03-21-2012, 04:29 PM
#2461 |
Location: Middle of Insanity - Right of the Mississippi!
Oddometer: 6
Installing the IICE Air on the R1150GS
Here is a short, illustrated installation guide for installing the IICE Air on the R1150 GS (Sorry for the quality of the pictures):
1.) Remove seats - Remove both seat. 2.) Remove Right Black Plastic Panel below Tank and find a Suitable Location to Mount the IICE Air - I found the best place to mount the IICE Air on my 2000 R1150GS was on the frame rail just below the lip of the right rear lower edge of the tank. Position the two leads of the IICE Air behind the frame and up under the rear lip of the tank to the area located center line of the tank. 3.) Attach the IICE Air - You can now attach the IICE Air to the frame rail (or wherever you want) with two nylon tie straps through the holes on the IICE Air around the frame. 2.) Locate Air temp sensor - You will find the Air Temp sensor right under the rear lip of the gas tank. The Sensor has a wire connector attached to it with a "female" plug -- this plug has a metal "bail" on it that must be depressed fully to release the connector. The "bail" faces toward the front of the bike. ![]() 3.) Remove the "Female" Plug from the Air Temp Sensor - The Sensor has a wire connector attached to it with a "female" plug -- this plug has a metal "bail" on it that must be depressed fully to release the connector. The "bail" faces toward the front of the bike. Depress the connector and carefully pull the plug up from the air temp sensor. ![]() 4.) Connect the "Female" connection that you just removed from the Air Temp Sensor to the "Male" connection lead from the IICE Air. The metal bail from the female connection from the Air Temp Sensor will "Click" when positively attached. Check the connection ![]() 5.) Connect the "Female" connection from the IICE Air to the Air Temp Sensor. Make sure that you have a positive connection! -- The metal bail from the female connection from the IICE Air will "Click" when positively attached. Check the connection. ![]() 6.) Recheck your connections. 7.) Recheck the mounting of your IICE Air. 8.) Re-install the Black Plastic Cover located beneath the Tank. 9.) Re-install the seats. 10.) Enjoy the increased performance, the lack of surging -- Ride like the wind! |
03-21-2012, 05:00 PM
#2462 |
Syndicated
Oddometer: 11,285
You absolutely rule, Keith! (kandersn) Top shelf!
03-21-2012, 05:06 PM
#2463 |
Oddometer: 6
Could not have Done this Without Poolside!
Poolside:
I could not have created that short install guide without your super product! I can't wait to see how my bike performs after getting the IICE Cool! Waiting patiently for that day... |
03-21-2012, 05:10 PM
#2464 |
Stubbly Adventurer
Oddometer: 857
03-21-2012, 05:28 PM
#2465 | ||
Momma's Boy
Oddometer: 92
The pictorial above is pretty sweet. If anyone wants the pictorial of where they should NOT connect their IICE Air, pm me...I can show you on both an 1150 and a 1200... |
03-22-2012, 06:32 PM
#2466 |
Oddometer: 1,048
Not so fast! It was my understanding that plugging it into the fuel injector would cause the implosion of the sun.
2013 KTM 350EXC-F 2007 KTM XC300 (for sale!), 2005 BMW R200GS, 1984 Kawasaki GPz 750 |
03-22-2012, 07:58 PM
#2467 | |
Optimus Primer
Oddometer: 13,934
Wahoo...
![]() ![]() Once the feedback cycle initiates, it is near-impossible to redirect.
Splitting lanes, and splitting hairs. |
03-23-2012, 07:19 AM
#2468 |
Khan!
Oddometer: 988
What are the thoughts about dealer service with the IICE Air installed while under warranty?
Heading out for my 12k service at the dealer. Shouldith removeth?
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // BMW R1200GS 30th
03-23-2012, 07:44 AM
#2469 | |
gunna b adventuring
Oddometer: 4,836
Andrew, you got me to thinking. It seems that my riding gear is no longer water proof. This was discovered after installing the Air and was not an issue before. Wonder if there is a connection. Will the Cool fix the problem. I'm not one to jump to conclusions so more research is in order.
. I ride faster than I should but slower than I wish. I know there is risk, but I balance it against skill and luck and that act is a big part of why I ride motorcycles and why I bother with a trip like this. - Neduro "When injustice becomes law, resistance becomes duty." - Thomas Jefferson |
03-23-2012, 07:45 AM
#2470 | |
gunna b adventuring
Oddometer: 4,836
No
03-23-2012, 08:50 AM
#2471 |
Runnin out of Time
Oddometer: 52
Please excuse my "retard" question, but... how do valve adjusts and tb balancing work now?
Should the IICE Air be at the -20 or set jumper to bypass for this delicate "tune up" operation?: |
03-23-2012, 09:15 AM
#2472 | |
Heavyweight Boxer
Oddometer: 4,758
Via Tapatalk |
03-23-2012, 10:14 AM
#2473 |
Oddometer: 8
Hi Poolside/all,
Here's my experience after a few days of riding with the IICE Air: Bike: 1997 R1100GS, "Euro" model (no cat, no O2 sensor), ~220K Km Setup: all original, no mods, IICE Air at -20 default setting Result: I simply love it! Overall, the change is very subtle - my iron beast didn't transform into a racing cat...but after 4 years of ownership, I feel it finally gained my trust. I'm a "torque" guy, so I particularly feel the change in low RPM, when I'm pulling out from ~1000RPM in 2nd or 3rd (now even 4th) gear. No more of those annoying "hiccups", the throttle is great, acceleration has a "wet" feeling now, and the engine just pulls happily forward. As a side bonus, adding the IICE Air also eliminated all backfire issues that occurred randomly every now and then. Oh yeh, and I have no idea why, but my ABS used to fail on almost every start due to a weak battery...issue solved ![]() to summarize - exactly what I needed! great job! now lets talk about that Cool thingy...
03-23-2012, 10:29 AM
#2474 |
Almost Famous
Oddometer: 735
03-23-2012, 10:36 AM
#2475 | |
Random Hooligan
Oddometer: 6,169
Of course, my opinion is what you paid for it.
-Scott- Semper Fi '04 BMW R1150GSA, '97 BMW R1100GS (For Sale), '08 KTM 450EXC-R, '04 KTM 625 SXC "A pessimist thinks all women are bad. An optimist is one who hopes they are." Chauncey Depew
