04-30-2012, 05:49 PM
#31 | ||
upside down parker
Oddometer: 3,238
there is front to back play in the rod big end on the right. i plan to remove it and get new bearings. no evidence of water in the bottom end. i was hoping to keep this an r50, but looking around for parts there are way more r75 and r60 parts. that makes sense when you look at how few r50 bikes were produced. if anybody has an r50 top end laying around give me a shout. |
05-01-2012, 05:14 AM
#32 |
ShadeTreeExpert
Oddometer: 5,222
I have an R90 so I think there are more R50 parts and 900 cylinders are rare. I guess it's a matter of one's view point.
Never memorize something you can look up. ---Albert Einstein |
05-01-2012, 06:18 AM
#33 |
upside down parker
Oddometer: 3,238
05-14-2012, 07:31 AM
#34 |
upside down parker
Oddometer: 3,238
this weekend i pulled the front forks apart and was met with the nastiest smelling oil i've ever encountered. i replaced the fork seals and the rubber bits in the bottom of the forks. here's what they had become
![]() i need to drop the springs back in and add some oil and the new fork boots and the forks will be done. |
05-14-2012, 09:33 AM
#35 | |
Oddometer: 93
05-14-2012, 09:40 AM
#36 |
ShadeTreeExpert
Oddometer: 5,222
It's good to get fresh oil in the forks. If they seem to not always go up and down easily then you may have to check more but the fresh oil and some parts is a good start. I just wanted to say that the old oil always looks like that. It was in there too long but nobody changes it often enough.
05-22-2012, 07:01 AM
#37 |
upside down parker
Oddometer: 3,238
i have a used set of barrels, pistons, heads coming my way.
i also ran into an old friend this weekend that happens to have a media blaster i can use. that answers the question of how to best clean the frame and all the other painted parts that have corrosion. |
05-22-2012, 03:52 PM
#38 | |
Don't buy from Brad
Oddometer: 7,403
You didn't happen to buy this bike from Stagehand did you? ![]() ![]()
On tap:Nada Aging: 3 experiments in mead - blackberry, apple, and straight honey |
05-22-2012, 03:53 PM
#39 | |
Don't buy from Brad
Oddometer: 7,403
check for cracks. strive to prime and paint before further corrosion sets in.
05-23-2012, 05:05 PM
#40 |
ShadeTreeExpert
Oddometer: 5,222
That cylinder with a single scratch in it also looks like it is quit pitted. Just from the photo I'd say it was not usable as is.
05-23-2012, 06:02 PM
#41 |
upside down parker
Oddometer: 3,238
agreed. while i didn't get the bike from stagehand it appears to have suffered at the hands of an owner who also has wristpin clips remaining on the bench.
looks like my new pistons and such will be here on 5/29. matt, that's the route i'm headed with blasting though i doubt i'll even have to buy the bud. |
05-23-2012, 06:43 PM
#42 |
Oddometer: 23
Great news on the new pistons and jugs!
"It's life Jim. But not as we know it." "Hey, easy man, I've got a beverage here." 1988 FLHTP - Caddilac pearl white road sofa. 1975 R75/6 - in boxes. |
06-20-2012, 11:09 AM
#43 |
upside down parker
Oddometer: 3,238
i need some assistance with an issue i found with the right connecting rod. it had what i thought was an unacceptable amount of play front to back. i pulled the rod and measured the bearing shell at 2.04 mm and the end to end measure of 48mm. they don't show any concerning wear.
i put some plastigauge in and reassembled. the plastigauge showed a .051 measurement. this is in spec according the manual. am i just being paranoid about the play in the rod? is there something else i should be checking? |
06-20-2012, 07:08 PM
#44 |
Don't buy from Brad
Oddometer: 7,403
Not buying bud will help to maintain your reputation.
06-22-2012, 06:46 AM
#45 | |
Oddometer: 430
