Old 04-09-2012, 08:21 PM   #1
Player B OP
Player B's Avatar
Oddometer: 72
Show and Tell: First Project is Ready for the Road!
Hello all. After lurking here for a while, I figure it is finally time that I introduce myself and do some show and tell on my own project. I've been wanting to start something like this for a while now, and back in November I picked up a 1983 R80RT from a fellow inmate not too far from where I live just north of Dallas.
Bike the night I brought it home
Before I go on, If you're looking for an RT restoration, you will be disappointed. It may look like sacrilege to some purists, but the reality is that this bike was most likely going to be parted out if I didn't take it. This way, I got the perfect base for my first project, and I still have all the parts that I will hopefully make their way to someone who is trying to restore their RT.
Mechanically, the bike was in very good condition. The engine runs solid, everything on it works and has, in my opinion, minimal corrosion for a bike that is almost 30 years old. So far, I haven't done much to the engine other than changing the fluids and cleaning it up. The bodywork is a different story. It was certainly serviceable, but that picture makes it look in much better shape than it was.
The goal for now as been to drop weight, and give it a sportier stance without throwing too much cash into it. Still have some little loose ends to tie up, but for now "Stage 1" is complete. The bike is road worthy and I plan on riding the snot out of it.
On to the good stuff, pictures:
A coworker snagged a couple of pics of me during a recent morning commute
Player B screwed with this post 04-09-2012 at 08:30 PM
Player B is offline   Reply With Quote
Old 04-09-2012, 08:24 PM   #2
Player B OP
Player B's Avatar
Oddometer: 72
Work that has been done:
1. Remove the body work and general clean up. Nothing to crazy here. Bottle of simple green, several rolls of shop towels, and scotchbrite pads got it cleaned up pretty well while still leaving a bit of "patina". I did end up using easy off to clean the wheels of some grime that wouldn't budge.
2. The headlamp needed new paint. Tore out all the wires, cleaned it up and used some black Rustoleum Textured on it. I like the way it turned out. Redoing the wiring was miserable though. Relocated the Ignition switch to the Headlamp mount and modified some universal style brackets to attach everything to the forks.
3. Installed some clip-ons from Woodcraft. Required a little reaming of the current controls to get them to fit. Nothing too difficult, I just took a wooden dowel rod and wrapped some sandpaper around it. Took a little bit of elbow grease, but they fit now.
4. Created some spacers to drop the instrument cluster down. I thought about fabricating a new bracket, but this was simpler and it turned out to work perfectly. Probably going to move to an Acewell unit in the future anyways.
5. Modified the subframe to accept a motoLana seat unit.
6. LED Bar end Turn signals up front, and LED brake light and turn signals out back. Made some brackets out back to position everything as I liked. Spent a couple of nights working out kinks in the wiring, but it turned out pretty clean.
7. The gas cap lock was broken, and at some point one of the POs filled in the gap with what looked like some sort of caulk. Tore it apart to clean it up and machined a black delrin plastic cap for the hole. If somebody really wants to steal my gas they can just cut the lines running down from the tank anyways.
8. Modified (cut up) both the front and rear fenders.
9. Replaced the old rotted tires with some Avon Road Riders
10. the old horns were shot, replaced them with some universal ones from Dime City Cycles
11. I removed the airbox (don't hate!) and added pods in anticipation of replacing the big heavy battery with a smaller one in that cavity. I ran it for about a week with just a Filter on the crankcase breather and was seeing more oil mist than I would like, so I ended up making a Catchcan out of a Flask I had laying around. The dimensions ended up working perfectly.
I'm not worried much about the pods. This is only going to be ridden in good weather and I doubt I'll be putting more than 2-3k miles on it in a year.
12. Installed some reverse cone mufflers. I love the way they sound. Loud, but not obnoxiously so (well... not too obnoxious). Needed to replace the crosspipes as the old ones had oxidized quite a bit and I ruined them trying to take the exhaust apart. Wrapped everything in tan exhaust wrap to hide the mismatching finishes. At some point I may give them a coat of high temp paint, but I don't mind the way they look now.
