Old 03-02-2012, 08:54 PM   #1096
PBee
_
PBee's Avatar
Oddometer: 9,158
+ 1 for Matt's bash plates. case protection is second to none.
As you can see in this pic
QUORN SCHNITZEL CLUB Est 2011.
When in the FLINDERS RANGES SA stay at the
ANGORICHINA VILLAGE
PBee is online now   Reply With Quote
Old 03-02-2012, 10:38 PM   #1097
boy60
boy60's Avatar
Oddometer: 713
The standard plate does not protect the electrics any way. The tourtech protects the engine alot more than the original. .
boy60 is offline   Reply With Quote
Old 03-02-2012, 10:41 PM   #1098
Meico640
Oddometer: 264
Rock on Rock Hard
Def +1 on the Rock Hard
I have one on my 640, bloody brilliant !!!
Wouldn't be without it, it has saved my fuel tap, my feet, my levers, my body work & my butt on numerous occasions.
Spoke to Matt recently to organize one for my new 990 !!!
Meico640 is offline   Reply With Quote
Old 03-03-2012, 12:10 AM   #1099
MudratinOz
Adventurer in training
MudratinOz's Avatar
Oddometer: 913
although they are the ducks nuts, I couldn't afford a Rock hard plate just atm, so went for the a Weld86 plate
should protect the new mukini Fuel pump nicely
KTM 2012 990 ADV ABS - BLUE
The orange does grow on you. You will not notice it at first..but it starts with a few innocent KTM stickers,.progresses to a KTM key ring, to KTM coffee mug and next thing you know, you have gone completely mad and start wearing orange tee shirts.It is a very bad infection..is this yeast infection (Bronx)
MudratinOz is online now   Reply With Quote
Old 03-03-2012, 02:08 AM   #1100
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,488
I made a kevlar/carbon one... but ran out of time to fit it and the bike hasn't been home since July. I'll find out if it works eventually....
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is offline   Reply With Quote
Old 03-03-2012, 04:07 AM   #1101
hattah79
hattah79's Avatar
Oddometer: 965
Rear caliper not sliding
Went to do a rear pad change friday night A quick 10 miniute job right
WRONG
Caliper would not slide off mounting bracket
Remove caliper rip rubber boot to peices and saok over night with CRC
Tried to sepperate this morning still not moving
I enlisted another pair of hands and the wifes hairdryer We heated the bracket
Several hits with a brass drift and apart it comes
The pin was rusted and pitted
I had a spare boot kit and pin so i was able to get it back together quickly
I check and regrease these pins on my 640 at tyre change or any time I have wheels out
This will now be a regular accourance on the 990
But why has it never been looked at before
Probally because its not in the service list
So keep an eye on them
hattah79 is online now   Reply With Quote
Old 03-03-2012, 05:09 PM   #1102
Oldfatbeerman
Enroute to a PUB
Oldfatbeerman's Avatar
Oddometer: 3,846
Originally Posted by ozimick View Post
Ye ye, OFB. Thats real interesting and all, but what I would like you to tell us about is that there fuel pump you have hanging off the side there. Did you fit it ? where did you get it ? had any problems with it etc etc
Mick
Mick , Yep , I fitted it , bought it from T. D. Hatrick in Townsville ( importer ) direct , about $120 IIRC . Just fitted the vacuum hose to the carb balance vacuum out let on the front cylinder and hooked her up from the tank and to the carbs , done about 5,000 km now and I have run the fuel down to within the last 1 liter of fuel in the tank and no issues , I think the key to that is have it below the lowest point of the fuel tank . Fuel pump problem solved for me .
It does not matter how much lipstick , lingerie , botox or other beauty enhancing products you put on or in a Pig , it is still a PIG .
Oldfatbeerman is offline   Reply With Quote
Old 03-03-2012, 06:08 PM   #1103
MudratinOz
MudratinOz's Avatar
Oddometer: 913
Mick, Al, my pump was $66 posted, from T. D. Hatrick
http://www.mikunioz.com/pulse_fuel_pumps.htm
Old 03-03-2012, 06:36 PM   #1104
MudratinOz
MudratinOz's Avatar
Oddometer: 913
Awsome, thanks OFB and Muds , I"ll chase it up with T.D. I see you both have a different model pump from same supplier.... I guess they willl know what I need
Only difference between the pumps is ltr/hr iirc one is 33 and the other 35, OFB's is a flat mount base mine isn't. all depends on where and how your wanting to mount it.
Old 03-04-2012, 11:42 PM   #1105
The Bigfella
Big Adventurer
Oddometer: 2,488
The Super Enduro is fixed... thanks to Shark at Bali Harley Doctor... and a steal at only 3,600,000 Rupiah. The issue ended up being crud in the carbies. I guess I could have avoided it if I'd been prepared to trust my mate here with the keys. I'd trust him with my life.... but I'm not quite ready to trust him with the keys. I thinl the temptation would have been too much for him.
Off to the Bromo volcano over the next couple of days.
Old 03-05-2012, 01:07 AM   #1106
Meico640
Oddometer: 264
Damper & risers
Has anybody got any ideas for a damper & risers for my new 990 (when it arrives at the end of the month )
I'm 6' 1" so need to get the bars up a bit...
Old 03-05-2012, 02:27 AM   #1107
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,106
You should have said you meant the 990, mine were the Emig Top triple clamp and Revolution 2 Damper from Emig Racing in Orange anodising in a 3in rise. Paige is really good to deal with, excellent customer service.
Andy
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690 EVO 1 Rally Raid Build Thread
KTM 690 EFI Idiots Guide
KTM 690 Troubleshooting Guide
El Ponkin is offline   Reply With Quote
Old 03-05-2012, 02:51 AM   #1108
PBee
_
PBee's Avatar
Oddometer: 9,158
Scotts Triple clamp, Damper & Rox risers.
With a 100mm longer braided brake line.
ANGORICHINA VILLAGE
Old 03-05-2012, 03:47 AM   #1109
fat spider
Scary Adventurer
fat spider's Avatar
Oddometer: 45
Try the link below and keep your money in Aus, advantages , local servicing, no need to replace top triple clamp, uses a riser that moves the bars forward as well as up which is essential.
I have this exact setup on my own 990 and are more than happy.
http://www.rallemoto.com/contents/en-us/d40.html
fat spider is offline   Reply With Quote
Old 03-05-2012, 03:02 PM   #1110
Meico640
Oddometer: 264
With ya,
I have the Rallye Moto on my 640ADV full kit with triple clamp,
The only prob is that they didn't make risers to go with it.
It seems that it is the same kit that goes on the 990( might do a swap)
Their new kit seems to have sorted this out & they are sending me some new risers at a very good price to compensate. Onnya Vaughn.
I was just wondering what other people had done
Times are GMT -7.   It's 05:20 AM.
