2012, 07:58 AM   #7
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,902
Piston
Yep, my old Yamaha Phazer does.
That pipe above is quite a piece of work!
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 01-23-2012, 09:24 AM   #8
Chillis OP
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,158
I didn't think to look at the snowmobile market.
That pipe above looks great!
Old 01-23-2012, 02:10 PM   #9
Shocktower
Shocktower's Avatar
Oddometer: 9,488
Rediculous how on earth will your GF burn both calfs with out twin pipes
BTW that 2-1 is sexy looking
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 01-23-2012, 03:12 PM   #10
anotherguy
anotherguy's Avatar
Oddometer: 6,631
If anyone is interested I've asked Glyn (the guy who built the 2:1 pipe) for permission to put some contact information up here. Here's a set of pipes he makes for +4MM stroked RZ350's-$550 CAD. He does all sorts of engine work for road going 2 strokes.
Old 01-23-2012, 03:53 PM   #11
tkent02
Oddometer: 2,908
I rode one, 25 or so years go. Good mid range, good top end, much faster than a stock GT 750. Probably not as good on top as three separate pipes would have been, but I never rode one like that, so I don't really know..
tkent02 is offline   Reply With Quote
Old 01-23-2012, 08:40 PM   #12
scrambler73
Oddometer: 121
2 strokes will always make the most horsepower with ONE individual expansion chamber per cylinder.
As soon as you add 1 or 2 more cylinders to the mix, the soundwaves (for lack of a better explaination) begin to collide in a way that disrupts the whole purpose of an expansion chamber.... Cramming unburnt mixture back into the cylinder before the port closes.
There is a guy working on a 3 into 1 for a Kawasaki Triple that will have interchangeable "chambers".. all made to work at different RPM's. It will be pretty cool to see how it all turns out.
Ive had a few different old-school brands of 3 into 1's on H1's and H2's and they all work the same... Good low end and midrange grunt......but at 6 grand or so, absolutely shut off like you are hitting the kill switch. 6 grand on a triple is where the fun is supposed to start, not stop.
Ive also ridden a buffalo with one of Omar's 3 into 1's and it ran well. Buffalo's were never high revving, so you didn't really miss that last 1000 revs.
Electric start?
scrambler73 is offline   Reply With Quote
Old 01-24-2012, 09:51 AM   #13
gplracing
Oddometer: 29
Hi guy's I'm Glyn the guy that built the 2-1.
This is still in the very early stages of development, but has shown some goos results.
With the post quoted your are right to a point about the pulses getting confused. But the way the crank is phased plays a huge role in the end result.
As this is going onto a parallel twin that is phased at 180* this is in my favour. The first one was dyno'd last week in Germany, a different design to the one shown here but the same principle.
It did quite well for it's first run only 4hp down on the 2-2 set up he was running and it peaked at 9400k against his 9700k with the 2-2.
I will agree that a 3-1 is asking for trouble and will never be able to give you any top end power to speak of, but the 2-1 with a 180* can be made to work really quite well.
How fare I'll take this I don't know as I am time limited at the mo, but I know that it will be as good as any after market off the shelf pipe currently out there.
Glyn
gplracing is offline   Reply With Quote
Old 01-24-2012, 11:36 AM   #14
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Welcome to the Jungle Glyn.
Old 01-24-2012, 06:12 PM   #15
scrambler73
Oddometer: 121
Cool Glyn...and I do agree that with 180 phasing, if the 2 into 1 is designed well enough (and it sounds like you are definately on the right track!), you will not have nearly the "problems" with soundwave turbulence that one would have with a 3 cylinder.
How was low end grunt compared to the 2 into 2? Thats actually quite impressive that it was only 4hp and 300 revs down on peak.
Glyn
Electric start?
Times are GMT -7.   It's 03:24 AM.
