02-08-2012, 07:28 PM
#181 |
Rally Dreamer
Oddometer: 1,581
Looks like an awesome Mexican 1000 vintage entry!
follow my journey: Dreaming of Dakar Special thanks to my sponsors: Freedom Cycle of Concord NH BRP Renazco Racing MX1West Help support my racing addiction and look cool doing it! Buy a T-shirt or hat from the Dakar Dream Store |
02-09-2012, 01:52 AM
#182 | |
www.motoxplorers.com
Oddometer: 2,163
02-09-2012, 03:03 AM
#183 |
Oddometer: 440
And the waterproofing on the spark plug cable is good ...
02-09-2012, 12:21 PM
#184 |
Armature speller
Oddometer: 6,782
02-10-2012, 08:03 PM
#185 |
Expert Tomfoolerist
02-25-2012, 12:04 PM
#186 |
Guns are for pussies
Oddometer: 13,783
Circus bear bump
Just say'IN |
02-28-2012, 02:05 PM
#187 | |
Oddometer: 13,783
Just say'IN |
02-28-2012, 08:41 PM
#188 | |
Riff Raff
- Ken |
02-29-2012, 06:07 AM
#189 | |
Oddometer: 13,783
Just say'IN |
02-29-2012, 06:23 AM
#190 |
Safari Scramble!!!!!
Oddometer: 3,205
I think the key point here is that the navigation setup could be different for different events. At the Safari rally I needed a roadbook and an odometer and that was it. I don't think GPS was allowed but it wouldn't have done you much good. I used a reasonably simple handlebar mount setup and did not find the weight on the bars to be much of an issue. The terrain consisted of loose sand roads and hard packed 2 tracks for the most part. In an event like Dakar with all the crap you have to carry a frame setup would be ideal given you have all the extra equipment on the bike.
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
02-29-2012, 06:55 AM
#191 |
rally racer
Oddometer: 124
![]() We've been using this rally-light set up for a couplr of years now. Billet plate bolts to H/bar top clamp http://www.rally-raidproducts.co.uk/...r-scott-ohlins http://www.rally-raidproducts.co.uk/...dbook%20-mount
690 enduro/ rally 350 exc RALLY-RAIDPRODUCTS.CO.UK |
02-29-2012, 07:50 AM
#192 |
Oddometer: 13,783
That's a nice simple set up Beaney, love it!
Seth, so all the extra weight on your bars wasn't an issue then? Honestly Seth, I don't want two or three different set ups for rally. Like I said, I'm at a place where I have some options and I'm trying to make a good decision. I don't ever plan on doing the Dakar, it has zero interest to me. I would like to do a few other rally events, like the MX1000, Toureg, Albania etc etc etc. I've been thinking that a hybrid nav set up would be nice, a cross between the ultra simple H-bars style and the steering stem option. So far Paul's design seems like the best compromise between performance and simplicity but I've only done Rallymoto, so I don't have a clue if my thoughts are correct or not. As is usually the case, it's personal preference. I'm hoping Ned chimes in
Just say'IN |
02-29-2012, 09:09 AM
#193 | |
Oddometer: 3,205
02-29-2012, 10:14 AM
#194 | ||
Reforming Neandertal
Oddometer: 867
Beanie, Seth and Aaron, this is similar to what Seth and I were going to do last year before we kept the RMS mounts, I' like the looks of both, but the RMS mounts have the ability to be completely removed quickly and easily. The top clamp mounts will work with my guard setup, but it would be more of a pain to remove for single track and I'd like to see it farther away from the brake line or the lines run down the triple. Aaron, we can look at something like that if you'd like, but the farther out from the steering stem, the more momentum you'll have and feel. It'll always be a compromise to some extent, but like you said, it's not Dakar, you can get away with a lot less. |
02-29-2012, 12:08 PM
#195 |
Oddometer: 859
Aaron,
If all you need is the roadbook and an ICO then I think the RMS sytem will work fine. I used it during a three day draining last year and had no problems, didn't really notice the weight on the bars at all. I also think this system is probably a little more crash worthy as it can rotate. For Dakar there is so much more needed to be mounted that a fix mount on the steering stem makes sense. I'd keep it as simple as possible. |
