Old 02-06-2012, 01:30 PM   #1486
Marki_GSA
Oddometer: 580
Take the sump/oil pan off.
Marki_GSA is offline   Reply With Quote
Old 02-06-2012, 02:29 PM   #1487
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Where are you "DasMatti"?
"DasMatti"
Undoubtedly we need some help getting this thread going again, how was your test ride?
tallguy-09 is offline   Reply With Quote
Old 02-06-2012, 05:46 PM   #1488
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,549
Originally Posted by Anorak View Post
How do you get the piston out to access the rod?
I didn't think about that. Or, to be more accurate, I didn't think.
How often do you need access to the piston on a modern boxer? I'm aware of one where the piston disintegrated at 180K miles. The solution to that problem was a salvage engine that was only 25K miles old. Much cheaper than trying to fix the old engine.
What oil pan?
marchyman is offline   Reply With Quote
Old 02-06-2012, 05:58 PM   #1489
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,255
I seem to recall a number of posts regarding one cylinder vibrating and ultimately failing on the GS12. Often it was the right side. Hate to see some similar issue on this design.
I'll say it again-makes me wonder if what we're seeing isn't a running development engine being put through its paces for research.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 02-06-2012, 07:23 PM   #1490
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Looks like a (or two) running motorcycle(s) to me and I'm thinking all will be good
First thing I'll remove: Rear Footpegs
tallguy-09 screwed with this post 02-06-2012 at 07:28 PM
Old 02-06-2012, 09:45 PM   #1491
rdcyclist
rdcyclist's Avatar
Oddometer: 1,243
In the case of the integral case/cylinders, you split the cases and the crank "falls out". Similar to rebuilding a Japanese four, the bottom case is split from the top and the rod bigends are exposed for disassembly.
The truth of the matter is, almost nobody rebuilds motorcycle engines anymore. There are plenty of wrecking yard engines available with low miles and in the case of a worn out engine, the rest of the bike is usually done by then anyway. How much is a ten year old bike with 250k worth?
rdcyclist is offline   Reply With Quote
Old 02-06-2012, 10:00 PM   #1492
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,381
You are right about everything, my fear will be with the "Chain tensioner" plastic guides that tend to disintegrate from time to time.
Ps: If the new engine does not have the pesky plastic tensioner sliders, me bad and more power to them
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 02-06-2012, 10:06 PM   #1493
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,178
It was a rhetorical question raised for the purpose of intellectual exercise.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-07-2012, 07:58 AM   #1494
rdcyclist
rdcyclist's Avatar
Oddometer: 1,243
Lord knows I need the exercise...
Old 02-07-2012, 11:10 AM   #1495
Marki_GSA
Oddometer: 580
What oil pan?
There has to be some access otherwise you wouldn't be a able to build the engine in the first place. Of course they could be 3D printing them. ;)
Old 02-07-2012, 12:10 PM   #1496
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,527
Don't bring logic into this!
Seriously, they simply compress the rings as they assemble the block halves!
Jim
Old 02-07-2012, 02:53 PM   #1497
Beemerlover
Oddometer: 334
Probably off-subject, but do those guys in the pics REALLY need those knee sliders with boxes mounted on those bikes?
Beemerlover is offline   Reply With Quote
Old 02-07-2012, 02:54 PM   #1498
Beemerlover
Oddometer: 334
Jim
Just like assembling a Goldwing engine, right Jim?
Old 02-07-2012, 03:01 PM   #1499
Beemerlover
Oddometer: 334
What oil pan?
So, are the cams only supported right in the middle with the ends sticking out into space? Maybe I'm missing something, but that pic doesn't look right. Also, I wonder what that big boss on the outside-center of the head with the hole in it is for?
Old 02-07-2012, 04:08 PM   #1500
jtfbb
jtfbb's Avatar
Oddometer: 42
Looks pretty much how the cams are supported in the current camhead motors. The boss on the the outside edge of the head - possibly to mount the shaft for the cam drive gear? - yes I think I saw gear driven cams mentioned somewhere.
Current Bikes: Some Airheads and a couple of hexheads
jtfbb is offline   Reply With Quote
Times are GMT -7.   It's 11:38 AM.
