Old 04-14-2012, 11:18 PM   #1
Spud Rider OP
Spud Rider's Avatar
Oddometer: 3,811
XR650L: Spud's Oil Cooler
For a while I have been considering different options to install an inexpensive, well-protected oil cooler for my XR650L. I finally decided to experiment with one of the Long/Tru Cool, power steering coolers sold by Baker Precision.
http://www.bakerprecision.com/trucool.htm
Because I wished to keep the oil lines feeding the cooler well protected, and as short as possible, I decided to purchase the 4x4x3/4, small, power steering cooler, which sells for $29.95. After considering a side mount, I finally decided to mount the oil cooler on the bikes downtube, as high as possible, directly behind the front fender.
I constructed a frame for the oil cooler from 3/4x3/4, aluminum angle stock, and 3/4, aluminum bar stock I purchased from Home Depot. I bolted the oil cooler to the angle stock, and completed the coolers frame by bolting two cross pieces of 3/4 bar stock.
I mounted the bottom of the cooler to the frame with two, 1/4x2 bolts, and a short piece of aluminum behind the downtube. I attached the top of the oil cooler to the frame with a plastic zip tie, which I intend to replace with a steel cable tie.
I purchased SAE J1019, transmission oil hose from a local CarQuest store. I ordered five, 90-degree, brass hose barbs from a local hose supply shop. Since I wanted to install a Trail Tech, TTO Temperature Gauge, I also bought some brass fittings from Fastenal. Most of these fittings are also available at many auto supply stores.
I cut the external oil pipe just above the rubber grommet on the frame, and plumbed the oil line into the bottom of my oil cooler as shown in the photographs below. I plumbed the top line from the oil cooler into the line feeding the oil reservoir in the frame. I installed the temperature probe in the oil line between the engine and the oil cooler so I can get a continuous reading of the oil temperature as it exits the engine, before it enters the oil cooler. I secured the oil hoses to the bikes frame using 5/8 loom clamps I bought from Home Depot. I drilled holes in the front fender, and shimmed the fender down with nylon spacers so it would clear the oil cooler.
After installing my Spud Cooler, I went on a 110-mile ride to test it.
Im pleased to report the oil cooler works well. I paid approximately $95 to purchase the parts needed to assemble the oil cooler. I spent an additional $50 to plumb the TTO temperature gauge into the oil line. I will continue to report on the effectiveness and durability of this oil cooler as I accumulate more miles riding my XR650L with the oil cooler installed.
Spud
Old 04-15-2012, 02:29 AM   #2
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Good job Spud!
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 04-15-2012, 04:40 AM   #3
Grover6
Oddometer: 183
Nicely done
Grover6 is offline   Reply With Quote
Old 04-15-2012, 07:21 AM   #4
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,212
Excellent work!!
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 04-15-2012, 07:28 AM   #5
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,520
Originally Posted by Sourjon View Post
Good job Spud!
John
Originally Posted by Grover6 View Post
Nicely done
Originally Posted by tjrockit View Post
Excellent work!!
+ another Spud
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is online now   Reply With Quote
Old 04-15-2012, 08:13 AM   #6
Lane_N
Pig Wrangler
Lane_N's Avatar
Oddometer: 87
That looks great Spud! What kind of oil temperatures are you observing now under operating conditions?
Lane_N is offline   Reply With Quote
Old 04-15-2012, 09:12 AM   #7
elsalvadorklr
southern xr rider
Oddometer: 4,154
damn goo job man!
I need to do something like this too...
is that temp reading you took right after shut down after or during the ride and what kind of riding was it?
cheers
elsalvadorklr is offline   Reply With Quote
Old 04-15-2012, 09:19 AM   #8
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
Very nice!
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 04-15-2012, 10:25 AM   #9
Onederer
Crunch Nugget
Onederer's Avatar
Oddometer: 853
You have designed in too many points for potential oil leaks, rattles and front suspension interference.
