Old 04-28-2012, 03:46 AM   #6466
leafman60
Oddometer: 1,844
http://scheffelmeier-metall.de/shop/...iuvAGuHD0EH6Na
leafman60 is offline   Reply With Quote
Old 04-28-2012, 05:14 AM   #6467
Niedz
Niedz's Avatar
Oddometer: 634
whoa, snook, you musta spent some time reading!!!!
havent even gotten back to the bike since i noticed the ghost lights!!! argh! im feel like im never going to ride that thing again! I hope to pull the dash apart and check the ignition switch this sunday. ill let y'all know how it goes.
the mysterious lights has also recently afflicted muddyrabbit!
fabrication fun, rack n roll
Niedz is offline   Reply With Quote
Old 04-28-2012, 06:54 AM   #6468
plumber mike
Highdive Deepened
plumber mike's Avatar
Oddometer: 3,865
I might get proactive about this. I'm thinking about replacing the ignition switch with a discreet toggle switch. I may leave the key for a steering lock, but I really never use it. I also think a volt guage hooked directly to the battery(fused of course) will help with diagnosis when the stock display is acting funky. I must say that the wiring on these bikes is the smallest/cheesiest wiring I have seen on a bike.
I'm still saving up for a big scheffy order.Toolbox skidplate, SS wheel spacers, etc.. My last major purchase for the bike. Well,I still need a new shock excel 21" a60 front wheel with the superlace Will it ever be done?
1996 XR250R
2012 CBR250R
plumber mike is online now   Reply With Quote
Old 04-28-2012, 07:02 AM   #6469
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Originally Posted by plumber mike View Post
...Will it ever be done?
Picking up my bike tomorrow and HOPING TO DEAR GOD THAT IT IS 100% DONE (A60s, Faring, etc...)...
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 04-28-2012, 07:45 AM   #6470
plumber mike
Highdive Deepened
Oddometer: 3,865
....and knowing it's done right! Priceless
1996 XR250R
2012 CBR250R
Old 04-28-2012, 08:14 AM   #6471
mbfj40
Oddometer: 169
Hiya Snooker,
Thanks for the mention. Did you see my fix to prevent shift shaft damage on my bike. I put up a few pics on one of the other inmates threads. If I can find it I drag it over here if you haven't.
Safe riding guys, and have fun...
mike
mbfj40 is offline   Reply With Quote
Old 04-28-2012, 08:20 AM   #6472
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Let's HOPE so!
Old 04-28-2012, 12:26 PM   #6473
JonBryant
Oddometer: 16
So i decided to check my IAC again to make sure it was still clean and also did the reset while it was out of the throttle body to make sure it was moving ok and it popped apart. Pretty sure i saw 3 pieces fly out but can't be sure. Is there a spring under the sleeve the pushes out of the plunger piece? All i can find on the ground is the plunger and the sleeve that goes under it.
Edit: Found it sitting right next to the throttle body tucked behind the frame. Put it back together and it idles great for about 10 seconds then back to it's low cold idle then stalled... boo. Stayed running after the next attempt with a little nursing of the throttle.
JonBryant screwed with this post 04-28-2012 at 12:43 PM
JonBryant is offline   Reply With Quote
Old 04-28-2012, 06:18 PM   #6474
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,336
Originally Posted by mbfj40 View Post
Hiya Snooker,
mike
Mike, And you got a lot of us exited hoping you will build them to sell.
joenuclear is offline   Reply With Quote
Old 04-28-2012, 08:59 PM   #6475
bigmo
Oddometer: 18
Many thanks to my friend Troy for taking the time to put together this ride report featuring my very yellow little Xcountry!
Day 1 is posted here with day 2 and 3 on the way. Some great shots and video of the Xcountry in action. This little bike continues to amaze me!
Arkansas Adventure - G650X Country and F800GS
bigmo is offline   Reply With Quote
Old 04-29-2012, 12:25 AM   #6476
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,587
Hiya Snooker,
mike
No I didn't see it please post it here. All you new guys take note this is your number 1 priority to prevent the biggest flaw from becoming a disaster! Install a bendy steel gear shift lever! http://www.mattsnook.com/bmw/bmwXCou...ever/index.htm
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 04-29-2012, 10:08 AM   #6477
mbfj40
Oddometer: 169
Here Ya go Snooker,
mbfj40
Oddometer: 105
My shift Shaft solution
Originally Posted by macadamia
Moose Racing shifter for the Yamaha YZs... I drilled 3 holes to weaken it...
Hiya Macadamia,
I've seen lots of different ideas for swapping, drilling, weakining etc for the shift levers on our X bikes. Here's what I've done and so far it's even passed a crash test by an '81 Dodge truck that wasn't watching the road.
1st design was a MSR YZ shifter with a piece of aluminum welded to it and a hole drilled in line with the shift shaft. Then I made a plate (similar to your kick stand guard one) that has a pin to engage the new hole in the shifter. This provides a double shear or the shift shaft.
1st version
1st version
1st version installed
My 2nd version employes upper and lower shift travel limits, because not only is the shift shaft subject to bending and breaking, if it is "over extended" up or down, it can bend the internal plate on the inside that ratchets the shift drum. (don't ask how I know)
2nd version plate
2nd version with shifter at rest
2nd version at down limit
2nd version at upper limit.
Old 04-29-2012, 10:35 AM   #6478
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
Brilliant! You've finally solved the problem in a this-can't-fail fashion!!
Make a kit and we'll all buy one!!
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline   Reply With Quote
Old 04-29-2012, 11:59 AM   #6479
lewiss66
lewiss66's Avatar
Oddometer: 374
Which one would be the best for all brands?
The second in the picture?
http://g650forum.forumactif.org/
http://buyvintage1.files.wordpress.c...porteur_01.jpg
G650 Xcountry 2007 / Beta evo 4T 2011
lewiss66 screwed with this post 04-29-2012 at 11:43 PM
lewiss66 is offline   Reply With Quote
Old 04-29-2012, 12:43 PM   #6480
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,443
Originally Posted by lewiss66 View Post
Which one would be the best?
It still doesn't fix the problem of the shifter taking a hit from the front when you take a spill when riding. When I broke mine, I looked at the fracture surface and you can tell that it broke from the front to the rear, no the bottom up.
tbarstow is offline   Reply With Quote
Times are GMT -7.   It's 02:50 PM.
