Old 04-30-2012, 07:56 PM   #1
2GbeemerLUV OP
Bavarian Motor Pie
2GbeemerLUV's Avatar
Oddometer: 51
Here's an easy one
Sorry if this is redundant as I know this is a common misfortune of an airhead ( but I put the "ewe" in noob): puffs of black smoke out of right exhaust when bike leans left or on side stand.
I know this is a recourse of unburned fuel or rich mix (I'm getting equal spark on both sides visually, but left head is working fine where as the right is not responding to air screw adjustments and dies when shorted and allowed to run on its own).
What else does this tell me and what should I be checking first?
2GbeemerLUV is offline   Reply With Quote
Old 04-30-2012, 08:51 PM   #2
ritetwist
ritetwist's Avatar
Oddometer: 178
Have you checked the plugs? I would guess the right one would be fouled,black and carboned up.
Carb cleaning is in order,check float for gas level,is it shutting off?
Could be just a bad or badly fouled plug.
Start with the basics.
Afraid to sleep for fear of missing something.
ritetwist is offline   Reply With Quote
Old 04-30-2012, 09:21 PM   #3
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,965
failure to respond to mix screw adjustments points to a blocked or dysfunctional idle circuit, to my idle, dysfunctional brain circuit.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Times are GMT -7.   It's 04:48 PM.
