Old 03-02-2012, 02:26 PM   #4741
woodchuckexc
Oddometer: 801
Oiled thechain and rode the beeeatch
woodchuckexc is offline   Reply With Quote
Old 03-02-2012, 03:19 PM   #4742
Fatallybitten
Slow but Sure
Fatallybitten's Avatar
Oddometer: 371
Gerbings Dual Controller, HDB Billet, Luggage and Auxillary Gas Cans
Today I finished up a number of mods that I have had underway over the winter.
I wired in my Gerbing's dual controller using the Highway Dirt Bikes' billet for the switches. It is a nicely finished and functional way of handling the switches.
Then I mounted my Happy Trail Mojave soft panniers and loaded them up to see how they worked. These are going to be my everyday panniers for day/weekend trips, as well as more serious off-road excursions. They come with waterproof inner liners and hold about 25 liters a side.
Right Side
Left Side
Next, I swapped the Mojave soft bags for my Happy Trail aluminum panniers that hold a combined 70 liters of gear. I have two waterproof bags that strap to the back rack, one holds 70 liters and the other 50 liters. All or some combination of this luggage will handle my gear for longer trips
Right Side
Left Side
Lastly, my solution for carrying extra fuel is to strap a 5 liter plastic gas can to each passenger foot peg and pannier. I haven't road tested it yet, but the gas cans are securely attached and I don't expect them to move. The location doesn't interfere with my riding position and has the added benefit of being situated low down near the center of the bike.
Right Side
Left Side
Now I just need winter to end so I can road test both of these luggage configurations and the auxillary gas cans in preparation for this year's trips.
Cheers, David
Fatallybitten is offline   Reply With Quote
Old 03-02-2012, 07:32 PM   #4743
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 4,039
Mended the wiring rats nest and started on the water pump rebuild. Tried to tap out the seal with the shaft but it just bent the cir-clip and tore the rubber seal in half.
I am going ttake that as a sign that the work needed to be done.
Pried at it bit, but decided to put off finishing for tomorrow. Time to try out the new heat gun!
When in doubt, take it as a compliment.
My Ride Reports
Hobbes950 is offline   Reply With Quote
Old 03-02-2012, 07:48 PM   #4744
bikepsych
Oddometer: 300
Had it dyno'd yesterday (sorry its a day late) and the PCV dialed in. Hopeing to pump up the MPG's back to 40+. Cranking out 102 ponies and 64 ft/lbs of torque. Now time for a new rear tire after the dyno run.
Bruce
Camarillo, CA
2015 Triumph Tiger 800 XCx
2009 Harley Road Glide
2006 Buell Ulysses
bikepsych is offline   Reply With Quote
Old 03-02-2012, 08:52 PM   #4745
rinho
Rinho Féroce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,159
Chain and sprocket replacement... and spend some time on the 2nd fan project
I use 0.050 aluminiun, because I did not have carboard to built the first pattern... finally, I guess it's stiff enough to be the final version.
Just have to add a bracket on the top, I did a mistake and cut it by accident
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 03-02-2012, 08:53 PM   #4746
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,159
To be continued...
Old 03-02-2012, 10:24 PM   #4747
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
Took a mild plunge into the next depth of the KTM lighting woes. Last year I bought the Euro light, today I ordered an HID 35w 5000 lum H7 low beam upgrade.
I did swing by a KTM shop down in Roseville and actually took a look at the KTM remote tripmaster switch. (I know, I know, I know, there's a ton of other cheaper do-it-yourself options out there.) What I really wanted to know was will that switch REALLY work with the newer style speedo units on the 990s (2009 to current). The KTM Twins site says it works with both the 950s and 990s, but the first two 990s used the older style computer. We looked at the instructions and it shows it only working with the earlier units up through 2005. The key thing (aside from accessing the Mode button remotely) is that the switch does NOT appear to allow the Trip 2 odo to be adjusted in flight - something that works on the EXCs and some of the older computers. So I didn't bother trying it. Bummer.
As such, I left the store with only a new die-cut KTM decal for my truck window.
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 03-03-2012, 01:55 AM   #4748
Autostream
Autostream's Avatar
Oddometer: 5,833
Developed a new power retardation system
Examined the undercarriage... more than once or twice...
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream screwed with this post 03-03-2012 at 01:41 PM
Autostream is offline   Reply With Quote
Old 03-03-2012, 09:17 AM   #4749
SidewinderX
Hey, watch this!
SidewinderX's Avatar
Oddometer: 1,160
Arrived home and was greeted by a nice package from Hontri..... Installed my underseat storage tray in just a few minutes. Well worth the $$. Nice finish and great fit.
Daniel
What would you attempt to do in life if you knew that you could not fail?
SidewinderX is offline   Reply With Quote
Old 03-03-2012, 10:09 AM   #4750
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,199
It works well on the 2008. You want to try it? I might sell it but you're welcome to try it first.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 03-03-2012, 02:16 PM   #4751
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,376
Put CJ's plate on w/a Rotopax mount
2 Gallon Rotopax
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 03-03-2012, 02:50 PM   #4752
Supahflid
Wheelieless
Oddometer: 3,795
2 Gallon Rotopax
I just did that too. Are you going to leave it on when you are doing close to home or day rides? I'm thinking I might remove the tank and the bolt that holds it on when just tooling around.
Supahflid is offline   Reply With Quote
Old 03-03-2012, 03:02 PM   #4753
TheMuffinMan
Oddometer: 6,376
I'm going to remove the tank and bolt for around town stuff too.
Old 03-03-2012, 04:01 PM   #4754
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,943
This-
Added the new ADV sticker today
It's not an adventure until you cross a bridge , 2011 WR250, 2015 ktm 690r
findLadukebob
Ladukebob is offline   Reply With Quote
Old 03-03-2012, 04:13 PM   #4755
southernADV
southernADV's Avatar
Oddometer: 112
In Argentina cost 35000 US dollars for the standard version!!
Never enough.......
southernADV is offline   Reply With Quote
Times are GMT -7.   It's 11:08 PM.
