Old 03-02-2012, 03:33 PM   #1
henkew OP
Oddometer: 70
Would this Trailer work for a 1200 mile journey?
My son and I would like to take our bikes with us to Southern Utah this Spring on our annual rock climbing trip. We have a Tiger 800XC and a 650 Ninja. Would a trailer like this do the trick?
http://www.lowes.com/webapp/wcs/stor...%20Ramp%20Gate
I wonder about the tire size for that long of a trip at freeway speeds. I'm also curious how it would impact gas mileage. Any thoughts would be appreciated.
henkew is offline   Reply With Quote
Old 03-02-2012, 03:37 PM   #2
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,616
That trailer would do just fine.
I have 12" tires on my trailer, and have pulled it at over 75mph on extended freeway runs often...with no issues.
Flashmo is offline   Reply With Quote
Old 03-02-2012, 03:57 PM   #3
PhotoBiker
Please insert title here
PhotoBiker's Avatar
Oddometer: 1,436
How will you secure the front tire?
The bed on that trailer is pretty slick, it's made for tractors, leaves, lawn-mowers, etc.
You might get by with a a few well-placed 2x4's bolted down to the flooring?
My opinion (and it is just that) is that I wouldn't trust this trailer to support two bikes for an extended trip like you have mentioned. There is one central structure member that extends from the tongue through the bottom of the trailer. A single bike would place most of its weight over the top of that member, you'd most likely be fine. Two bikes will have their weight off center, I'd expect the trailer to flex about the center on a long trip.
I'd look for a trailer that has a triangle-like configuration from the tongue to the bed to minimize this flex.
Sort of like this one:
Again, this is my $.02, YMMV.
-=Glen=-
[Current]
'10 R1200GS
'06 Ninja 250
Check out my Gallery
PhotoBiker is offline   Reply With Quote
Old 03-02-2012, 05:22 PM   #4
LARK
Oddometer: 69
I have to agree with PhotoBiker on this. The trailer you're looking at is about as cheaply made as they come. The floor is grated just like the lift gate is. Not good. Pressure treated 2"x6"'s are pretty much standard on decent basic lower end units. Basic units like the one in PhotoBikers post will allow you to drill through the 2"x6"'s and into the steel cross braces and secure anchors to the floor. What ever you buy look under it before hand so you'll know if your anchor points will be secure. A 15" tire will ride better and run cooler. Spend the extra money and include a spare wheel/tire and mount on the trailer. For under $1500 you can get a very good 5'x10' drop gate trailer with 15"wheels and a spare with a 2" coupler. I'll pull great and last damn near forever.
LARK is offline   Reply With Quote
Old 03-02-2012, 06:10 PM   #5
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,462
Strongly suggest you repack the wheel bearing, both the inter & outer bearing.
Then install a bearing buddy w/ the spring tention.
Easy to do & will be done completely right for sure. Never seen a bearing w/ enough grease from the factory.
Wolfgang55 is offline   Reply With Quote
Old 03-02-2012, 06:37 PM   #6
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,413
That trailer would work fine. You need some basic rigging skills to tie down. carry bikes on my open flat railer all the time. Use QUALITY tie down straps (ANCRA!) only and NO Chinese shit to secure the bikes. 4 on each bike, then tie the tire to the front headboard.
Old 03-02-2012, 08:00 PM   #7
blackfoot36
blackfoot36's Avatar
Oddometer: 29
I didn't see the fuel part of the question addressed yet. FWIW, anytime I've towed a trailer, my fuel economy sucked; often less than half the usual MPG. I figured it was worth the extra fuel for what I needed. A lot depends on tow vehicle, overall weight of the whole rig, drag etc. For me, doubling my fuel estimation for the trip worked- but I never kept detailed records.
blackfoot36 is offline   Reply With Quote
Old 03-02-2012, 08:02 PM   #8
Bajatacoma
Why me?
Bajatacoma's Avatar
Oddometer: 56
I've got one that looks very similar to that; picked it up for $150 used (divorce sale). I carried two bikes on it with no issues but mine are lighter than yours too. As mentioned, the front flexes a bit since it's boxed and not triangulated; it never felt unsafe, just could have been better. To solve this I picked up a piece of angle from the local metal store and welded a brace on each side from the tongue to the second perpendicular brace under the decking. This was also welded to the front perpendicular piece. Kind of hard to explain but simple in design (Id post a pic if I were home). It took me longer to go pick up up the metal than to weld the braces on and paint them. That stiffened it up significantly and it tows better now too, especially when empty.
Mine was several years old when I got it and the expanded metal was a bit rusty on the decking but I ran it that way for a while until I had some time to replace it. I used treated deck boards and it's been fine- I thought about 2Xs but it's not like this trailer will ever carry anything really heavy. The expanded metal tailgate is easy enough to use as the ramp angle isn't very steep and it allows air to flow through so it doesn't hurt your mileage as much.
Other mods included replacing the 1 7/8" hitch with a 2" (standardized everything I own), replacing the lights after I broke a marker and a tail light and doing a spring over for more ground clearance (made it easier to push through the yard and my truck is slightly lifted so now it lines up better with the truck- yes I know I could have bought another drop hitch but the trailer was pretty low to start with). I installed bearing buddies after repacking the bearings. The tires haven't been an issue even in our hot weather; I usually check them when I stop for fuel on trips. I've got a pair of the Northern Tool wheel chocks that I bolt on when needed. I drilled holes to allow me to carry one bike centered or two off the center line. No complaints so far. http://www.northerntool.com/shop/too...Product%20Page
If I were going to be towing a lot, needed to carry heavier loads and/or was buying new I'd have bought something like the one photobiker posted, but realistically this meets my needs. Try watching your local classified or checking Craigslist for used deals too.
