04-14-2012, 06:57 PM
#31 | |
Oddometer: 1,410
clutch may improve with riding, remember its probably got a bit of surface rust/sheen on it and will be a little grabby.
suspect the oil on boots is from the push rod tub seals. They are rubber and at the base of the pushrod tubes on either side. Old rubber= fail Dont know about the cancel buzzer, but mine doesnt have one. Tach and speedo just need to be lubed and will probably smooth out for 95% of the time. No kill, gotta turn it off with the key! side stand is spring loaded and takes a little getting used to. Its probably not in the factory position and bent some from years of use. Stand should not fold up if the bikes weight is on it. Tranny, fresh gear oil will make the shifts better. Its a very clunky tranny to begin with. I have found that if it gets a little low on tranny fluid or its needing fresh then it will be harder to shift. ENJOY IT! You will grow to love your ugly duckling
1974 BMW R90/6 Bettie #1 Quote:
04-14-2012, 07:02 PM
#32 | |
Endeavor to Perverse
Oddometer: 3,440
As to the turn signals, simply remember this mnemonic: It's LEFT UP to me to figure out this DOWN RIGHT silly system. There is a kill switch. That has to be one of the worst fairings and most awful seats I've ever seen. That being said, take her in hand and make a lady of her once again. You'll be glad you did. If you can score the Matchless, I'd be all over that, also.
The Bull Cook Racks Made in the US! Dual Sport Luggage Racks for: DRZ-S, SM and E, DR 650 and KLR650: http://www.moto-racks.com |
04-14-2012, 07:04 PM
#33 |
ShadeTreeExpert
Oddometer: 5,229
Congratulations. Sounds like a great Airhead.
They are noisy when shifting. Takes some getting used to. Most Airhead riders use "pre-shifting" and say it helps. Before the clutch is pulled in the toe is lifted just enough to remove free play then the shift is performed the standard way. Another technique is to shift with out using the clutch. It is allowed and works better once you get the hang of it. There should be a kill switch. Sounds like you have a non standard right hand control? The kill switch is a red toggle on the right? Maybe your Grand Dad knows what happened to it. The side stand and the center stand are more quirky features of the Airheads. There are after market options. The Reynolds Ride Off Center Stands are no longer made I believe but show up at flea markets and such. Probably not really worth the money these days for the Reynolds. But there is a good option for the side stand and it is still made. It is the Brown Side Stand. Also a couple of others are still made but I think the Brown is the most popular. The bags sound like Krauser's but the wiring does not sound standard. Maybe somebody added some lights? As far as modifying the front brake there are volumes written on this subject. The handle bar MC is a good beginning. Changing to another style caliper gets involved and is not mentioned often on these forums.
Never memorize something you can look up. ---Albert Einstein |
04-14-2012, 07:42 PM
#34 | |
Oddometer: 1,410
Kill switch, just remembered that mine is an early 74/6 with /5 controls and they added one with the new controls
04-15-2012, 07:20 AM
#35 |
Oddometer: 430
Wow, you are a lucky guy. To have something like that handed down may not seem like much to some but Iam sure your Grandfather loves/loved that bike. In the pictures the bike really looks to be in nice shape, I will agree the Vetter fairing does not seem to blend with the style of the bike. Very nice.
04-15-2012, 11:21 AM
#36 | |
Oddometer: 12
I still remember the first time I was up there after he got the bike, I would have been 12 at the time. He would take me on rides starting when I was so little I had to sit on the tank. I can't remember what the bikes were, mostly his Virago's I think. But I do know once he finally got the beemer, I really can't remember him riding anything else. Not to say he didn't, but there is no doubt he loves that bike. |
04-16-2012, 08:11 AM
#37 |
I Miss the PartyBoss
Oddometer: 5,909
My 75 R90 /6............. I really like cruising around town on this bike. .....................
