Old 02-06-2012, 05:21 AM   #1
Knobbiethrower OP
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,324
Fuzeblock FZ1 mounting
Looking for ideas/suggestions for location and mounting this fuseblock on a 990 adv
http://blackdogadvbikes.com/black-do.../275-1152.html
Thanks in advance!
2013 KTM 990 ADV
2011 HUSABERG 570
Knobbiethrower is offline   Reply With Quote
Old 02-06-2012, 07:05 AM   #2
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,347
I put mine in the glove box between the tanks.
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 02-06-2012, 07:22 AM   #3
mOtO_man
mOtO_man's Avatar
Oddometer: 11
my Fuzeblock mount
I put in on the right of the bike. Had to cut out some plastic on the inside of the right fairing for it to fit. The benefit of it being here is that it can easily be accessed and viewed. It did not go in the glove compartment because all the wires would have had to be removed to remove the glovebox....a pain for doing maintenance.
mOtO_man is offline   Reply With Quote
Old 02-06-2012, 07:29 AM   #4
Motard_Menace
Motard_Menace's Avatar
Oddometer: 317
The nine-fifty I just purchased has the fuse block behind the upper headlight/fairing assembly. There is quite a bit of room up there. It is similar to the pics posted but the previous owner fasted it with zip ties on the inside of the bracket. I will try to get some pics later and ad them to the this post for reference.
Here is a pic for the placement of the fuse block that was on my bike when purchased. Not as fancy as the ones on here but an old CanBus setup.
Photobucket
Motard_Menace screwed with this post 02-07-2012 at 12:06 PM Reason: Added Pic
Motard_Menace is offline   Reply With Quote
Old 02-06-2012, 02:05 PM   #5
PS-RagE
PS-RagE's Avatar
Oddometer: 648
I also put mine in the glovebox:
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 02-06-2012, 02:42 PM   #6
torinreality
metaconscious
Oddometer: 57
Originally Posted by mOtO_man View Post
...It did not go in the glove compartment because all the wires would have had to be removed to remove the glovebox....a pain for doing maintenance.
I put mine in the glovebox, too, but I went to some effort to ensure I could remove the Fuzeblock without unwiring anything. Unfortunately the bike's in storage, so I can't post pictures right now, but here's a description of what I did:
1) Cut a hole in the bottom of the glovebox...bigger than the short dimension of the Fuzeblock ,but smaller than the long dimenion. This means the Fuzeblock will slip through the hole, but only sideways.
2) Fabricate an aluminum mounting plate that's bigger than the Fuzeblock in only the long dimension. Thus the mounting plate will also slip through the hole, but also only sideways. The extra aluminum along the two Fuzeblock sides gives me something to mount to the glovebox.
3) Mount Fuzeblock to plate with stock Fuzeblock mounting points (underneath).
4) Bolt mounting plate to bottom of glovebox using Dzus fasteners (with standard sportbike bodywork clips that grab the plastic glovebox bottom).
I'll try to take pictures and post them. If you're interested in the above and my description doesn't make sense, message me.
torinreality is offline   Reply With Quote
Old 02-06-2012, 02:45 PM   #7
torinreality
metaconscious
Oddometer: 57
I love the Fuzeblock, BTW. So awesome to be able to change circuits from switched to "always on" and back again.
Old 02-07-2012, 09:59 AM   #8
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
Got my Aerostich/Rowe Electronics PDM-60 last month, but haven't mounted it yet... can't decide between in the storage box or in the fairing.
Narsisco Lopez is offline   Reply With Quote
Old 02-07-2012, 11:21 AM   #9
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
So, if I've read everything correctly, you wire the fuseblock into the ACC1 (the always on) or directly to the battery and then everything else (GPS, Aux lights, etc.) wire into the fuseblock. Right?
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 02-07-2012, 04:25 PM   #10
torinreality
metaconscious
Oddometer: 57
Wire the Fuzeblock directly to the battery, so you're not limited to the ACC1 amperage. Use a heavy wire. Then all other accessories/farkles wire into the Fuzeblock. I didn't rewire anything stock, but only used the Fuzeblock for the new electrical farkles (gps power, heated grips, voltmeter, aux lights, heated clothing socket, etc.).
Old 02-08-2012, 05:27 AM   #11
Knobbiethrower OP
ADV in ADK
Oddometer: 1,324
Thanks to all for the ideas/responses. Which color wire is the ACC1?
2013 KTM 990 ADV
2011 HUSABERG 570
Old 05-27-2012, 04:32 PM   #12
CharlieFox
Oddometer: 196
Have taken any pics of your install?
CharlieFox is offline   Reply With Quote
Old 05-28-2012, 09:04 AM   #13
m800mm
Oddometer: 74
My plan is to put it in the glove box on velcro, and use male/female
bullet connectors so for service just unplug them. Also I'm thinking
color coded wires. What do you think.
m800mm is offline   Reply With Quote
Old 05-28-2012, 06:11 PM   #14
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,347
That's basically what I did, tho I used a 6 prong connector (I have 5 acc's to the fuzebox) I ordered somewhere off the internet instead of the individual bullet connectors. I did not run all the grounds to the fuzebox, but instead ran them to a central location on the engine behind the tanks, then ran another gound to the battery. That kept me from running 5 more wires into the fuzebox/glove box and cut way down on the birds nest syndrom.
Old 05-28-2012, 07:31 PM   #15
mreimler
Adventure Crasher
mreimler's Avatar
Oddometer: 339
After the canister-ectomy, I made a small bracket and mounted the fuse block where the air pump used to be. Easy access and out of the way.
mreimler is offline   Reply With Quote
Times are GMT -7.   It's 11:32 PM.
