Old 02-07-2012, 04:45 PM   #1501
Beemerlover
Oddometer: 334
Originally Posted by jtfbb View Post
Looks pretty much how the cams are supported in the current camhead motors. The boss on the the outside edge of the head - possibly to mount the shaft for the cam drive gear? - yes I think I saw gear driven cams mentioned somewhere.
From the pics I've seen of the camhead heads, there appears to be two fairly widely-spaced bearings for the cams. This pick looks like the only bearings are right in the middle. Maybe it's just the angle of the pics though.
Gear drive for the cams huh? Sounds like a good idea, but I wonder if that will be a chain-driven gear in the heads that couples to gears on the ends of the cams? Guess time will tell.
Beemerlover is offline   Reply With Quote
Old 02-07-2012, 06:54 PM   #1502
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 983
Originally Posted by Marki_GSA View Post
There has to be some access otherwise you wouldn't be a able to build the engine in the first place. Of course they could be 3D printing them. ;)
This is educated conjecture at its best, but the design looks like a wet liner design. It's likely that the block is assembled with the rods attached to the crankshaft. The pistons would then be installed into the bores of the liners. With the pistons protruding from the bottom of the liners the piston wrist pins would then pushed through the pistons and into the upper rod bores via an access hole made available through a water pipe flange, or some such, on either cylinder when the pistons are joined with the rods.
This type of design was used by VW on the Wasser Boxer Vanagon for many years. IIRC, Renault was also fond of this design. A major drawback of this design is that removing the piston pins after many miles/years of use is difficult when there are some carbon deposits on the exposed portions of the wrist pins between the upper rod journals and the piston wrist pin bosses. Special tools are usually required to facilitate pin removal. Neanderthal measures and home mechanic clubbings don't work here. An owner of this type of engine design must not neglect or lengthen oil change intervals and must not use inferior dino oil.
Another drawback of this type of design is that the o-rings at the top and bottom of the liners are also sensitive to poor maintenance. The coolant must not be allowed to degrade enough to allow corrosion of the grooves that hold the o-rings. Without proper maintenance, the o-ring grooves degrade and cause the o-rings to fail if the liners are made of iron that is exposed to the coolant. This would likely allow water into the crankcase and its oil if the liners aren't coated to protect the iron in the liners or the liners are not made of non-corrosive materials. Electrolysis is the enemy here.
The rear view of the block doesn't show any access ports, water pumps or flanges that might provide wrist pin access. I would bet that a frontal view of the block would provide evidence of properly positioned devices that allow access to the wrist pins. Such a view would solidify the idea that these engines are a wet liner design.
This is my take after rebuilding many Vanagons and is subject to withdrawal after serious internet flaming or real proof otherwise avails itself.
As ever, YMMV.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 02-08-2012, 07:15 AM   #1503
Deans BMW
Granpa Hoon
Oddometer: 3,460
99% sure it is a wet clutch and the FD unit is the same as used on the new K1600's, a much more robust unit.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is online now   Reply With Quote
Old 02-08-2012, 08:24 AM   #1504
rritterson
Oddometer: 207
Originally Posted by Beemerlover View Post
Probably off-subject, but do those guys in the pics REALLY need those knee sliders with boxes mounted on those bikes?
Knee pucks are not used for support, they are used as a lean angle gauge. If the guys know how far to lean and hang so that the pucks touch just before the boxes, they'd be helpful.
rritterson is offline   Reply With Quote
Old 02-08-2012, 10:38 AM   #1505
g_e_young
g_e_young's Avatar
Oddometer: 867
Is the K1600GT final drive a significantly different design internally? Or just more robust? I just hope the new FD is lighter as I think the single worst design element of my GSA is the amount of unsprung weight at the rear wheel. It's very obvious when driving over bumpy surfaces....
g-
IBA# 15974
www.whatsmyco2.com
g_e_young is offline   Reply With Quote
Old 02-08-2012, 03:07 PM   #1506
Deans BMW
Granpa Hoon
Oddometer: 3,460
g-
Both a different internal design and more robust.