![]() ![]() Boojum
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly" BMW's: 1999 GS 1100 "Work Horse", 1975 R90/6 "Black Betty", 92 R100 GSPD, 03 XR 650L with Farkles, KLR 250, 72 Honda CL-70 |
04-16-2012, 08:19 AM
#38 | ||
über-n00b
Oddometer: 287
I'll also add that you should expect more oil seeps from any aged gasket. I'm replacing as needed every gasket and rubber bit on my R100RT. On the bright side, as I like to tell me "must-be-cleaned-and-waxed-never-ride-when-it-might-rain-American-Iron" riding co-workers, rainstorms also double as bike washes, and the oil leaks mean I don't need to worry about the bike rusting! Enjoy the old BMW. They are the consummate gentlemen of the motorcycling world.
Larger than life and twice as ugly! My photos: stewie.smugmug.com |
04-16-2012, 10:49 AM
#39 | ||
Oddometer: 12
04-16-2012, 10:56 AM
#40 | |
Oddometer: 32
Had my first freeway rides this past weekend. At 70 or so, in fifth, I found I could barely hear the engine over the wind -- just a distant, comforting hum. Nice. |
04-16-2012, 12:16 PM
#41 |
Oddometer: 276
My R90/6 working through just a few small issues and it should be perfect. Did the restore over this winter..Just put some love into the bike and you will not regret it!
What is looked like when I bought it. ![]() After 4 months of work this is what I ended up with!
04-16-2012, 02:32 PM
#42 | ||
über-n00b
Oddometer: 287
Which brings to mind, I'd suggest asking your grandfather if he has any of the special tools like the exhaust nut wrench or any of the other myriad of "special/modified" tools for working on the bike. They aren't hard to source, but if he already has them, well, no sense in breaking up the set. Quote:
Spun races and destroyed hubs is even less fun.The bike will drive you to distraction with things like the electrical system (what were they THINKING? Taking lessons from Lucas?) to the side stand (what were they THINKING? Way out under the cylinder so you can't SEE it?) to the centre stand (what were they THINKING? Do you see a pattern developing here?) But I must say, until I got the airhead, I never had a bike that made me want to throw a leg over and strike out for California from New Brunswick/Maine just because...
Larger than life and twice as ugly! My photos: stewie.smugmug.com More_Miles screwed with this post 04-16-2012 at 02:39 PM Reason: Aparently proof reading isn't my strong point |
04-16-2012, 02:43 PM
#43 |
ShadeTreeExpert
Oddometer: 5,229
Your Grandfather should have some tools especially the finned exhaust nut tool. Every Airhead rider has to start with getting this tool. Well almost every one. But you will use this tool again and again. So if Granddad doesn't have the tool there are several sources and thru the years there have been many versions of this tool. We will advise, but right now there is an original one on Ebay that has not been bid up yet. These go for a pretty penny sometimes. I don't want to tell you what it might be worth they are sometimes over priced I think. But I do like the original heavy BMW tool.
http://www.ebay.com/itm/270955014898...84.m1423.l2649
04-16-2012, 04:07 PM
#44 |
Oddometer: 12
My grandpa does not have the tool. I specifically remember him mentioning taking it to a guy he knew when he needed that. I checked out the Ebay thing, but seems someone else has a relativly high max bid already on the item. Not sure how much I should pay for it? As it sits now, still outbid and it's 30 bucks shipped right now.
04-16-2012, 05:38 PM
#45 |
ShadeTreeExpert
Oddometer: 5,229
If it goes no higher then somebody got a good deal but no telling how high it might go. I can tell you I've seen these sell for over a hunnert on Ebay. I do think that is too much to pay for most people. They might still be available but I haven't seen any other than the auctions for some time. I think the last one I saw new was still 70 or 80 bucks but I'm not sure about that.
I don't even remember what I paid for mine 30 years ago. But I still have it. At this point if you wanted to try and win this item don't bid any more but "snipe" it. I use a service called Gixen. You can find them with Google easy enough. That wrench is the cast iron one. There is also a cast Aluminum one that I don't have but think they look OK. Max BMW sells the Aluminum one pretty cheap; http://www.maxbmwmotorcycles.com/fic...HAUST%20WRENCH And there is one sold by Cycle Works that works with a half inch breaker bar. http://www.cycleworks.net/index.php?...roducts_id=346 I think most recommend the Cycle Works wrench and it also has the big advantage of being small enough and light enough to sometimes be carried on the bike.
