12-22-2011, 09:45 AM
#16 |
Oddometer: 3,261
Thanks Rufus- I never thought about that. I'm not much of a two stroke guy but I am going to fire up an oldie soon.
Nine mile skid on a ten mile ride. Hot as a pistol but cool inside. |
01-23-2012, 01:33 AM
#17 |
Oddometer: 538
it is a major ballache to have to try and mix fuel at the gas station, but if you arent going far you can do it at home and just never use more than a tank when you're out
youll need to upjet if you are running premix.
'11 Honda Hornet '01 Peugeot Speedfight 100 4x Puch Maxi |
01-24-2012, 07:12 AM
#18 |
Oddometer: 8,232
I am restoring a 1979 RD 400, and may of people eliminate the pump, I will not for several reasons 1 mixing on the road sucks, and the injection system is proven, it was tough for me because I changed carbs without injector ports so I just mounted some, I will stick with this, because it is not broken so I no fixty
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby '08 KTM 530 EXC 79 RD 400 Daytona |
01-24-2012, 08:51 AM
#19 |
Gnarly old curmudgeon
Oddometer: 209
Another vote here for keeping the injector system instead of running premix. If the current oil tank is too big and obtrusive for the look you want, why not just rig up a smaller one you can tuck away under the seat or something?
In my experience bikes with the injector system run cleaner and foul plugs less often. |
01-24-2012, 09:41 AM
#20 |
Still gettin faster
Oddometer: 943
Don't do it!
Looks like we're voting here.
+1 for the "keep the injector pump" party. Having owned several pre-mix and injected bikes, I have learned that the oil injector is my friend. Especially on the road. Don't do it. |
01-24-2012, 09:55 AM
#21 |
Pro Turd Polisher
Oddometer: 523
Keep the oil injection dude, if it ain't broke don't fix it. Like others have said, it is wonderfull if you plan on riding the bike anywhere serious. All you have to do is top the gas tank off at a fuel stop, check your oil level once in awhile, and ride on. Carrying a bottle of 2stroke oil and measuring untensil stinks. Leave premix for racebikes or vehicles like mopeds where you dont have to fuel up quite as often.
Jerry ____________________________ Great forum and Resource for 1st and 2nd gen Honda V4s SabMagIntercept www.v4hondabbs.com |
01-24-2012, 07:02 PM
#22 | |
Oddometer: 614
For what it's worth....the bike has been stripped, blasted, freed of some excess tabs and such, and the clean up phase of the project is underway. I'll be priming and painting it (the frame swingarm etc.) with my electrostatic paint system...probably light gray, wheels will be medium gray, and the tank and a few other things will probably end up orange of yeller. Tires (Dunlops with a kinda rough dirt-tracky looking tread pattern, even though they're a little big) are courtesy of my old Sportster that recently got new rubber. Airbox was toast, so it's just getting a K&N pod filter on the case inlet flange where the tube attached from the airbox. I know....it's not happening unless there are pictures, so one of these days, when I've made a bit more progress I'll post it up in another thread. I guess I'll start one, or would it be OK to post progress in the street/flat trackers thread already going? Thanks again for the input. Lynn |
01-24-2012, 10:24 PM
#23 |
Oddometer: 351
Bin the oil injection it's crap. Premix is the only way to go, if you want to make 100% sure, your motor is getting oil. Most oil injection systems,have a cable that will feed more oil as your revs go up. The cable will fuk up starve your motor of oil, and bang. If you are to lazy {stupid} to pre-mix oil, buy a 4 stroke.
01-25-2012, 05:54 AM
#24 | |
Oddometer: 8,232
BOOO to the Aussie they are crazy any way , Premix is a PITA IMHO oil injection systems are fine I am voting for keeping it simple, just one brain fart and KABLAAAAMMMOOOOOOOOOOOO ( David Hobs reference)
01-25-2012, 06:01 AM
#25 | |
beat up ex flat tracker
Oddometer: 6,766
Looks are only looks. Put a number plate over the oil reservoir and forget it.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
01-25-2012, 06:04 AM
#26 | |
Oddometer: 6,766
01-25-2012, 07:08 AM
#27 | |
Still gettin faster
Oddometer: 943
01-25-2012, 07:31 AM
#28 |
Yes, it is BIG.
Oddometer: 94
As certified Polaris Techs, between myself and my father, we have worked on and sold hundreds probably thousands of oil injected 2-strokes over the last 20 years, and have seen only a hand full of engine failure where the pump was blamed, one was on a brand new unit where metal shavings where found to be of fault, the others where all the owners fault (i.e. not changing the inline oil filter or using the wrong oil type, i.e. Spectra (a PRE MIX ONLY OIL) in an injector or amsoil, doesn't work well, especially in injectors- Polaris would not honor warranty on any unit with a burn down while running it, regardless of what amsoil says). So, once you chose an oil, make sure it is compatible with use in an OIL injector! If not find one, everyone will tell you what they think is best, in my KTM 300 MXC i run Motul oils, low to no smoke and a pleasant smell. Most pre-mix type oils are not intended for use as injector oil (it’s a viscosity issue). While Motul makes an injector oil, In my old Polaris ATVs I run Pennzoil injector oil, it is cheap and readily available, if i still road them Iike I did before kids, then I'd run Motul in them. While Pennzoil is Not my preference, for bikes that are almost 30 years old and rarely get ridden anymore, it works well. While on some sleds and bikes over the years I have removed the oil pump, it has always been because of extensive engine modifications where it was determined that the stock pump would not meet the needs of the modified engine. In the end, no matter what route you go (keep injector or toss it) chose a HIGH QUALITY oil and STICK with it as this has been proven the best thing for a 2 stroke engine. But just my $0.02 and like the rest of the inamtes here, what do I really know???
The Kawasaki KLR 650, sure it will do that! Hell, it'll do anything ... just not necessarily well.
biggurn screwed with this post 01-25-2012 at 07:37 AM |
01-25-2012, 09:03 AM
#29 |
Oddometer: 4,315
My (former) landspeed record holding RZ 350 has 40K+ on the original oil pump. And I set the record without worrying if the oil ratio was enough at the top end. Just pour some VP MR2 (R.I.P.) in the tank and kick. I do set it up a tad rich on oil delivery. More oil+race fuel=more power
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
01-25-2012, 02:39 PM
#30 |
Oddometer: 351
I have had 2 strokes for the last 35 years. I rebuild all my own motors. What i am trying to tell you , there is a reason why people by pass the Oil-injection {and it's not for the fun of it}. Pre mix at a pump how hard is that????? Baby bottle of oil put your fuel in tip in the oil, and give it a shake. What is the drama with that? If you can't do that should you own a 2 stroke? Which is what this thread gets down to. Some people should just never own 2 strokes. You have to check your ring gap, you have to decarbon your motor, clean out your pipes/mufflers, if you have a bridge in your exhaust port drill holes in your new piston,heat up your head gasket till it's cherry red then put it in water so you can reuse it,{Good thing about Bultacos}, jetting from summer to winter. Doing all this is 100% fine, but tipping some oil in your petrol tank is just way to hard. Pre mix is easy i was doing it when i was 10 years old, it works 100% of the time.
