04-18-2012, 10:12 AM
#2131 |
Broken Roadie
Oddometer: 2,787
The Husaberg Adventure Travelers Thread:
http://www.advrider.com/forums/showt...9#post18486899 Help me get it started if anyone wants to move or quote any of the related posts from here over to there. cheers Finn |
04-18-2012, 12:30 PM
#2132 |
Around
Oddometer: 3,354
PM'd ya BogeyMan. Yep I'll take it.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden "Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE |
04-18-2012, 12:40 PM
#2133 |
Oddometer: 429
Husaberg files found on the web
Husaberg Valve adjust document
http://www.fileswap.com/dl/0SaBSUr3Z...rsion.pdf.html Husaberg water pump document http://www.fileswap.com/dl/oycBz1Noz...ation.pdf.html Husaberg Schematics http://www.fileswap.com/dl/Mw8m1sOKK...atics.pdf.html Husaberg supplemental Schematics (Signal lights) http://www.fileswap.com/dl/rOeipgUOJ...ental.pdf.html
03 XR650L, 92 XR250L ,01 DRZ400, 95 KDX200, 03 KTM 640 E, 2010 Husaberg FE450 |
04-18-2012, 01:25 PM
#2134 | |
Dumba$s Jarhead
Oddometer: 2,856
This is the kind of info that needs to be at the beginning of the thread...along with links to pages within the thread to specific topics.. is the OP still active? Maybe Lostrider will put it at the beginning of his thread.... it doest require time and effort to keep up though.. just my thoughts .. picked my FE570S up from Cliff's about 2 hours ago now begins the work to get it ready for my move to Colorado next summer.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone. |
04-18-2012, 02:55 PM
#2135 | |
Oddometer: 429
Thank you.
04-19-2012, 11:03 AM
#2136 | |
Oddometer: 36
McLeod,
Checked the continuity and turns out high beam side is no bueno. The outer housing twists oround the inner if that makes sense. I've never seen a bulb made this way. Anywho, my local KTM dealer has one on the shelf for $9.82 or Cycle Gear can order one for $2.95. I'll be without high beams for a few more days! Thanks for the help. mikec Quote:
04-19-2012, 11:14 AM
#2137 |
Oddometer: 641
thoughts?
been riding ktm's for several years,owned most sizes they make. currentlty on a tagged 06 450exc.
Its time to move it out, been thinking of a husaberg.. Today i found a good deal on a 2010 450fx. with a rekluse in it. Bike rides well, no obvious issues, but no tag(not an issue to get) , so i couldnt get it up to speed. What is everyones thoughts on using the fx as a dual sport? How is the gearing going to be? Dont need to really haul ass on it, but would like to be able to do 65 without destroying it. Also, never ridden a recluse, would it allow me to gear the bike up, and use the rekluse to make up for it? thanks guys! |
04-19-2012, 04:11 PM
#2138 | |
LDA
Oddometer: 179
04-20-2012, 09:45 PM
#2139 |
Oddometer: 42
Husaberg 2013
More speculation/ info for the future of Husaberg found here:
http://www.enduro360.com/2012/04/13/...hat-is-coming/ |
04-20-2012, 09:54 PM
#2140 | |
Potius Sero Quam Numquam
Oddometer: 4,396
Yeah and no doubt if the prices keep going up, $11-12 large in the USA. I'll be happy with my $7500 FE390 for awhile I think. |
04-21-2012, 10:58 AM
#2141 |
Oddometer: 641
well, ended up picking up an 09 450fe. rekluse etc.
now, where can i find a decent spring rate chart? im 170 lbs naked c class rider, prefer tight nasty stuff. thoughts? thanks, dave |
04-21-2012, 12:22 PM
#2142 |
Oddometer: 2,170
I am 10lbs heavier and prefer the progressive springs. I put a 8.0 on and couldn't stand it. Went back to a PDS2. It's something like 7.6-9.5. It doesn't go all the way to the rated max as we don't have that much spring travel on our shocks.
04-21-2012, 05:10 PM
#2143 |
Safari Scramble!!!!!
Oddometer: 3,194
saw a 390 listed on nedirtbikes the other day for 5000. i bought my 09 450 with rekluse, rad guards, hand guards from edelmans last year for 6500. used bergs seem to be quite reasonable.
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
04-21-2012, 05:25 PM
#2144 |
Oddometer: 4,396
I really wanted the 2011 390 for the tasty forks, love those dual-chamber forks offroad. May have to add a a stiffer spring to the rear shock since I'm 220 ready-to-ride and the compression ring is all the way down. May try the progressive spring Tahoeacr mentions.
04-21-2012, 07:08 PM
#2145 |
Lost but laughing.
Oddometer: 4,576
Cyborg, I weigh same as you, maybe a little more depending on tools carried etc and have had my suspension worked by a shop here who races 390s.
Mine is a 2010 390. Forks .48 kg/mm fork springs Revalve forks Shock P20 spring Fit telescopic needle Revalve shock The telescopic needle changes the rear shock a fair bit and makes your other adjustments more useable/noticeable. FYI.
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” George Carlin |