Bajatacoma screwed with this post 03-02-2012 at 08:09 PM
Bajatacoma is offline   Reply With Quote
Old 03-02-2012, 08:38 PM   #9
barnyard
Verbal tactician
barnyard's Avatar
Oddometer: 11,042
I also have that trailer.
This summer I hauled my Buell home about 30ish miles after the rear wheel bearings shit the bed. I was not impressed. The floor flexes and the bike moved around A LOT. Not only up and down, but side to side also. I know how to tie down bikes, I have been doing it for 6 years. I was really concerned that the rails on the trailer were going to rip off.
This winter, we are welding more angle stock to the frame, adding more stock to the front and adding one of those steel wheel chock, tie down thingys. Not really a wheel chock, but the thing some attach to a pick up bed. We can tie down 3 bikes and that will work fine.
We are also talking about cutting off the coupler, adding a little more length and triangulating that so we can mount a toolbox. I would also add a 2 inch coupler. All the other trailers I pull are 2 inch.
If having a utility trailer were not so usefull, I would have bought a 3-rail trailer with a 2,000 lb capacity.
I have a spare tire for my trailer, for a trip like you are planning, I would take 2 spares and a complete spare hub. Include the tools to change tires and hub (seems obvious.) If you do not want to do a hub, get a complete set of bearings and seals as a spare. Grease the seals and put them in a zip lock bag.
I also bought replacement LED lamps for the lights. Standard bulbs have a tendency to get hot on long trips and fail. LEDs eliminate that.
Watch Craigslist. I bought my trailer used with all the spares for $100 less than new. 3 rail trailers are out there, but take a bit more searching.
all around good guy
barnyard is offline   Reply With Quote
Old 03-02-2012, 09:42 PM   #10
high dangler
high dangler's Avatar
Oddometer: 535
you'll be fine with that trailor. I would ditch the big fold up vertical ramp though . It'll be like a drag chute .
rompin stompin tiger 800 XC rider
high dangler is offline   Reply With Quote
Old 03-03-2012, 05:18 AM   #11
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,838
"My opinion (and it is just that) is that I wouldn't trust this trailer to support two bikes for an extended trip like you have mentioned. There is one central structure member that extends from the tongue through the bottom of the trailer. A single bike would place most of its weight over the top of that member, you'd most likely be fine. Two bikes will have their weight off center, I'd expect the trailer to flex about the center on a long trip. "
+1
Tsotsie is offline   Reply With Quote
Old 03-03-2012, 10:23 AM   #12
Tuffgonger
Ridiculousness
Tuffgonger's Avatar
Oddometer: 28
I purchased that same trailer about 2 years ago and had it for about 6 months (instead picked up a used 6x10 full aluminum trailer with 15" wheels for about $1200). The flex in the trailer is a little disturbing, especially when you stand on a corner or tie something down. Additionally, any weight on the floor that is not on a piece of angle bar, causes the floor to sink and flex. It would probably make the trip, but for the size bikes you have, I would do some work on it first. I was carrying dirt bikes and would not go farther than about 100 miles.
What I did to the Lowe's trailer before selling it: fortified the floor with 2x6s and large carriage bolts. This prevents the major flex I talked about earlier, plus gives it a little more weight and solidity. Added a bunch of eye hooks for tie down spots. Lastly, got two of the Harbor Freight heavy duty wheel chocks and bolted them down.
One last comment: we had an incident where the trailer jumped off the trailer ball going 40mph over some large bumps. I usually double-check the fit before leaving the house, but this was the last straw for us. YMMV.
Tuffgonger is offline   Reply With Quote
Old 03-03-2012, 11:44 AM   #13
STisma
STisma's Avatar
Oddometer: 148
I've had one of those open "landscape" type trailers.
With time I started hauling more and more and securing all the items became difficult.
For some reason motorcycle gear attracts .....everybody.
So I ended up getting an enclosed, cargo, trailer 12ft long 6 or 7ft wide.
It fits two full size bikes and a third if needed, along with tons of gear.
Lockable, weather protected, .... used it for quick naps as well.
Yes, more money, but that gear must be secure and it serves as storage.
If it can go wrong, it will go wrong!!!
STisma is offline   Reply With Quote
Old 03-03-2012, 03:04 PM   #14
GH41
Oddometer: 822
At 5 feet it seems a little narrow for two bikes. If you intend to trailer the bikes often I would shop for something with twice the load capacity of your bikes. For ocational use it will be fine. Make sure to buy a spare, jack and 4 way lug wrench. GH
GH41 is offline   Reply With Quote
Old 03-03-2012, 11:44 PM   #15
Dream Rider
Servant
Dream Rider's Avatar
Oddometer: 192
trailer
I agree with Lark: I have a 6x12 drop tailgate. single axle, 15" wheels. aluminum shell, plywood floor and uses a
1 7/8" ball. Towed my 1150 GS, Tools, and other goodies from Anchorage AK to Fayetteville NC and back to SE Washington. Bike faired very well, did not get any road dings (common on the ALCAN) and I have used it for hauling and storage. Home Depot has some for about $1700 but should be worth it. Keeps all your gear dry and safe. and you can sleep in it if you take the bikes out. That trailer you showed me is ok for hauling trash. IMHO
Dream Rider is offline   Reply With Quote
Times are GMT -7.   It's 07:53 AM.
