Old 04-05-2012, 08:16 PM   #1
Powder Hound OP
Fear and Loathing
Powder Hound's Avatar
Oddometer: 86
Seeking accesories wiring guru in SLC..
I am wanting to wire up a few things and have it all be tip top on my bike before a big Mexico/CA trip... Looking for some help... I can supply beer or $$$$....
My ride to work used to be better than yours and now it kinda sucks!
08 V-Strom 650... Flat Black...
Powder Hound is offline   Reply With Quote
Old 04-06-2012, 07:35 PM   #2
jtn
Oddometer: 120
What are you thinking of? I've rewired a few vintage bikes so I might be able to lend a hand. My shop's near 33rd south and west temple -- pm me
Dual Sporting a TL350 / Trail 90 Rebuilds / CL175 Cafe / GL500 Rebuild
'70 CL175, CL350
'82 GL500
'69 - '74 Trail 90's
jtn is offline   Reply With Quote
Old 04-08-2012, 08:49 AM   #3
jtn
Oddometer: 120
It's pretty straightforward if you use the right connectors and seal them with good heat-shrink tubing. I like these from Waytek, they have an adhesive on the inside that helps with water protection and some strain relief when you shrink them down:
http://order.waytekwire.com/products...Heat%20Shrink/
http://order.waytekwire.com/products...%20Connectors/
Let me know if you want to swing by and I can show you what I know -- there's tons of opinions how to tap into wire out there, I prefer crimping + heatshrink tubing as opposed to those quick connectors that puncture the wire (or soldering) because you can still keep the integrity of the wire sheath, replicate it while on the road, and its visually obvious if the connection isn't good.
I do this when wires are close enough to rub and can't be fixed to a body panel/frame section. This photo is from a bicycle but the same principle applies:
'70 CL175, CL350
'82 GL500
Old 04-08-2012, 01:46 PM   #4
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,617
I just spent 4 days in West Jordan. Had I seen your post sooner, I would have helped in person.
Flashmo is offline   Reply With Quote
Times are GMT -7.   It's 02:10 AM.
