Old 04-13-2012, 08:14 AM   #16
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,847
Inspiration.
Pics by Bootlace.
Old 04-27-2012, 04:27 PM   #17
MaverickAus
MaverickAus's Avatar
Oddometer: 942
Has anyone done a (front fork) disk brake conversion?
1999 KDX 200, 1996 KLR 250, 2006 KLX 331 R , 2006 CT110X, 2012 Versys, 2001 ZRX 1200 R
MaverickAus is offline   Reply With Quote
Old 04-28-2012, 09:23 PM   #18
Salsa
Oddometer: 420
Does a CT200 count?
Slightly modified.
Custom welded double disc hub with 8" bicycle discs, mechanical calipers, KX85 forks and 19" front wheel. (It Stops !!!!)
Adjustable head crown, high backbone frame, 17" rear wheel similar to the front with 1 - 8" disc.
160cc Chinese YX160 engine, 3 gallon tank, KLX140 muffler.
Bodywork by Rubbermaid.
Motorsport Shocks I built for desert and MX racing 35 years ago. Nitrogen spring and variable damping depending on position in stroke.
The head crown on the CT200 is too small for a decent set of forks, so it was chopped off and replaced.
Don
Salsa is offline   Reply With Quote
Old 06-15-2014, 04:35 PM   #19
Giomeister
Oddometer: 1
Brake adapter
Originally Posted by WILL_S View Post
Forks weren't hard.I used kx80 trees but the cr ones will do fine.I cut the ct stem out and got a bush made to fit the ct stem into the kx trees then it all bolts together like stock.oh and i made a adapter to run the drum front,the forks i got were of a disc brake bike.
The arm is 2" over.the shocks are 400mm.
the pipe i made
http://www.advrider.com/forums/showp...1&postcount=17
I really like the under pipes,like on the yellow one and am going to knock one up soon.
Hey Will_S,
Do you have any more pics of the brake adapter and how it fitted? Have to do the same to a set of cr80 forks I'm attempting to rebuild. Good job on the bike btw!
Cheers
Giomeister is offline   Reply With Quote
Times are GMT -7.   It's 12:56 PM.
