Old 05-06-2011, 10:29 PM   #331
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
Originally Posted by PFFOG View Post
Not true with CCI, as the LH bearing is SHIELDED!! The air fuel mix is shrouded from the mix, and the lower end bearing is also shielded by smaller slits in the rod, than a pre-mix motor.
Look at the diagrams or take one apart, it is very obvious that disconnecting the injection will lead to failure of the bearings.
Copy all. Vtwin was asking about his 'little M31' two-stroke, saying it was strictly pre-mix. If his M31 is supposed to be a CCI system, then by all means, he should be using the pump.
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 05-07-2011, 08:31 AM   #332
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,392
Thanks GP. Really seems like it's just not enough oil to lube bearings in pre mix, but they've been like that for years, so I guess it works.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 05-07-2011, 11:35 AM   #333
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,236
Originally Posted by vtwin View Post
How does my little Suzuki M31 two stroke get lube to the crank since it runs strictly premix?
It's actually more about shielding of the bearings.
Suzuki copied SAAB's oil injection concept for the Sport, Shrike, and Monte Carlo 850 cc engines, all of which have an oil injection system that forces oil directly into the main crank bearings and the cylinder walls. To keep the oil in there from getting too diluted, they also had some extensive stamped metal shielding that covered the main bearings and crankwheels. The upside of all this complexity is that the cranks on these Suzukis are "stuffed", which in laymen's terms means that all the lower end open space is reduced to a minimum and this makes for more efficient transfer scavenging.
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 06-20-2011, 08:36 AM   #334
pjhorgan
Oddometer: 14
Jenna,
I had a TS185, too... my first bike. It was a '71. Then I had a string of Suzuki two-strokes after that. Learned to soup them up quite a bit... they were over-engineered and came with a 12,000 mile warranty, so you could really work on them with a die-grinder. Used to replace the head gasket with tin foil, file 5mm off the piston intake skirt, port and polish the cylinder, put on a Bassani pipe and almost double the horsepower. Of course, that wasn't too hard, since, stock, it only had 11 hp!
Also installed "long travel " shocks from Curnutt, in California, and put preload spacers and heavier oil in the front forks. Geared way down, it was a pretty good mountain climber.
Later, my father got one, and we souped it up some as well. Wish I still had one.
Enjoy!
Pat
08 WR280R
01 DR650
87 XR250R
06 Z750S
pjhorgan is offline   Reply With Quote
Old 06-20-2011, 09:12 AM   #335
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,487
so why haven't I gotten to ride this thing yet? That oil pump oughta take a half hour to install. Back to work ya bum!
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 06-20-2011, 10:27 AM   #336
blaine.hale
blaine.hale's Avatar
Oddometer: 3,104
Jenna, we added a 2nd Bultaco to our house hold. When are we starting a gang and tearing up urban trails?
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is online now   Reply With Quote
Old 06-20-2011, 05:32 PM   #337
hardwaregrrl OP
ignore list
hardwaregrrl's Avatar
Oddometer: 7,402
Dammit....I knew there was something I was supposed to be doing these past few months. She runs great! I'll post pics up tonight. Having electrical issues at the moment. Need tires and the damn registration from the stoner I swiped her from...but it's all good.!
hardwaregrrl is online now   Reply With Quote
Old 06-20-2011, 05:58 PM   #338
jkpell
nOOby
Oddometer: 3
you didn't by any chance get this from a chap that lives near Newnan did you?
jkpell is offline   Reply With Quote
Old 08-14-2011, 11:23 AM   #339
vtwin
vtwin's Avatar
Oddometer: 7,392
Jenna, glad you fixed all your issues. I am going through all this with my two little Suzuki smokers. Takes for ever to start my little K11p and my M31 only really started and ran once since Jan 1st.
Monroe.
unknown
Old 08-14-2011, 11:04 PM   #340
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,485
Pics, my ass! It didnt happen! :
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 09-18-2011, 02:22 AM   #341
john479
john479's Avatar
Oddometer: 113
Hi, a month since the last post but I'll give it a go.
I recently bought a TS250 1981. Runs great but I have a leak coming from where the neutral switch cover should be. I am going to get a cover for it but I was wondering should it leak with no cover? The seal is strange as it has a metal ring around the shaft and then rubber. The cover that I will get has an o ring so is it this that is supposed to seal it?
I have attached a pic of the shaft and seal.
Thanks very much for any help.
John
john479 is offline   Reply With Quote
Old 09-18-2011, 05:43 AM   #342
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 2,564
Originally Posted by john479 View Post
.................The cover that I will get has an o ring so is it this that is supposed to seal it?
John
Yes the covers had o-rings that sealed them, they will leak with no cover or if it gets cracked.
PFFOG is online now   Reply With Quote
Old 09-18-2011, 06:31 AM   #343
john479
john479's Avatar
Oddometer: 113
OK, thanks very much
Old 03-03-2012, 05:12 AM   #344
C-Stain
C-Stain's Avatar
Oddometer: 6,084
Hey Jenna!
What ever happened to those pictures you promised? I'm getting more and more gray hair waiting!
Originally Posted by Mr_Gone View Post
C-Stain is wise.
C-Stain is online now   Reply With Quote
Old 03-04-2012, 02:07 PM   #345
hardwaregrrl OP
ignore list
Oddometer: 7,402
Originally Posted by C-Stain View Post
Hey Jenna!
I know I suck. Just drug a SL350 home and a R90 S, so I've got my hands full. I will be getting back to the TS soon, I promise.
Times are GMT -7.   It's 04:33 PM.
