03-30-2012, 12:10 AM
#91 |
Oddometer: 1,353
Super busy for a little while, but wait on wiring mods, theres an issue or 3, hint, none of those threads had issues with voltage going down as rpm's raise and as for the AC wiring, supersize them only if you wish to add a few days to the life of your battery by taking months off the life of your stator
Alpi I have seen that video before, and though it may or may not technically be considered a fire, it wasn't very exciting, just a bunch of mostly steam. His charging system went super high voltage when his regulator went full tilt. A lead acid battery is actually more exciting under those conditions so I don't consider that occurrence noteworthy except in that nothing particularly bad happened and the smoke/steam looked cool. Find me flames that I can se and I will get more reactive :) NDC it means your stator will last longer because the clamping voltage is higher resulting in lower stator current and heating, but probably not much longer. Only thermocouple couple tests will tell how much, the math is beyond nearly everyone and miles beyond me. P.S. this: http://www.youtube.com/watch?v=BPwPB...feature=colike cracked me up. Not scientifically meaningful, but very funny because I am always amused when people get opposite results of what they were expecting.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250 I love and miss you Jeneca and I'm sorry. |
03-30-2012, 04:01 AM
#92 | |
Oddometer: 73
... and later in the same thread: "On a lighter note, I was contacted by Shorai today. They want to know how much it will cost for the entire repair of my bike, my labor time included, and are going to reimburse me for that amount." It sounds like open fire, which fortunately damaged only some bike parts, before the owner managed to pull the cable, as far as I can tell...
'07 G650 XCh (and '04 recumbent bike) alpi screwed with this post 03-30-2012 at 07:33 AM |
03-30-2012, 06:16 AM
#93 | |
Oddometer: 3,433
03-30-2012, 06:27 AM
#94 | |
Oddometer: 2,757
Erling (ps).... It is important to know...that this will not fix the imbalance between idle and at rpm voltage... But merely lower the ressistance in the wires....allowing for the voltage to jump a little... But if that is enough...to tip the charging system to work by maintaining the battery correctly....then have at it.. We will find out. (pps).. Joel.... as mentioned before.... we ( me and others) are cluttering your thread....with this stuff.... So please let us know when enough is enough....
03-30-2012, 09:43 AM
#95 | |
Oddometer: 3,433
![]() I would have thought that raising the output voltage (it it worked) by supersizing the wires would add life to the stator as the current flow thru the stator would be reduced ... |
03-30-2012, 09:52 AM
#96 | |
Oddometer: 1,353
Burning plastic produces a header of black smoke visible for miles. There is NOTHING on that bike that will contain a fire. And in either case, pulling a battery cable will not do the remotest thing to slow a battery fire because if the battery and not a short is the cause of the issue, what you have is shorting cells IN the battery. If it is a short external to the battery producing smoke, sure, pulling the cable will remove the cause, but lead/acid batteries will start external shorts burning or smoking just the same. Anyone concerned, look at the picture in the link. Thats steam from boiling electrolyte and likely some vaporizing plastic. I'll bet that battery got super hot, shrink wrapped its case and melted the insulation of wires touching it, all of which I have seen lead acid batteries do. Notice the op set his helmet carefully on the ground next to the front wheel, something sport orders do not do if concerned about real fires. Here is some real fire coming out of a LiFePo4 cell. The guy demonstrating is a nut of my favorite sort who I correspond with. In his previous attempt, putting an 80 amp 22 volt charger on a single cell only made the battery label melt before the cell opened internally, so he went at it again with a 1500 watt heat gun simultaneously with the 80 amps and managed to create fire. On a power sports battery, there are 4 cells in series, so this would require 88 volts, and a heat gun. No bike or car charging system can do this, and even if they could, all the other electronics on the bike would shoot fire long before. Here is the video: If you want to see where the fire and explosion concern comes from, click on some of liveforphysics532 other videos to see what the dangerous lithium chemistries can do, and note, what the LiFePo4 cell did is boring compared to what a lead/acid battery will do under 5x over voltage, 8C charge rate with no heat gun required. At the least with lead/acid you will get a ball of fire 10X the size of the battery and acid everywhere including your eyes. I am SOOOO not impressed with Shorai batteries to date, but I find zero evidence they are a fire hazard.
