04-16-2012, 10:52 AM
#61 |
Oddometer: 12
Looking forward to following this!
If you want to spend anytime in Vancouver drop me a line, I'm right downtown with lots of secure parking right next to my 990. Cheers, Jamie |
04-16-2012, 11:10 AM
#62 | |
Way Offline
Oddometer: 1,162
I am at one with my duality. |
04-16-2012, 11:23 AM
#63 |
Wanderer
Oddometer: 877
My front blinkers are on the Bash Guards. Now that i have 2500 miles on the RR faring i can see what is rubbing and needs to securely fixed or a gap made.
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting. RTW Ride Report --> http://advrider.com/forums/showthread.php?t=781893 Blog ------------------> http://rtwwithnoah.blogspot.com/ Facebook------------> https://www.facebook.com/RtwWithNoah Open-Exporers----->A collection of travel blogs |
04-16-2012, 11:34 AM
#64 | |
Wanderer
Oddometer: 877
I will be down in Montana by then. I graduated from MSU in Bozeman so I have some college friends to see. Plus beartooth pass south of Redlodge MT is on my list of places.
04-16-2012, 11:40 AM
#65 | |
Way Offline
Oddometer: 1,162
The directional mounts were pretty much the last thing I looked at to fix the rattle, Thought I picked a winner for you on that one.![]() And I've found the fix to make the 690 run like a million bucks. Earplugs.
04-16-2012, 11:47 AM
#66 |
Oddometer: 25
What a trip!!
Subscribed! Well done dude, go for it. Looks like you plan to come to Ireland. I can offer you a bed and some local craic in Belfast.
Good luck and enjoy. |
04-16-2012, 11:48 AM
#67 | |
on the road o'dreams
Oddometer: 5,507
Just a quick comment on chains and so called "miracle" sprockets. What some riders miss ... especially those who ride mostly off road ... is that a sprocket can be TOO HARD. I've read several forums were dirt riders declare that their Ironman sprockets went through two DID VM-2 X-Ring chains and their sprockets still look new. They were thrilled! See anything funny about this? ![]() I get 25,000 miles on a DID X-Ring chain. Think those guys went that far ... on their "dirt bikes"? I doubt it. Most dirt riders do a couple thousand a year at most. I've used DID chains over 250,000 miles, going back to 1997. I normally run OEM sprockets when available or JT, AFAM or Renthal when OEM not available. No idea if KTM supplied sprockets are good ... or not, but they would be my 1st choice for RTW. Buy two! Lots of "Snake Oil" miracle sprocket/chain hucksters have come and gone, like Larry "Vic" Krause and his Sidewinder products of ill repute, who has been around since the 70's. I've not used Ironman but I do know a bit about metallurgy. A case hardened sprocket is of no advantage for overall chain life. Sure, it never wear out ... but how is your chain doing? A new chain can cost around $120 to $170 to replace. More in some far away place. They are heavy and hard to pack. On long rides on my DR650 I always carry a spare front $15 sprocket (JT). I change it out every 10K miles no matter what. I've found that a fresh front sprocket adds LOTS OF LIFE to my chain. A front Sprocket is relatively cheap and easy to replace. Chains, not so much. ![]() A super hard sprocket may look NEW ... but can wear your nice new chain in short order. You may only get 10K to 12k miles before chain shows signs of failure. My current DR650 uses a 525 chain (your KTM uses 520). My original chain went 12K miles (medium quality DID). Replacement DID VM-2 X ring went 24K miles. Current DID is now up to 12K miles ... has never needed adjustment, looks NEW. I just changed to a new front sprocket: OEM Suzuki. 45,000 miles on bike ... and counting. Japanese engineers claim sprockets "should" wear, rather than the chain wearing first. In any case, keep chain clean as you can, light oiling, no sticky stuff. Good luck! Looking forward to more reports.
04-16-2012, 11:55 AM
#68 |
Gone and back again.
Oddometer: 8,094
Subscribed.......good luck.....let us know dates on the Montana segment.....lots to ride in that area.....
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King Reality is what does not go away when you stop believing in it. -Philip K Dick I wanna be skinny, but my ass is too big. - Charles Barkley When choosing between two evils, I always like to try the one I've never tried before. - Mae West Experience is what keeps a man who makes the same mistake twice from admitting it the third time around. |
04-16-2012, 12:20 PM
#69 | |
Wanderer
Oddometer: 877
04-16-2012, 12:21 PM
#70 | |
Wanderer
Oddometer: 877
04-16-2012, 12:39 PM
#71 |
Wanderer
Oddometer: 877
Found the rattle
The RR kit has this aluminum piece that mounts with 2 screws under the dash. It was rubbing on the underside of the dash and against the side panels. The only reason I can see for keeping it on there is my power outlet is mounted to it. I will be moving the power outlet and removing this piece of aluminum. The 2 mounting holes are next to my thumb. It was rubbing at the top where you see the bare aluminum.
Another picture. I will put more up when its back together. I put the orange gas line on the bottom of the dash to keep it from rubbing. didn't work as you can see. I was also adjusting the sensitivity of the pickup on the TrailTech tach so i get a correct reading.
04-16-2012, 12:47 PM
#72 |
Oddometer: 36
My friend and I are riding our 690's from Vancouver BC to the Oregon sand dunes. We're leaving early Friday morning. Maybe at the very least we will pass you on the road! Otherwise I would have offered you a bed and shower for the weekend in North Van!
A ship is safe in the harbor, but that's not why ships are built... '10 KTM 690R:) |
04-16-2012, 01:12 PM
#73 |
Oddometer: 9
effin epic
What kind of mileage are you getting on that KTM? When I was motorbiking Thailand a few months back, saw a few riders that started in Italy. Definitely Do-able man.
04-16-2012, 01:20 PM
#74 |
Oddometer: 1,260
MMMmmm...... Now you've gone and made me hungry for the pork bellies at Over the Tapas!
04-16-2012, 01:26 PM
#75 |
Animal
Oddometer: 149
I'm In
Ballsy riding a motorcycle to Alaska to go riding(snowboard)!!! Good Luck and Godspeed!
