04-21-2012, 06:12 PM
#106 |
Oddometer: 784
Thanks for posting the info re the Croatian Co, very good info, really appreciated, we have some F650 single owners in that part of the world so have relayed the info over to F650.com as there are VR probs with the single & will see if they are
able to go further with Croatia On the F800 it is clear from the brilliant work done by Joel, ebrabaek and others that the primary problem is lack of cooling to the stator & that wont be resolved without a design change The work around if you like is to try to reduce stator temps by a VR change, Increasing the VR regulation voltage using the Shindengen FH12 shunt regulator provides a limited but useful reduction in load on the stator. Going to the series pass VR further reduces the load & hence temperature of the stator All I can say is I am glad I am only looking for a replacement VR for the single to overcome our limited problems |
04-21-2012, 07:01 PM
#107 | |
Oddometer: 2,841
... All will be visible...tomorrow.....Erling |
04-22-2012, 10:16 AM
#108 |
Oddometer: 174
I suspect your heat sink mount is fine, the mosfet has a low Rds so the i^2r losses are lower than the stock regulator... Your anecdotal observations support that. Joel did not make a distinction between the two.
This is a very interesting thread along with all the others on the stator issue. Sent from my GT-I9100M using Tapatalk 2 |
04-22-2012, 11:36 AM
#109 | |
Oddometer: 2,841
Erling |
04-22-2012, 12:20 PM
#110 |
Oddometer: 3,442
If the i^2 * R losses are less in the R/R ... might that be actually be a bad thing?
This MOSFET R/R is still a shunt design right? So if the losses are less in the R/R and the resistance of the stator is unchanged, then total circuit resistance is lower and the max. current would be higher ... thus creating MORE i^2 * R heating in the stator due to the higher current.... Or am I AFU here? |
04-22-2012, 12:37 PM
#111 | |
Advenchaintourer
Oddometer: 1,993
04-22-2012, 12:59 PM
#112 | |
Oddometer: 3,442
![]() I though the stator was basically just coils of wire tied together in a "Delta" configuration. Schematically like this picture: http://www.teal.com/products/App%20note%20AN-15.htm |
04-22-2012, 04:39 PM
#113 | |
Oddometer: 2,841
Erling |
04-22-2012, 04:40 PM
#114 | |
Oddometer: 2,841
Erling |
04-22-2012, 06:21 PM
#115 | |
Oddometer: 3,442
I do agree that regulating at a higher voltage is GOOD (more voltage means less current ... so good), but beyond that it seems like in a shunt design system, with our stators especially, INefficient R/R would be better ... i.e. a higher resistance path to ground in the R/R would be an advantage in that it would help limit the current flow thru the stator coils when less than full output is required. |
04-22-2012, 08:00 PM
#116 | |
Oddometer: 2,841
Erling |
04-22-2012, 08:32 PM
#117 | |
Oddometer: 3,442
Without a real set of test cases being run, in which thermocouples are installed in the stator and the various configurations tested... I don't know ........... but thinking about it ... it almost seems like the -SC version of the R/R might be the "local optimum" ............ |
04-23-2012, 01:03 AM
#118 | |
Oddometer: 42
04-23-2012, 06:26 AM
#119 | |
Oddometer: 2,841
Erling |
04-23-2012, 06:29 AM
#120 |
Oddometer: 2,841
Let me know if there is any interest in a group buy....... I could ask.......as I keep testing the unit.....
Erling |
