Go Back   ADVrider > Riding > Trip Planning > Americas
Old 03-09-2012, 09:17 AM   #1
jc99 OP
Oddometer: 18
Baja Garmin GPS maps
Has anyone used any of these? I just bought the Garmin montana and was thnking of buying the Baja Gps maps for it. There are several online. Thoughts of which one is better?
jc99 is offline   Reply With Quote
Old 03-09-2012, 10:12 AM   #2
WilderRider
WilderRider's Avatar
Oddometer: 1,805
If you look in the GPS forums you will see plenty of discussions about the various maps. Personally I like to route at times, so i went with Bicimaps for all of MX. it had all of the trails I needed at the time.
RISK: "The loftier your goals, the higher your risk, the greater your glory."
WilderRider is offline   Reply With Quote
Old 03-09-2012, 04:25 PM   #3
stickman1432
Crusty Adventurer
stickman1432's Avatar
Oddometer: 764
Try LBMAPS.com for Baja maps they work great in the Garmins. Plus if you like maps get the hard copies of the Baja Almanac,
Rich
R1200GS-08', WR250R-08'
XR650R-03', 110 Honda-83'
stickman1432 is offline   Reply With Quote
Old 03-10-2012, 07:27 AM   #4
jc99 OP
Oddometer: 18
Is city navigator enough or do you need the Baja specific maps?
Old 03-11-2012, 07:29 AM   #5
lexluther11
Ride,Eat,Rest-Repeat
lexluther11's Avatar
Oddometer: 1,200
I would say yes plus a paper map.
lexluther11 is offline   Reply With Quote
Old 03-11-2012, 07:56 AM   #6
Colorado Uli
Motociclista Non Elegante
Colorado Uli's Avatar
Oddometer: 2,570
I carried two different types of paper maps AND the LB GPS map and found that none were perfect (although the LB map is good).
The roads there change too fast for accurate updates. Sometimes I'd run into brand new paved highway in the middle of nowhere and other times I'd try to follow a road on the map and it would be almost completely gone (washed away and abandoned).
Ask the locals, ask here, and use common sense -- don't be afraid to turn around -- when in Baja and you'll be fine.
Something, something, something ... in latin.
"Now with more SE then ever!"
Das KTM520
2004 KTM 625 SXC - Sick. Getting better
Colorado Uli is offline   Reply With Quote
Times are GMT -7.   It's 03:10 PM.