Dean O
Copperhill, Tn.
Old 02-08-2012, 09:22 PM   #1507
peter-k
Candyman
peter-k's Avatar
Oddometer: 70
g-
Did you try with a better rear shock? While I am not saying it reduces the unsprung weight, it does reduce the rear wheel trampling.
peter-k is offline   Reply With Quote
Old 02-09-2012, 04:03 AM   #1508
whittrated03
Steady Rollin' Man
whittrated03's Avatar
Oddometer: 221
Originally Posted by PeterW View Post
Hopefully they actually re-engineered that final drive as well - rather than just continuing to push more ponies through something that was marginal 10 years ago :)
The GS is a great bike, one I've always lusted after, IF you can overlook the reliability issues - I can't.
Pete
Thats a big HELL YEAH! I am in the position now to own a GSA but will go with the Tenere or Tiger 1200. Def the Yamaha Tenere 1200. I absolutely love the BMW GSA. It looks the part...it just looks so trick compared to the other bikes in the adv segment but I hate being stranded. I tend to get far away from civilazation so dependability is the absolute most important thing for me. Thats why I choose Japan motorcycles. Oh, as you guys probably can figure, i ride a Strom.
Smooth is fast.
whittrated03 is offline   Reply With Quote
Old 02-09-2012, 04:24 AM   #1509
whittrated03
Steady Rollin' Man
Oddometer: 221
I would like to know why BMW needs to make a adv bike with 130hp???
Smooth is fast.
Old 02-09-2012, 04:55 AM   #1510
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,171
Can you go into any detail on why you believe this? I'm not trying to sound argumentative, but it is what we all want to hear, and what BMW must know we all want to hear, so I tend to be somewhat skeptical when statements like that come along.
Old 02-09-2012, 05:20 AM   #1511
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,359
Obviously you really want a BMW though, or you wouldn't be here!
Jim
Old 02-09-2012, 05:53 AM   #1512
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,243
Kinda my take too. Unless they feel really compelled to chase the Multistrada into a segment that isn't 'GS'. The 'upright sport touring bike' segment. Maybe it'll get a 17" front too!
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 02-09-2012, 06:07 AM   #1513
Midnullarbor
Oddometer: 332
Talking
Sorry, Jim, but that argument is rather weak!
For anyone with a general interest in motorcycling & adventure-riding [and keyboard time!!!] the G-Spot sites are relatively attractive . . . it's not just all the Angst and hurly-burly . . . it's the sheer accessibility of the layout of "threads with titles".
Unless you are a committed close-follower of one of the mega-threads of "Beasts" (or whatever) . . . it is difficult to keep in touch with what is happening there . . . yes, it is actually a bit daunting to find a thread with 2,000 or 20,000 posts sitting there . . . like a nightmare of unread emails.
(Have to put in a good word for "Hacks", in the same way )
Midnullarbor is offline   Reply With Quote
Old 02-09-2012, 06:20 AM   #1514
Midnullarbor
Oddometer: 332
An adv-bike with 130 hp . . . why not?
Admittedly, it's rather difficult to use more than 50 rear wheel horsepower on a dirt road . . . but with such heavy bikes as these, we are really talking about something closer to Autobahn adventure-tourer. A big and growing market segment . . . and customers always want more power (if only for prestige) . . . and for manufacturers, it would never do to have a flagship with substantially lower output than their competitors.
Interesting to know where it will all end . . .
Old 02-09-2012, 07:48 AM   #1515
vtbob
wanderer
Oddometer: 592
130hp is not really about adventure touring...meaning bad roads, dirt, mud, stones. 50hp and less weight is the way to go.
130 hp is all about speed on pavement, bragging rights, image, bench racing/BSing.
130 hp sells That is what BMW, Ducatti, note the engine on the new honda!!
There are the poseurs, and then there are the serious adventure tours.
enjoy
vtbob is offline   Reply With Quote
Times are GMT -7.   It's 11:03 AM.
