02-28-2012, 10:19 PM
#946 | |
Tilting the Horizon
Oddometer: 1,433
03-02-2012, 04:44 AM
#947 |
TONKA
Oddometer: 4,871
Does somebody make have handle bar risers for the Ninja 250? I am concerned about the rider's position as I have back issues and need to set up right. Much like the LEO riders to be comfortable.
Thanks Bill |
03-02-2012, 05:32 AM
#948 | |
Riding is my passion
The 2nd gen's are a bit more aggressive, but compared to most sport bikes, still not bad at all. I do find the 1st gen's much more comfortable though.
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
03-02-2012, 06:02 AM
#949 | |
TONKA
Oddometer: 4,871
Thanks |
03-02-2012, 06:51 AM
#950 | |
Here's the MCL risers I found with a search - http://www.motorcyclelarry.com/index...roducts_id=106 And an article about installing them - http://grayraven.com/JimNtexas/?p=395 I'll see if I can find any others Edit:. Twisted Throttle sells some, but they look pretty close to the MCL's, but are a bit more expensive - http://www.twistedthrottle.com/trade/productview/2956/ ![]() - http://www.rlmotorcycles.com/GenMar-.../gm%20k108.htm
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU BlueLghtning screwed with this post 03-02-2012 at 06:57 AM |
03-02-2012, 09:32 AM
#951 |
insert pithy saying here
Oddometer: 432
I've got the TwistedThrottle bar risers above and they work really well. I also have back issues and the risers keep me mostly upright with just enough forward leaning so that the weight is off my low back/sacrum (where my injury is). Very worth the money, IMHO!
03-02-2012, 04:28 PM
#952 |
TONKA
Oddometer: 4,871
Thanks to all! This gives me some options. My back issues are 4 herniated disc in mt Thoracic area. Or between my shoulder blades. So being in the lean forward position for very long would kill the deal for me.
03-02-2012, 09:24 PM
#953 |
Oddometer: 1,920
Did you have to change any cables? brake line?
"Limbautomy" what's the Rush? |
03-03-2012, 12:13 AM
#954 |
Oddometer: 432
Nope, straight swap.
The only trick is that when you put the longer bolts on for the bar risers, make sure that you clear the wiring harness that runs under the handlebar on the lefthand side. When I installed my risers, I accidentally punctured that harness and caused a short that prevented my brake lights from working. Easy fix, but equally easy to avoid if you know about it in advance.
03-03-2012, 06:17 AM
#955 |
Oddometer: 581
I'm thinking of trading my KLX250S for a Ninja 250. Its a 2004 I'm looking at. I'm not in love with the looks,(I think the 08+ looks fantastic) but I might be able to overlook the looks if the bike is as fun as it looks.
I have a Ninja 650 and think that bike is about as fun as the TL1000R I had(though I miss that bike too) I'm thinking the Ninja 250 willl be as fun as the Ninja 650 but in a lighter more playful way.
2005 Ninja 250 -WTT or WTS $2400 OR KLR650, TU250, W650..sportbikes, naked bikes...whatever... |
03-03-2012, 09:34 AM
#956 | |
Oddometer: 1,119
Also consider the Wr250x. Same amount of fun, a little more power, but less heavy. |
03-03-2012, 11:02 AM
#957 |
El cheapo
Oddometer: 4,890
Cost about 3x more than a used Ninja 250, will you be having 3x more fun?
03-03-2012, 11:52 AM
#958 |
Oddometer: 1,119
So the ninjette is the only bike anyone should ever buy because it's some fun and very cheap?
njd screwed with this post 03-03-2012 at 12:03 PM |
03-03-2012, 12:18 PM
#959 | |
El cheapo
Oddometer: 4,890
Would you spend 3x the money just to have the same amount of fun? |
03-03-2012, 03:01 PM
#960 |
Oddometer: 1,119
I wouldn't have much fun on the ninjette...at least not after 20 minutes. I used to own the ex500 and even at 5'11" found the bike to be too small and uncomfortable.