03-30-2012, 10:51 AM
#97 | |
Oddometer: 1,353
My past measurements indicate this might be good for as much as 0.11 volts, cause thats all the drop there is in the wires from the R/R to the battery. You may also get unintended consequences as the big culprit of under voltage with the K7X is that the stator rings the R/R mildly and the R/R sensing circuit is not buffered and there fore clamps on the spikes rather then the RMS as it should. But it may work for some additional voltage. Heck, if it reduces the ringing of the R/R sensing circuit, it may be good for more voltage then that. Modeling voltage ringing is hella hard, so the only way most people do it is to try it and find out. Note that these wires are unfused so be cautions mucking with them / adding parallel paths for current and fire. Supersizing the AC wires from the stator to R/R removes external resistance before the shunt and will heat the stator that much more and won't affect voltage (unless it reduces ringing) as regulation happens downstream of this. It will increase current slightly, but at the cost of shortening the life of an already short lived stator. No one has said "Joel, what the heck is ringing?" But I will answer anyway lol This is a K7X ringing: ![]() We are looking at the output of the R/R at the precise instant it stops clamping (the R/R is a duty cycle on/off affair. Basically the voltage bounces as the SCR's open. We are looking at a tiny division of time (20 microseconds per division).This is normal though fairly large on the K7X. What is abnormal is the R/R fitted to the K7X, at least the one that does not end with "SC", senses this super brief spike and clamps for it which is stupid because SCR's are not NEARLY fast enough to clamp this brief of a transient. The ringing is small at idle and much larger at RPM, hence voltage goes down as RPM is raised. Ringing is almost impossible to model and occurs when it does however bad it does in a given circuit. It is not harmful at this magnitude, but your R/R needs to ignore it and regulate on RMS average voltage, not the peaks of ringing. Put a huge choke around the R/R output and a capacitor in parallel and it kills the ring where upon the RPM voltage becomes the same as idle. This is not practicable as the choke required adds weight and the capacitor is big. Interestingly, I have an SC regulator in my possession and it does seem to ignore the ring. I am about to do the true CCA test on the last of 3 batteries in my possession, AKA something related to this thread :p Here is a pic: ![]() of desolating the 5 month old battery in preparation for hammering the hell out of it. CTEK 4.3 charger I am in love with in desolate mode applying 15.7 volts to the battery. Deka AGM battery construction, like Odyssey is extremely tolerant to high voltage for desulfating. Note, the battery is only drawing 0.23 amps. It is mildly gassing and not venting at all confirmed with flammable gas sniffer. Try this on a Yuasa AGM and at least you will dry out the battery and may even get to see it gizz electrolyte. Soon as this next test is done, I will be posting video of true CCA of 3 comparison batteries (Deka ETX14, Yuasa YTX12, and Shorai LFX18). I also began testing a Shorai LFX21 but aborted because it is not going back to Shorai and I didn't want to hurt it. Loads of time consuming work but the results are more eye opening then capacity tests so hopefully the results will be meaningful. All for now....
03-30-2012, 11:04 AM
#98 |
Advenchaintourer
Oddometer: 1,989
Long thread so havn't read it all yet.
What I do know is I have seen these shorai lightweight batteries fail at the track. They are intended for track use and still they fail or loose charge. What is more of a problem is you CANNOT charge them without the Shorai special charger. That = no go for me on a touring adventure bike. Is there more to the story? Can I get the cliff's notes version? |
03-30-2012, 12:19 PM
#99 |
Oddometer: 2,757
Just ordered the meter....
