Old 01-20-2012, 07:11 AM   #61
Grreatdog
Grreatdog's Avatar
Oddometer: 11,433
Originally Posted by nearysr View Post
How does an XT350 compare with a TT in terms of performance? Are they fairly equal in terms of gearing, # of gears, weight, etc? I've been looking for an XT for a while now. Never thought about widening my search to include a TT. Thanks in advance for the advice.
TT350's were pretty rare here. I have only seen a couple in the wild including back when they were new. Back in the 1990's I looked for one for several years to drop my XT350 motor into and finally gave up.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 01-20-2012, 01:26 PM   #62
Fred333
Oddometer: 46
Hello Anklyne,
good to see you have got your bike back !!!
I will have a look to your futher adventures...
Fred
TT 600 36A, 59X, 3SW bastard
Restauration here: http://www.tenere.co.uk/forum/viewtopic.php?f=4&t=82
XT 600 Z Tenere (34L)
Fred333 is offline   Reply With Quote
Old 02-09-2012, 01:44 PM   #63
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,970
Hello TTers.
I'm considering buying a 1991 TT350
Wanting to use it for a street legal DS.
Any words of wisdom or wave offs?
TIA
I love these goofy bikes and their "let's go make coffee some place stupid, instead of, a stupid place to buy coffee" mentalities.
FatherX is offline   Reply With Quote
Old 02-09-2012, 06:12 PM   #64
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
Originally Posted by FatherX View Post
Hello TTers.
TIA
Check the carb manifold. The rubber can come away from the alloy. Easy to replace.
All wheel bearings apart from front right uses a pair of bearings.
Change to 15/50 gearing.
Don't fall off.
NordieBoy is offline   Reply With Quote
Old 02-09-2012, 07:05 PM   #65
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,970
thank you
Old 03-24-2012, 02:25 AM   #66
Anklyne
Anklyne's Avatar
Oddometer: 87
It wasn't my first time carrying beer on a bike, but it was my first time carrying a whole carton
Another recent pic
And with my mates DR-z
It's only a couple of months until I can go for my open class license (>250cc), so I'm going to be selling my street bike real soon, then looking for probably an XT600 or an older 660 Tenere. Then once I've got my license, I'll be selling the TT
It's been fun, but I bought the bike to learn on and learn I have. I still love it though :')
Anklyne is offline   Reply With Quote
Old 03-24-2012, 12:12 PM   #67
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
I've been using my 350 more and more...
DR650 Wiki
NordieBoy screwed with this post 09-11-2012 at 10:05 PM
Old 04-13-2012, 05:28 PM   #68
fcjunkie
fcjunkie
fcjunkie's Avatar
Oddometer: 1
Originally Posted by TTKlaus View Post
I have a TT350, wouldn't get rid of it for nothing. It's easy to make streetlegal. You would not gain enough by using the XT350 stator and flywheel. The stock stator is enough to power the stock 55W headlight and the tailight. The cheap way to do it would be to get a halogen headlight and run a 35W H4 in it. Get a rectifier put it in line and change the taillight to an LED, get LED blinkers and your home free, don't forget the horn. I used to run mine using the cheap way, but now I have a Universal Baja Designs system on it, Baja Designs also rewired my stator for higher output. Works great. I don't think Clarke has a bigger tank, I believe their's is stock size 2.6gallon. But the stock tank with a properly running bike should get you anywhere from 80 to 120 miles. I've gone 140 miles before on a tank (would not recommend it, it was scary out in the middle of nowhere and no gas station in site).
TTKlaus
Hey TTKlaus,
I was wondering if you could give me a little more information on the Baja Design kit you used on your TT350. I called them and they were not sure they could help me. I really like their dual sport kits and was wondering if you could steer me in the right direction? I don't want to change the looks of my '87 TT350 too much. It is awesome just as it sits!
Many thanks,
fcjunkie screwed with this post 04-13-2012 at 05:34 PM
fcjunkie is offline   Reply With Quote
Old 04-14-2012, 06:17 PM   #69
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,244
250TTr with 350 Top-end?
Anybody try putting a TT 350 top-end on a Yamaha 250TTr? The air-cool model?/ ED
BIG ED XT FAN is offline   Reply With Quote
Old 04-19-2012, 02:42 AM   #70
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
Some shots of my shock res conversion...
From a useless 1986 Yamaha version that needs a nitrogen needle and is non-adjustable...
To an orsum 1983 Honda version that is easily filled and adjustable (not that you can tell the difference on the bike, but it's got a dial )...
and with the longer line, it means I can remove the shock without also removing the airbox, airbox boots and carbs...
WR250 "gay" muffler - stealth mode engaged...
Damper mount...
The speedo splashes were from another job and my bike was a bit too close.
He's given me some stuff to polish it up.
Crank it above 7 and watch the stainless post flex
The damper isn't centered where I'd like but it's going to work fine.
The post leans slightly to the right which offends my OCD and sense of tidyness (stop laughing) but will be ok.
Looks like 3-5 will be normal settings.
Once I've been running it for a while, I'll dump the 10w and re-fill with 5w which should get the adjuster in the middle of the settings.
Old 04-30-2012, 01:38 AM   #71
Renxx
Moto maniac
Renxx's Avatar
Oddometer: 19
Slightly different TT:
Renxx is offline   Reply With Quote
Old 04-30-2012, 08:17 PM   #72
BIG ED XT FAN
Oddometer: 1,244
Nice TT350 bike!! Blue looks better then red.
Old 04-30-2012, 11:11 PM   #73
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
Ahhhh, no.
Although the black rims do make me go all gooey inside.
Old 04-30-2012, 11:26 PM   #74
Renxx
Moto maniac
Renxx's Avatar
Oddometer: 19
In 2007 it was still street legal...
Old 05-01-2012, 07:51 PM   #75
BIG ED XT FAN
Oddometer: 1,244
We never got street-legal TTs here in the USA!!
Times are GMT -7.   It's 10:10 PM.
