Old 04-25-2012, 10:37 AM   #16
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,706
Originally Posted by skrub View Post
Yep. Pulled the gas line, fuel runs fine. Got the float set per the manual. I was thinking in that direction, maybe it wasnt get fuel and cutting off the air would balance the mixture for it to run. When its running and the carbs blocked off you can twist the throttle and it revs like its supposed to. So that should say its getting fuel. Gotta love a challenge.
Been lurking... Sounds like you pilot jet is plugged or the passage from the pilot jet is plugged. These are very small and can be plugged very easily. Strip the insulation off of a length of copper wire and pull one strand off. Use it to pass through the pilot jet. Do this to the pilot jet circuit (under the area that the pilot jet is seated). Use lots of spray carb cleaner after the wire and do it again. Watch for spray cleaner to shot through the small hole that is in the carb bore (angled hole on the engine side of the slide). This should solve your problem... IF it is the carb. Engine seal behind the mag will be your next place to check. Do the pilot first
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 04-26-2012, 01:50 AM   #17
Tuff Tunica
Tuff Tunica's Avatar
Oddometer: 392
Carb cleaner tool
Recently I've been rebuilding two old abandoned bikes. A great tool for cleaning the small orifices on a carb is a hypodermic needle. I've got a couple 2" 26 gauge that work great. Rigid enough to clean just about any small clogged opening.
Unbeing dead isn't being alive. E.E Cummings
Nothing is miserable unless you think it is so. Boethius
Tuff Tunica is offline   Reply With Quote
Old 04-27-2012, 08:21 AM   #18
Shocktower
Shocktower's Avatar
Oddometer: 8,314
I use Piano wire, you can find it at most hardware stores, I think
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 04-27-2012, 10:45 AM   #19
MacNoob
MacNoob's Avatar
Oddometer: 1,047
I use an acetylene torch tip cleaner.
Originally posted by Mark Twain: "There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact."
MacNoob is offline   Reply With Quote
Old 04-29-2012, 01:41 PM   #20
skrub OP
Oddometer: 258
That was it, a clogged passage. Thanks for the help every one. All it needs now is fine tuning. One last question, the manual says to set the air screw 1 1/2 turns off the bottom and ajust. Witch way increases or richens the engine ?
skrub is offline   Reply With Quote
Old 04-29-2012, 01:53 PM   #21
slideways
permanent ex-pat
slideways's Avatar
Oddometer: 4,467
Clockwise is richer.
Everything you ever wanted to know about carb tuning.
http://www.eric-gorr.com/pdfs/carb%2...%20jetting.pdf
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
Upper Italian Lakes report.
http://www.advrider.com/forums/showthread.php?t=160841
South Africa, Swaziland, Botswana ride report
http://www.advrider.com/forums/showthread.php?t=454490
Great CanAm Tour
http://www.advrider.com/forums/showthread.php?t=476605
slideways is offline   Reply With Quote
Times are GMT -7.   It's 02:24 PM.
