Old 03-15-2012, 10:13 AM   #1
MAXVERT OP
Rough Rider
MAXVERT's Avatar
Oddometer: 829
Fuel Line Quick Disconnect
I need to replace the fuel line quick disconnect on my 990A.
Has anyone found a better and less expensive set.
A stronger set than the stock plastic ones would be good.
What's the hose I.D. ?
Thank,s Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 03-15-2012, 11:04 AM   #2
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,065
Mine broke last summer, I couldn't believe what KTM wants for a replacement! And they charge for each end, both male and female.
So I ordered mine from Justgastanks.com after I couldn't source one locally, the same damn thing (only white) at half the cost.
I'm pretty sure this is the one I got and you want: 5/16" with dual shut-offs (but double check the hose size, I'm just going from memory):
http://justgastanks.com/product_info...oducts_id=1965
Same damn thing, down to the factory markings.
viola-tor is offline   Reply With Quote
Old 03-15-2012, 12:49 PM   #3
MAXVERT OP
Rough Rider
MAXVERT's Avatar
Oddometer: 829
Great thanks,
Max
Da oggi la strada
é senza limiti
Old 03-15-2012, 01:27 PM   #4
PowerCell
SE990R
PowerCell's Avatar
Oddometer: 1,928
Originally Posted by viola-tor View Post
I ordered mine from Justgastanks...
Or... for one-third the price...
http://www.mcmaster.com/#catalog/118/202/=goe674
~ Ken
PowerCell is offline   Reply With Quote
Old 03-15-2012, 02:14 PM   #5
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,065
Even better! Touche!
Old 03-15-2012, 02:31 PM   #6
hontri
Global Bummer!
hontri's Avatar
Oddometer: 266
Thank,s Max
I got mine here and they have a shitload of other cool fittings! http://www.industrialspec.com/
If you don't like the plastic they have them in chrome plated and brass
hontri screwed with this post 03-15-2012 at 04:17 PM
hontri is offline   Reply With Quote
Old 03-15-2012, 04:44 PM   #7
Uller
Uller's Avatar
Oddometer: 558
Here is a metal option:
http://www.beemerboneyard.com/cpcqkdiscon1.html
Uller is offline   Reply With Quote
Old 03-15-2012, 04:48 PM   #8
PowerCell
SE990R
PowerCell's Avatar
Oddometer: 1,928
Originally Posted by Uller View Post
Those are also available at McMaster for less than half that price. Chrome plated brass...
~ Ken
Old 03-15-2012, 04:56 PM   #9
Chuckracer
More Ride, Less Google
Chuckracer's Avatar
Oddometer: 5,760
What size, 5/16"? (I'm lazy... )
2003 Kawasaki KLR650 "Reality"
1993 Ducati 900SS "L'evento"
Chuckracer is offline   Reply With Quote
Old 03-15-2012, 04:59 PM   #10
Uller
Uller's Avatar
Oddometer: 558
I do believe it is 5/16". I can dbl check in a couple of hours and give you a certain answer though.
Old 03-15-2012, 05:00 PM   #11
Uller
Uller's Avatar
Oddometer: 558
I probably shouldn't have put anything Beemer related in here anyway. Thanks.
Old 07-06-2012, 10:05 PM   #12
Zathan
RideGrinRepeat
Zathan's Avatar
Oddometer: 1
I just replaced mine after dropping the bike 100 miles from nowhere and riding home with a fine mist spraying on my leg the whole way home. No damage to the bike other than the mystery of a cracked QD. It is definitely 5/16". I picked one up from coyote (http://www.coyote-gear.com/quickdisconnects.html) as it was not too far off from me and shipping would be quick. Much better QD and great customer service as well. I also went ahead and replaced all the fuel line with HP fuel injection line rated to 250psi. Overkill I know but the $10.00 in hose is just insurance as far as I am concerned.
Zathan is offline   Reply With Quote
Old 07-08-2012, 08:45 AM   #13
cat
cat's Avatar
Oddometer: 1,291
i got Jiffy-tite, like this...
Made of lightweight, 6061-T6 aluminium, brass valves, and stainless steel ball bearings, they are corrosion resistant for extra long life.
Jiffy-tite is the only Quick-Connect fitting on the market today approved for use in all categories of NHRA and IHRA. They are also accepted for use in SCCA for virtually ALL fuel, water, oil and transmission applications.
# Plug and Socket Assembly Lighter than any in the Industry
# Black and Gold anodised
# Constructed of 6061-T6, Brass Valves, & Stainles Steel Ball Bearings
# 360° Swivel
# Compact, Lightweight
muuuch better.
cat is offline   Reply With Quote
Old 07-08-2012, 03:19 PM   #14
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,695
muuuch better.
Now thats Quality
I likey much better than the Motion Pro unit I bought
Brown Dog is offline   Reply With Quote
Old 07-09-2012, 05:16 PM   #15
gbx2001
Geophiz
Oddometer: 63
I have limited experience with quick connect couplings (QDs) so I would appreciate feedback on my question. I have a multi-fuel camp stove will run on gasoline, as well as white gas, kerosene, etc.. How feasible would it be to fill my MSR stove bottle via the quick connect coupling? Is there a better way to do this? I am trying to simplify for a longer trip so I am trying to fugure out the best way to approach this.
Feedback would be appreciated!
gbx2001 is offline   Reply With Quote
Times are GMT -7.   It's 01:08 AM.
