02-05-2012, 10:35 AM
#16 |
Oddometer: 1,625
Couple inside shots of the frame.
![]() ![]() Here we have the makings of what eventually will power the bike. From left to right: The hot rod engine that was in the bike before the strip down. It's an XR650L bottom end with a 675cc big bore kit in an XL600 cylinder topped off with an XR500 head w/Kibblewhite valves and Megacycle cam #148x9 w/hardwelded rockers and performance valve springs. ![]() Next to it is a '97 XR600, and on the far end is the original lower end from the bike. I want to use the original cases to keep the numbers matching but I haven't decided what combination I want to stuff IN the cases.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
02-05-2012, 10:56 AM
#17 |
Oddometer: 423
sick build ill be watching.
1980 XR80s Deceased, first ever teardown. 1987 XL185s Deceased, at the bottom of the ocean. 1985 750 Interceptor Sold still alive somewhere. 2006 XR650L heavily farklefied Tendering in the garage. 2012 F800GS Triple Black Let the mods begin. |
02-05-2012, 12:27 PM
#18 |
Ivanych
Oddometer: 213
HI Brucifer!!!!
You started a great topic and great work!!!!!! ![]() Show more photos, details, tricks. ![]() I'm going to go on the your traces (I will be like the fox) in the construction of my XR500R. Interesting any more details!!!! |
02-05-2012, 12:35 PM
#19 |
Oddometer: 638
Powder coating the frame is the way to go. I painted mine with epoxy spray paint and it was a pita to get an even coat.
02-05-2012, 03:04 PM
#20 |
Oddometer: 1,625
Thanks for following along guys and I really appreciate the kind words.
Ivan- I hope I can live up to your expectations! I'll share whatever tips etc. I can here---if there is any.
02-06-2012, 04:29 PM
#21 | |
looking for bionics
Oddometer: 594
![]() Any problems running that XR5 head? Did you use the old style cam chain with the XRL bottom end? Valve cover from the XL6? Did you do anything to seal up the oil chamber so it doesn't leak out around the cam bearing where the valve cover meets the XR5 head? How well did the combo work? Details please |
02-06-2012, 05:23 PM
#22 | |
Oddometer: 1,625
The piston is a JE 10.5:1 designed to run with the chamber of the XR650L head. I'm probably well over 11:1 with this head. It doesn't work with crappy Ca. 91 octane fuel. It pinged big time with anything over about half throttle. I didn't seal up anything in the 500 head. I do remember you talking about that in one of your posts. I'll look into it this time around. Yes, I used the early wide cam chain. As I recall, I flipped the cam sprocket over so it would line up properly as well. How did it run? Even pinging it was an animal. A freakin' torque monster! Effortless wheelies, even with the tall stock XL gearing. The first time I took it out my buddy showed up with his XR650L, it's piped and jetted. I told him I had to take it easy because my engine was brand new. Well, that didn't last long. ![]() We got about a mile from my house and did a top gear roll-on at about 50 mph. I just walked away from him. I pulled him by 3 or 4 bike lengths before we had to shut down. He couldn't believe it. That engine still isn't even broke in. I doubt it has a hundred miles on it.
03-02-2012, 07:18 AM
#23 |
Mr. Tourguide
Oddometer: 2,552
That's quite the motor!
I'll follow this for a while too. Damn, visiting this site just keeps getting more and more expensive. ![]() I love (and hate) frame up resto work. Seems that every one of mine lately has been stripped down to frame (the last 4 anyway). If I can ask about how much was the powder on the frame...people here charge crazy money for that.
My motorcycle projects blog My Goodreads Profile This is what I do when I'm not here! |
03-02-2012, 07:52 AM
#24 |
Oddometer: 1,625
Hey Henry! Good to see ya here.
It was $150.00 for the frame and the two upper motor mount plates.
03-02-2012, 10:27 AM
#25 | |
¯\_(ツ)_/¯
Oddometer: 1,246
If you thought it was gutsy rattling away on 91, take out a personal loan and fill it with some VP100.
1995 XR628R -Lots of goodies...room for more. Drinking: Funky Cold Medina. |
03-02-2012, 01:19 PM
#26 | |
Oddometer: 1,625
Thanks for the mathemagician skills, HT.
03-02-2012, 01:32 PM
#27 |
Sayer of Sooth
Oddometer: 17
I'm in!!! Good luck with the build, looking forward to updates!
03-03-2012, 07:04 AM
#28 |
Oddometer: 638
My 86 pings quite a bit with the Wiesco 11:1 piston and stock head. It still drives decent but it doesn't like winding out. I stick to feeding it race gas now. I might try an upgraded cam or just get a stock Honda piston.
03-03-2012, 02:16 PM
#29 |
Oddometer: 1,625
A little forward movement.
First, I installed the new bearing races in the steering head. ![]() ![]() Then, I pressed the new lower bearing (with dust seal) onto the lower triple. ![]() And lastly, with the new upper bearing and top triple, installed on the frame. ![]()
05-06-2012, 10:04 AM
#30 |
Oddometer: 1,625
Nothing new yet, but I have been THINKING of working on it.
My recent XR600 purchase and subsequent build have been keeping me away from this build. Hopefully not much longer.