The fender is that close to the frame to allow room for the tire under it during full compression, lowering the fender may allow the tire to contact it, which depends on the tire used. No matter what type of material the strap at the top is, the bracket will most likely vibrate against the frame. For what you paid for all the fittings, you could have bought an inexpensive tubing bender and some tubing, requiring only four short pieces of hose and eight clamps to connect it all. You would still need a double flaring kit, but maybe you could borrow one because that would be expensive for a one time use. The way you mounted the cooler, you have blocked 1/3 of the direct air flow.
The first attempt is often not successful. You made your first attempt, but it is not worth praise, keep trying.
I staired a whole thru the breaks until I remembered the carb prolly has a problem to and I'm gonna hafta work on em.
Onederer is offline   Reply With Quote
Old 04-15-2012, 11:51 AM   #10
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,331
Holy smokes Spud.....did ya buy stock in a hose clamp factory
Kiddin.........looks quite decent.........how are your clearances when the wheel is turned full left/right........and hows the clearance for the fender and wheel at full compression??????????????
If that checks out it looks good to me...i still like Marks cooler though.........but this is definately cheaper.
Hey.i started a rebuild thread if you`re interested...read along,,,i have a few issues so far..but what doesn`t when you gut something completely apart........
Good job.....know how about a good stereo install.....i`d love to have tunes on my bike going through the woods
B
techforlife is offline   Reply With Quote
Old 04-15-2012, 12:07 PM   #11
elsalvadorklr
southern xr rider
Oddometer: 4,154
damn a little harsh but I understand your point
I have a question for you
has anybody done or know whats prefferable, airflow over the valve cover/topend OR lower oil temps with the introduction of an oil cooler?
I ask this cause I have done the fender mod like spud using BIGGER less count holes and thought a liitle more airflow is better than not,
I do not have an oil cooler installed though but want to
If anybody has proof or data that will back up this question Id appreciate this
I think this cooler is a great project well made and a lot of thought put into it, yes it needs a little trimming on the tubes and such as I too think its a little much but I think your last sentence was uncalled for...
anyways
to all a happy sunday
christian
Old 04-15-2012, 01:15 PM   #12
techforlife
CDI REPAIR
Oddometer: 4,331
anyways
christian
Well.........if you vent the back of the fender you get more airflow to the head....that`s a good thing in hot weather......but if you ride in alot of mud then venting the fender causes it`s own issues of caking mud on the fins/head which is really not good.........
A big fin head would probably be the best bet....fins are out farther,catches more air,,venting the fender probably wouldn`t be needed then...depends on how/where you ride i guess...
I know for me,the oil cooler definately stopped the oil from turning charcoal black in 500 miles...that in itself has to be a good thing..
B
Old 04-15-2012, 02:02 PM   #13
purpledrake
No Pretensions
Oddometer: 334
Originally Posted by therealbigman View Post
+ another Spud
Hey Spud,
Once again, you show your resourcefulness, and ability to keep us all in awe. Very good work.
I have two questions.
First, what problems (overheating) did you encounter that led you to add an oil cooler? I am guessing that the high Idaho desert in the summertime causes problems, but what were they?
The second question regards the placement of the new oil cooler, and access to the spark plug. I don't know about you, but I can barely get my hand in there right now--have you tried to remove the plug since you installed the cooler?
PD
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 04-15-2012, 02:07 PM   #14
elsalvadorklr
southern xr rider
Oddometer: 4,154
B
yeah I vented my fender taking into account that I almost never ride in mud unless I have to...
If I do for some reason I thought about adding screen mesh to the backside and glue it on
my fender is also shorter in the back than stock, its a modded crf250 fender I think
anyways
I wish I could find a tranny oil cooler like spuds that I could mount where the xr250 and xr400 coolers mount as that would be the best, protection wise and airflow wise
someday someday
again spud congrats hope the cooler lasts and it looks like it works well so far...maybe just add a littel protection to the pipes and hoses so they dont get snagged?
cheers
Old 04-15-2012, 03:14 PM   #15
Spud Rider OP
Spud Rider's Avatar
Oddometer: 3,811
Thank you for the kind words, John, Grover, TJ, and BigMan.
Spud
Times are GMT -7.   It's 02:40 PM.
