Old 03-22-2012, 11:37 AM   #76
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,270
Originally Posted by SFKLR View Post
Still waiting on the 950 air filter here ...
BTW, what are "stacks"?
http://en.wikipedia.org/wiki/Velocity_stack
Basically the black horn looking things that stick out of the carbs/injectors.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 03-22-2012, 11:57 AM   #77
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,975
The RC8 Stack or "Trumpet" as KTM calls it is shorter than the 990 ADV ones.
Thinking is that the shorter stack should let it more air for higher HP#s.
The Longer 990 ADv ones result in more torque.
These will be here soon for testing.
BTW,
Air filters just showed up so I hope to start shipping out Fri and Sat.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 03-22-2012, 02:16 PM   #78
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
BTW,
The orginal stacks for the 990 motor (Adv,superduke,SM/T/R) are the same
The RC8 stacks with 2nd flies removed used in a airbox should give a gain starting from 6500rpm till limiter.
But it doesn't loose torque down below.
And the fun part is they cost allmost nothing, i paided 5 euro (6-7 US dollars).
example from a superduke:
http://www.superduke.net/forum/viewt...rt=625#p221658
'10 990SMT
Spark01 screwed with this post 03-22-2012 at 11:59 PM
Spark01 is offline   Reply With Quote
Old 03-22-2012, 02:33 PM   #79
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
Originally Posted by Locul@hotmail.com View Post
hi would these filters fit the rc8 or could it be done. my project is loosing weight where possible and this is very simple.
The RC8 stacks fit the standard 990 throttle body soo the hole size in the base plate are the same.
I measured the distance between the middle of the 2 holes and it is 12,6 cm
So if the distance between the middle of the 2 throttle bodies from the RC8 are the same...
And if you have more then 4cm distance between the throttle body and the frame...then it could fit??.
'10 990SMT
Old 03-22-2012, 02:53 PM   #80
Johnf3
Oddometer: 1,057
The ones for the carb'd 950s?
No 950 filters yet. Two more weeks at least.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 03-22-2012, 03:20 PM   #81
torinreality
metaconscious
Oddometer: 57
Has there been much discussion about socks for these filters? That'd be super convenient.
torinreality is offline   Reply With Quote
Old 03-22-2012, 03:23 PM   #82
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,147
I was thinking of takng mine down to Home Depot (when I get it) and see if one of the foam filters for a shop vac would be the right size. That would make it kind of a twin air.
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC
My2Wheels
dad2bike is offline   Reply With Quote
Old 03-22-2012, 03:35 PM   #83
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Originally Posted by tahoeacr View Post
That's good info. I've cut the bottom of the shelf in my glove box off to make room for sensors. I could do the same thing and see if their is some pressure in there. I usually have a tank bag on that holds my wide band and data logging so my glove box is always strapped down. Your shrouds are helping alot. A 950 that doesn't run the fan in Summer traffic.Great idea. I suspect that the fork legs create vortexes that probably spill over the stock fairing. The notch only being three inches from the radiator. Speculation of course since you can't really tell what's going on unless your in a wind tunnel. I've done some aero testing with various teams I've worked for. Some even had a big enough budget to afford wind tunnel testing. I thought that would be fun but it is one boring day I tell you. Looks like you have more than doubled that distance plus widened it out a couple inches. Nice mod with good results.
Suppose I could data log the airbox pressure sensor. Do some pulls on the dyno with no fans for a base line setting, then go ride and see what I get.
Just tying up a loose end here.......
I took some photos of the cover that was being lifted off at speed. As the air that passes through the radiator it is isolated from the carbes I know that the shrouds that I made are not responsible for pushing air to the carbes so this is air traveling through the steering stem area putting pressure around the carbes. My answer to the popping cover was to bolt it down This is the cover on the seat side lifting and flexing its clip open. It takes some pressure to do that.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 03-22-2012, 05:00 PM   #84
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,975
A lot.... we've been working on that. This project got huge before lots of little details could be worked out, but this will only get better.
Lots more info in Vendors.
Old 03-23-2012, 12:50 AM   #85
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,361
thanks. i will measure today.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 04-02-2012, 11:35 AM   #86
EdGear
Edventurer
EdGear's Avatar
Oddometer: 543
Got my CPR Rottweiler through CJ and installed it yesterday.
I had to remove the SAS which was a PITA.
Followed instructions in the HOW and was doing great until re-reading and noticing the Edit at the end.
Had to remove the throttle bodies again to add the intake vent connection.
Anyone tell me what purpose the intake vent connection serves, pressure balancing?
Once you have the air box off there is lots of room to work and installing the Rottweiler is pretty straight forward.
I was worried about water splashing up and heat coming off the engine.
I made a prototype barrier under the Rottweiler base plate out of aluminum flashing.
Put everything bad together and the bike started fine, no SAS FI faults.
Looking straight down to see flashing in front of filter
Once I get the flashing dialed in I use slightly thicker material and add heat shield.
I'm also thinking about raising up the glovebox base about 1/4 inch.
This would form a slot all the way around the glovebox mask to allow air in.
Should work even with a tank bag.
2010 KTM 690 Enduro R
2006 KTM 950 Adventure S
2002 KTM 400/453 EXC
EdGear is offline   Reply With Quote
Old 04-02-2012, 11:46 AM   #87
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,895
What is your plan for mapping?
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 04-02-2012, 01:48 PM   #88
EdGear
Edventurer
EdGear's Avatar
Oddometer: 543
I have a 2 into 1 with Akra with quiet insert. This ran fine with the stock map. I'll give that a try but will be learning how to use Tune ECU shortly.
Old 04-02-2012, 03:55 PM   #89
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,975
I've update my other thread on the next batch.
You can email CPR for a FI Map to try out based off there dyne testing.
Something to try at least.
Old 04-02-2012, 04:21 PM   #90
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,895
They only have a couple for the Superduke, secondary flies removed....I don't want to hurt this expensive motor...we need volunteers to take advantage of their 'mapping program' in SoCal
Mike
Reinheitsgebot
Bonsai Elephant - "
Times are GMT -7.   It's 07:17 AM.
