Old 04-10-2012, 10:13 AM   #331
drc42
Rally Dreamer
drc42's Avatar
Oddometer: 1,836
Originally Posted by pilo View Post
I'm trying to find a good source for waterproof electrical connectors. I saw Hogwild's post about they screw type connectors, but I'm looking for the waterproof push type. I know there are supply houses, but I don't know the terms and was hoping someone had done the research already. Two questions:
1) Does anyone know where I can source the power plugs on the F2R? I found a Chinese importer that has them, but I need to buy them in QTYs of 500! The same connector that is pictured on RMS site on the F2R
2) I'd like to buy a kit of parts for 2, 3 and 4 pin connectors like these listed on Amazon. I'm sure there is a supplier that has them in small qty cheaper than buying them one at a time on Amazon or some auto supply shop. Where do people buy these? I'd like about 30 connectors or so.
I bought of those some a while back from summit racing. Search for "weatherpack" on summitracing.com
Someone recently pointed me to this site which looks promising for stuff like this: http://www.easternbeaver.com/
When I heard the name I was concerned about clicking on it at work don't worry, not that kind of beaver.
follow my journey: Dreaming of Dakar
drc42 is offline   Reply With Quote
Old 04-10-2012, 10:14 AM   #332
cross-country
cross-country's Avatar
Oddometer: 1,619
I don't know if this will help, but I have dealt with digikey.com a bit in the past. Their live-chat peeps are usualy able to help me find what I need, despite my electrical ignorance.
cross-country is offline   Reply With Quote
Old 04-10-2012, 10:25 AM   #333
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,485
I'm trying to find a good source for waterproof electrical connectors....
Look at the JST JWPF connectors discussed about ten posts up. The same connectors KTM uses on their tripmaster computer. Much more compact than the delphi weatherpack connectors, even rated for underwater use.
The weatherpack's are nice if you need a disconnect on a high-current device like a headlight as they are rated at 20A.
The tiny JST connectors are only 3A, but that is more than enough and for hooking up nav/rally electronics and switches, and the compact size is much nicer to try and stuff into a rally bike.
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb is offline   Reply With Quote
Old 04-10-2012, 10:26 AM   #334
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 1,147
Hey Phil, these are the ones I use, they are OEM for Hondas and I replaced all the cheap ones on my KTM with them.
http://www.corsa-technic.com/item.ph...category_id=54
The guys there are awesome to deal with, it's in the US and they ship quick. They're a bit more then the Amazon ones, but they're smaller and I think they're cleaner.
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Old 04-10-2012, 10:35 AM   #335
wrk2surf OP
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,619
Connectors
Connectors are known by many names.. some are waterproof some arent, GM connector, Molex, etc. Here http://www.rowand.net/shop/tech/auto...connectors.htm is a page about the connectors and pins with links to company's selling them. You have to watch out because most use a pin tool like this
to pop the pins in and out.
Digikey.com and http://www.theelectricaldepot.com/ are a couple other supply companies.
wrk2surf is offline   Reply With Quote
Old 04-10-2012, 11:59 AM   #336
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
Got the RMS rack today.
Here is a side view. I decided to not drill holes in the top and just mount the F2R to the center mounting points. The ICO may vibrate a bit but I can live with that for now.
I also broke out the soldering iron today and wired up the un-switched harness I got from beavercreek a few weeks ago for the ICO and the RB power source. I can just unplug the whole rig if the bat starts to drain on me.
So now I have power for the VR light and RB. Productive day. I guess now all I have to do is pack and wait for launch day.
My SPOT tracker link: SPOT
14' KTM 690R
13' R1200GS "Wasser Baby"
10' KTM 450EXC
84' Honda 500VT Ascot
RuckedUp is offline   Reply With Quote
Old 04-10-2012, 12:09 PM   #337
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
Looking good, what fuel tank have you got?
Minimum range for the rally is 150kms, and I think I spotted the stock tank in your pic....
TALES FROM THE BIVOUAC
TWOONEZERO
Brodovitch is offline   Reply With Quote
Old 04-10-2012, 12:27 PM   #338
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
I will have the Exxon tanker on the bike :)
14' KTM 690R
10' KTM 450EXC
Old 04-10-2012, 01:09 PM   #339
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,224
http://www.digikey.com/PTM/PTMPartLi...g=en&ptm=11101
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 04-10-2012, 04:14 PM   #340
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,452
Just thought i would point out that your F2R is mounted to charlie's bracket incorrectly. the F2R should be mounted to the brack via the holes in the side of the roadbook...you will need to drill 2 holes in the top mating surface. Unless something has changed recently.
Seth S
Seth S is online now   Reply With Quote
Old 04-10-2012, 07:53 PM   #341
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,003
Was finally able to mount up the nav gear to my Super Enduro
Was able to thrash the hell out of the set up last Sunday at a riding park in PA. Two foot water bars, rocky hill climbs and a double and table top on the MX track I even threw it on the ground in greasy trail section with zero damage. Big thanks to Paul for making the bracket! looking forward to the MX1000 with it!
Just say'IN
crankshaft is offline   Reply With Quote
Old 04-10-2012, 09:59 PM   #342
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
Roger that
Thanks, I did it this way for ease of mount and not having the time or motivation to drill holes. The ICO may vibrate a bit but I can live with that as I don't plan on hauling like a wild man just using my first rally to learn.
14' KTM 690R
10' KTM 450EXC
Old 04-10-2012, 11:56 PM   #343
Seth S
Seth S's Avatar
Oddometer: 4,452
with it mounted like it is the bracket is more likely to break. I believe charlie and crew intended the roadbook to act as a strength member with the bracket. it doesnt take long to mount the correct way and it is rock solid when done so. you might be surprised by the amount of vibration even when riding slower....and the damage that the vibration can do even in one stages.
Seth S
Old 04-11-2012, 12:52 AM   #344
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
ok
Damn now Im second guessing myself, ok back into the garage and follow the instructions to the T
14' KTM 690R
10' KTM 450EXC
Old 04-11-2012, 02:18 AM   #345
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
and the damage that the vibration can do even in one stage.
spot on.
TWOONEZERO
Times are GMT -7.   It's 12:18 AM.
