Old 04-16-2012, 10:15 AM   #1
whitham_wannabe OP
whitham_wannabe's Avatar
Oddometer: 1,060
1971 TS90 Project!
Bring on the tiddlers! Just picked this TS90 up from an inmate, for the princely sum of $150, in need of some work, but oh so cool!!
The bike came non functioning, with a siezed up kick starter and siezed up brakes, but with a spare motor and spare brand new tyres. When I got it home, I couldn't get the motor to turn over at all, even by bumping the back wheel, so figuring the original motor was going to need to come out, got to work.
Curiously, with the motor on the bench, the kickstarter would now turn the motor over, though the shaft is now upside down, so has no return spring action. The motor would now also turn over with the sprocket, so my initial fears of a locked up transmission were allayed somewhat.
What to do next ... the PO said he had tried the spare motor, but that it wasn't very strong. It did, however, look in better shape than the original. A quick compression check showed that it had about half the compression that the original has. Pulled the head and barrel, and found out why ...
Ooops ... so the question now is where did the rest of the skirt go?! Peering down into the crank, I really can't see any shrapnel down there, so I am wondering whether to swap the piston and cylinder from the original onto the spare bottom end, or whether to split both cases and fix the kick starter mechanism in the old motor.
Any opinions?
From a WW1 RAF Flight Manual ...
"If a crash at the home airfield is inevitable, try to hit something soft and, preferably, inexpensive"
Travels With Bruce : More Travels With Bruce
whitham_wannabe is online now   Reply With Quote
Old 04-16-2012, 12:41 PM   #2
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,864
The engine in the frame in your first photo is a "TC" (dual range transmission).
You're a good man for taking this POS of the PO's hands.
From what you've posted, I would suspect the missing piston skirt was removed by the PO and the top end put back together about the time he put it up for sale.
With what you have found so far, I would be thinking about splitting this cases "IF" you plan on keeping the bike. It appears to be in good shape cosmetically...?? with the exception of the seat cover.
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 04-16-2012, 01:27 PM   #3
Brunow - 007
Bantam Fever
Brunow - 007's Avatar
Oddometer: 308
Now that's a very nice bike! Good luck with it!
Working on the D14/4 Bsa Daily Driver .
Brunow - 007 is offline   Reply With Quote
Old 04-25-2012, 10:59 PM   #4
bondbmw
Oddometer: 60
90cc hack Ropey?
Lots of bikes
bondbmw is offline   Reply With Quote
Old 04-26-2012, 02:35 AM   #5
Tuff Tunica
Moto-Skiveez creator
Tuff Tunica's Avatar
Oddometer: 645
Same bike
I got nearly an identical bike last year. Mine is a 1970 TC90 . A little better shape than yours.
I'll be watching your progress. I have some specific questions about the way the rotor works for the equivalent of reeds for the two stroke. Wondering if this is a common wear/replace item?
Good luck!
Unbeing dead isn't being alive. E.E Cummings
Nothing is miserable unless you think it is so. Boethius
http://advrider.com/forums/showthread.php?t=954772
Tuff Tunica is offline   Reply With Quote
Old 04-27-2012, 09:24 AM   #6
Shocktower
Shocktower's Avatar
Oddometer: 9,468
Very nice and POS means Pretty Ols Suzuki
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 04-27-2012, 10:04 AM   #7
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,325
There is a running one here in central Illinois for $175. I called offering to buy it if it had a title but I did not hear back so I guess the answer is no. I thought it would be perfect for my next project, some sort of small displacement cafe bike.
http://peoria.craigslist.org/mcy/2978561049.html
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 05-05-2012, 07:46 PM   #8
Gham
Gham's Avatar
Oddometer: 1,311
aaahhhh........my first love,a 1971 TC90,I burnt holes in 8 pistons before I learned about jetting and air filters.I could swap out a top end in 30 minutes! Of course at 15 years old I didn't think about metal in the crankcase or scarring the cylinder.Ignorence is bliss sometimes
Member 6204
Society Historicus Revisioniscus
Gham is offline   Reply With Quote
Old 05-05-2012, 07:59 PM   #9
Gham
Gham's Avatar
Oddometer: 1,311
Not mine/but identical to it
Member 6204
Old 06-30-2012, 10:45 PM   #10
Red0ktober
Red0ktober's Avatar
Oddometer: 52
I've also come to have some little Suzuki TCs. I have my dad's old '69 TC120 that I'd like to get running again (I took it apart when I was a kid). I bought another TC120 for the parts to replace the ones I probably lost years and years ago, and with it I got a complete TC90.
I've been running the TC90 around my yard, but it's running weak, especially on the upper range of the throttle. I need to pull the carb and check the jets and settings. [edit: spark arrestor was clogged, running strong now!]
I'll try to start the parts bike when I get the tank cleaned up a bit and a new fuel filter, hopefully Monday. If all is well, I'll swap the good bits over to my dad's bike (parts bike doesn't have a title).
Red0ktober screwed with this post 07-01-2012 at 08:26 PM
Red0ktober is offline   Reply With Quote
Old 07-10-2012, 11:14 PM   #11
kurtdaniel
Oddometer: 5
wow,, really nice find for that price.. i love that kind of bike.. I just found this Motorcycle parts bargain that id go to if ever i have a bike like this to modify..
kurtdaniel screwed with this post 07-15-2012 at 10:06 PM
kurtdaniel is offline   Reply With Quote
Old 07-12-2012, 12:25 PM   #12
Red0ktober
Red0ktober's Avatar
Oddometer: 52
The insurance premium for my '71 TC90R is less than the multi-vehicle discount it gives me, so my insurance went DOWN by $47 over the year!
Old 07-18-2012, 01:53 PM   #13
Bud Tugly
Gnarly old curmudgeon
Oddometer: 236
A fun little bike for playing in the woods or running around town. They were Suzuki's answer to the Honda Trail 90, but had better suspension (for the day) and more power. That dual range transmission makes it able to climb anything you can get traction on.
Bud Tugly is offline   Reply With Quote
Old 07-18-2012, 02:15 PM   #14
Red0ktober
Red0ktober's Avatar
Oddometer: 52
They only put a 3-speed D/R in the TC120 though, with an odd shift pattern - neutral at the top and all three gears down.
Still waiting on new petcocks to get the TC120s running. Just rode the TC90 to the hardware store on my lunch break.
I'm going to fix a few more things then put the TC90 up for sale, maybe upgrade to a KLR650. ;)
Old 08-06-2012, 04:28 PM   #15
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,236
Honda Trail 90's, and the old Yamaha snorkel cased 80's and 100's had neutral at the top, not that odd at all if you've ridden them for years. I actually prefer it to having it hide between first and second.
The TS 90 was a sweet little bike for it's time, and a good performer. One way to gain a few small ponies without changing the bore or carburetor, at least for the iron cylindered ones, is to polish out the roughness in the transfer ports, and have a machine shop take a few thousanths off the head. You will have to richen it a smidge on the main jet. Mine ran so great a friend's felonous stepson stole it from me.
Rat bastard..
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Times are GMT -7.   It's 08:32 AM.
