Old 11-10-2011, 09:15 AM   #166
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Originally Posted by LukasM View Post
Hey guys,
Can one of you who has taken apart a set of stock and other 45mm Zokes confirm if the sliders (the chromed part) are the same length? Diameter should obviously match and I would think the bottom thread for the axle clamps all interchange as well.
I need to replace a scratched slider on a F800GS fork and it might be easier and cheaper to find one from another bike. Anybody with some leftover parts from their Shiver conversion?
Thanks,
Lukas
Can't confirm size but I do have the slider tubes from the donor forks off an Aprilia RXV450. They are about to go up for sale on fleabay. If you want to make me an offer let me know... open to offerse. Have the fork tubes and tripples.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 11-15-2011, 11:26 AM   #167
FinStorm
Oddometer: 23
The sliders from shiver 45 is 30 mm shorter than bmw original, so you canīt use them with bmw:s upper tubes.
FinStorm is offline   Reply With Quote
Old 11-15-2011, 04:33 PM   #168
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Why is that? The BMW travel is less but I'm not sure how much. Seems it should work if the lesser travel equals out?
Old 11-16-2011, 12:56 AM   #169
FinStorm
Oddometer: 23
The innertubes limit the stroke, they stop against the top cap. Therefor Shiver has shorter tubes, they allow to be comressed more, They are a bit longer fully extended and shorter compressed. I am going to use BMW innertube with Shiver outertube, that means it will leave maybe 30mm unused length of the chrome slider when it bottoms. If you mix them the other way it will be the dustseal limiting the stroke.
Old 11-16-2011, 06:32 AM   #170
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Well, I have both the inner & outter shiver RXV tubes avail. I used the stock BMW tubes for my conversion.
Old 11-17-2011, 03:28 AM   #171
-W-
Flying Finn
Oddometer: 193
FinStrom is right.
That way the ridigity of the fork isn't just as good as the stock forks have, which ofcourse isn't that nice thing in this heavy bike.. Different thing is that do you notice it or not..
-W- is offline   Reply With Quote
Old 11-17-2011, 08:33 AM   #172
LukasM
Oddometer: 5,425
Thank you, that is good info, although not what I was hoping to hear...
Unfortunately I haven't been able to find out who sells Marzocchi sliders separately, anybody know a competent source? BMW is very very expensive...
Old 11-17-2011, 11:18 AM   #173
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
I have had great luck with contacting Marzocchi directly. Not sure the price will be any better tho for what you need. Sending you contact info via PM.
BTW are you running the stock BMW internals or upgraded Marzocchi? I have the marzocchi fork tubes from the RXV. If you are running the stock internals what I have won't work. If you have upgraded Marzocchi internals with the bottom foot adjuster then mine will work for you.
Old 11-29-2011, 06:01 PM   #174
Buster714
VP of crash testing
Buster714's Avatar
Oddometer: 661
Bravo!
Excellent work fellas. I have the HyperPro springs in my forks now and I'm no where close to where I need to be. I'll definitely be referring to these threads in the future. I'm sure there are a lof of us out there who are going to need a similar upgrade. Time to find a machinist and suspension guru.....
Aram :: SoloMotoParts.com :: Motorcycle Parts, Gear, and Accessories
Premier Brands / No Tax / Free Shipping / Hassle-Free Returns / Friendly Customer Service
Buster714 is offline   Reply With Quote
Old 01-20-2012, 11:43 AM   #175
Dualsport
Maker of Sweet Cheek
Dualsport's Avatar
Location: Cincinnati the best riding in the area, aint here
Oddometer: 866
I have a couple of new sets of 45mm Marzocchi Shiver forks from when Cannondale went under. Are they the same?
I would love to find a use for them.
Ray Pope
Dual Sport'n in Cincinnati
www.cycle-analyst.com
Dualsport is offline   Reply With Quote
Old 01-22-2012, 09:19 PM   #176
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
What are the specs?
Old 01-27-2012, 09:00 AM   #177
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
If you know the specs on these forks then I can tell if you they woudl work or not.
The travel needs to be as long or longer than the stock BMW marzocchi's.
If they are as long or longer they can be shortened. So do you know the travel? If so I might know someone interested in a set.
Old 01-27-2012, 09:04 AM   #178
LukasM
Oddometer: 5,425
It's not only about the stroke but also the length. Shortening is fairly easy, extending them is not.
Old 01-27-2012, 09:28 AM   #179
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Correct. They need to be as long overall and the stroke need stroke needs to be as long or longer.
As you said, shortening is easy and lengthening is harder. They are not like fake boobs. You can't just make them bigger for a few bucks.
Old 02-08-2012, 10:29 PM   #180
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 861
Originally Posted by Oso Blanco View Post
Have had mine in for a little over a year. Definitely a huge improvement over stock but I still need to do some tuning. The progressive rate springs need to go and I need to tighten up the compression stack. Even with the bleeds all the way in it's too soft. It bottoms easily and dives a ton under hard braking. The potential is there, just need to spend some more time with it.
You need a higher rate spring (USD forks dive while braking), what are you running for float? .8-1.5mm?
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Times are GMT -7.   It's 03:44 PM.