13. Stainless Steel Brake lines up front. They made a huge difference from the stock rubber hose that was on there.
Player B screwed with this post 04-09-2012 at 08:33 PM
Old 04-09-2012, 08:27 PM   #3
Player B OP
Player B's Avatar
Oddometer: 72
Other upgrades that I'd like to do
1. Some new rear shocks are high on the priority list right now
2. I should probably upgrade the front shocks (internals) as well.
3. I want to change to a smaller battery, and move into old airbox space. Along with changing the rear fender to a hugger mounted on the swingarm, this should create a nice empty space under the seat.
4. I'm thinking of making a rear cowl cover whenever this whole thing gets a new coat of paint just to break up all the black in the back.
5. I don't find the stock pegs and clip-ons that uncomfortable, but will eventually install some rearsets
6. Acewell instrument cluster
7. cut down the steering damper control knob to something that is flush or close to the top triple tree (plate)
8. This sounds crazy, but at some point I think I may try to do a rewire on the whole bike. Move all the wiring out of the headlamp, and maybe take a shot at crafting something a little less traditional upfront.
Old 04-09-2012, 08:35 PM   #4
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 45,686
You and I are on very similar paths, I see
Hedge36 is offline   Reply With Quote
Old 04-10-2012, 06:12 PM   #5
knary
sunshine and puppies
knary's Avatar
Oddometer: 29,486
everyone is
Artist, Father, Etc | Oil & Piston
Go Jane Go - Analog Jane and her three chamber heart
Goodbye Toolfan
knary is online now   Reply With Quote
Old 04-10-2012, 07:07 PM   #6
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 45,686
Originally Posted by knary View Post
everyone is
Ordered red flag terminals for all the re-wiring, plus a fancy-pants ratcheting crimper.
Received said flag terminals and crimper.
Realized that one needs a fancy-pants ratcheting crimper with dies specifically for flag terminals
Crimper ordered.
Sigh.
Old 04-10-2012, 07:36 PM   #7
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,509
Nice job. How is the low end power with the shorty mufflers?
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-10-2012, 08:19 PM   #8
Player B OP
Player B's Avatar
Oddometer: 72
Thanks,
Low end power seems fine to me, but then again I don't have much to judge it against. I only took it for a short ride or two with the stock mufflers while it was still in RT form, and at that point significantly heavier. The weight change seems more noticable than anything. If I lost a bit of power, my riding skills aren't refined enough to notice.
Old 04-10-2012, 08:21 PM   #9
knary
knary's Avatar
Oddometer: 29,486
Crimper ordered.
Sigh.
Step 1. suspend heavy-ish item by wire.
Step 2. put two layers of paint on item
Step 3. while putting third layer on, watch in disbelief as wire comes undone and item drops onto ground into dirt and leaf litter.
Step 4. shake can vigorously and debate just painting over all of it, sticks, bugs, leaves, and all.
Goodbye Toolfan
Old 04-10-2012, 08:41 PM   #10
Player B OP
Player B's Avatar
Oddometer: 72
Oh I have several of these...
1. Order cool bar end LED turn signals. Right as I'm about to finish the install, i snagged the wires so hard i pulled them out of the sealed base...order new turn signals
2. Order headlamp mounts. Take to machine shop at work. Completely missed the dimensions... Order new mounts and do over again.
3. Order LED turn signals for the rear. Finish wiring. Go to bolt into place. Part was defective and it sheared right off... Get new turn signals sent to replace defective part
4. Order universal SS brake lines instead of custom lines bc it was half the price. Didn't realize the adapters I had to use would end up making it more expensive than if I had had custom lines made
Old 04-10-2012, 08:42 PM   #11
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 45,686
Ah, so THAT's what happened to my seat cowl
Old 04-10-2012, 09:44 PM   #12
knary
knary's Avatar
Oddometer: 29,486
I think that's how I remodeled a house.
The bike looks great.
Goodbye Toolfan
Old 04-10-2012, 09:46 PM   #13
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 45,686
Crap, that's what I still have to do: order brake lines.
Old 04-11-2012, 05:46 AM   #14
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,824
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 04-11-2012, 07:59 AM   #15
DiabloADV
Semi-Occasional
Oddometer: 2,321
Looks good. But lose the horn and the side reflectors.
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Times are GMT -7.   It's 09:35 AM.
