Old 02-03-2012, 04:26 PM   #1
Harvey Krumpet OP
Oddometer: 899
KDX 250 oil pump info
Kia Ora all,
I have a water cooled KDX 250, I would guess 94 - 96 vintage. I have been running it on pre mix because I do not trust the oil pump, the bike is a bit of a hack. The pump works & I would rather run it as intended but I have no idea how to service or calibrate it for my piece of mind. Can any body supply some info or links with diagrams so I can check it?
Yes, I'm a bodger unfortunately, mechanics is not my strong point & I always need guidance, I do everything wrong the first time.... All help appreciated.
Harvey Krumpet is offline   Reply With Quote
Old 02-04-2012, 06:30 PM   #2
peter650
Oddometer: 422
If i was you, i would keep it on premix. That way you can be 100% sure your motor is getting oil, and how much it's getting.
peter650 is offline   Reply With Quote
Old 02-04-2012, 06:46 PM   #3
Harvey Krumpet OP
Oddometer: 899
My concern is that the pump may be lubricating other parts of the engine, I know bugger all about them & am struggling to get info off the web.
Cheers for the reply.
Old 02-04-2012, 11:42 PM   #4
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 436
If oil disappears from the tank then it reaches rings rods and mains. Monitor fuel vs oil consumption. A ratio will emerge. Who are we to second guess Kawasaki's engineers? Honestly I thought all KDX's never had injectors. Ether way works.
Piston
PistonPants is offline   Reply With Quote
Old 02-05-2012, 04:12 AM   #5
Shocktower
Shocktower's Avatar
Oddometer: 9,466
The Anti-Pump guy
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 02-05-2012, 11:11 AM   #6
welder
welder's Avatar
Oddometer: 1,523
I did not realize kdx's had oil pumps. I thought they were premix right from the factory
"If you come to a fork in the road, take it." Yogi Berra.
welder is offline   Reply With Quote
Old 02-05-2012, 11:11 PM   #7
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,185
we had the KDX 250SR(Japanese model) here in Australia they were a good bike.....however they are now old and being over there have fun trying to find parts new
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 02-06-2012, 01:57 PM   #8
Harvey Krumpet OP
Oddometer: 899
Where those bikes road legal? Mine still has the wiring loom on it & a steel tank, everything else is probably lying in the bush somewhere... The motor is basically a KX so I'm told.
Old 02-06-2012, 11:01 PM   #9
theMISSIONARY
Oddometer: 2,185
yes and steel tank is the "SR" model there was also a KDX200SR so the pump Might (if your lucky) be the same
Old 02-07-2012, 04:16 PM   #10
Harvey Krumpet OP
Oddometer: 899
Thank you. I will carry on with my research.
Times are GMT -7.   It's 09:04 AM.