Quote Joel: My past measurements indicate this might be good for as much as 0.11 volts, cause thats all the drop there is in the wires from the R/R to the battery. You may also get unintended consequences as the big culprit of under voltage with the K7X is that the stator rings the R/R mildly and the R/R sensing circuit is not buffered and there fore clamps on the spikes rather then the RMS as it should. But it may work for some additional voltage. Heck, if it reduces the ringing of the R/R sensing circuit, it may be good for more voltage then that. Modeling voltage ringing is hella hard, so the only way most people do it is to try it and find out. That's good enough for me..... I will do the beta testing to see if one can tip the charging system to a user friendly level.... As soon as it gets here... I'l hack it.... Erling |
03-30-2012, 01:22 PM
#100 | |
Oddometer: 1,353
1: does not exceed maximum charge rate printed on front of battery, which for the LFX21 is 21 amps. 2: Does not have a pulse or high voltage mode that is automatically engaged. 3: is set for a finish voltage of no greater then 14.4 to 14.7 depending on the LiFePo4 manufacture. Most lead/acid chargers meet all 3 of these requirements. Now for maximum life when the bike is layer up, all lithium like to be stored between 50 and 70% charged, so leaving it on a constant maintenance charger would only remove battery life, but many lead acid chargers shut down once charged unless the battery gets below a certain voltage, which is fine for LiFeP04 batteries. But you want to avoid maintenance chargers that have a pulsing maintenance desulfating storage mode. Interesting that I keep defending Shorai, because for touring or adventuring, I think their battery sucks! I'm just trying to make sure people dislike them for the right reasons so if they change their product in the future to something good, people won't be biased against them as I absolutely DO believe LiFePo4 chemistry will and should replace lead/acid batteries. Also, many of my Shorai complaints do not extend to all LiFePo4 batteries, just Shorai so far.
03-30-2012, 03:40 PM
#101 |
Advenchaintourer
Oddometer: 1,989
Ok, well then carry on.
Can't for the life of me understand why anyone would want one unless they were racing. Light is good if you need it. Charge is good when you need it. Dead battery is bad always. |
03-30-2012, 04:59 PM
#102 | |
Oddometer: 1,353
About 1/4 of the tow ins had batteries that failed entirely or were at least dead, some mid trip out of the blue. Fully about half of all those models towed in had issues totally unrelated to the battery or charging system BUT would fire right up when I hooked a booster battery or boost charger to them. The typical culprit was stuck fuel pumps, stuck fuel injectors, partially plugged injectors, or a sensor that was drifting out of parameters making the bike impossible to start with the stock battery. First while cranking I would feel the fuel pump hose to figure out if the fuel system was pressurizing, listen for the injector opening click and smell the raw exhaust for clues on fuel mixture. 60 seconds later I usually knew what was wrong or had at least greatly narrowed the possibilities, so next I would attach a large jump box or the big boost charger always in my stall and wham, start the bike right up as if nothing was wrong. I could do this because stuck pumps and injectors usually unstick when you have more voltage during cranking. Poor starting fuel mixture from poor injector patterns, wet plugs or drifting sensors can usually be overcome by cranking the engine faster and the hotter spark the ignition system makes when starting voltage is higher. I already knew if the fuel pump or injectors were stuck just by feeling and listening, but diagnosing sensors and injector patterns is much easier with the bike idling. Of the remaining 25% of bikes that wouldn't start with more starting voltage, usually leaving the bike key on for long stretches and cranking repeatedly was required to conduct diagnosis and find the culprit. In a dealership, getting more cranking voltage is a wall receptacle away and leaving the key on is no issue with a charger attached. On touring or especially adventure bikes, more CCA and Amp Hours are probably the single most likely thing to save you from a hike. The battery is the very first thing I have upgraded in every car and motorcycle I have ever owned. Because of this, at 38 years of age, I have only needed a tow truck twice. Once for a blown engine and once for a blown clutch. My diagnostic skills play into this but a powerful battery gave me the time to use them, and reduced the number of times I had to use those skills at all. The stock Yuasa/Excide F800 and R1200 batteries suck and stand a good chance of stranding you. The stock Deka battery is very good, but more is better and thats what I'm looking for in these LiFePo4 batteries, without success so far, but at least 2 more brands to go before I know. What does everyone think, make sense? or do I sound full of bull lol
03-30-2012, 05:12 PM
#103 |
Advenchaintourer
Oddometer: 1,989
Makes sense...
if you find one better than the deka let us know.... |
03-30-2012, 05:15 PM
#104 |
Oddometer: 2,757
Makes sense to me.....and your work is most appreciated.....
Erling |
03-30-2012, 06:22 PM
#105 | |
Oddometer: 1,353
I have high hopes for AntiGravities battery. The owner of that company is focused on quality and he has his FAQ's right unlike Shorai who's FAQ section is a blatantly false piece of advertising.
